I have these 18x8.5 +20mm front wheels, and 18x9.5 +25mm rear wheels. They still seem to set in just a bit, and I was looking at the 30mm and 20mm spacers, and was curious what others people opinions as to the best fit with wheels spacers...
I have lowering springs for the, and they are obviously not installed in the pics yet.. So I will need some spacers size that will work with the lowering springs..
Last edited by Iamtheonlyreal1; 08-12-2011 at 10:34 PM. Reason: Automerged Doublepost
I think you are thinking too big, especially when lowered.
I have stock M-Pars 18x8 13et front and 18x9.5 et 24 rear and run 12.5mm all around.
ECS spacers w/bolts which are quality and reasonably priced.
http://www.ecstuning.com/BMW-E92-335...cers/ES205205/
OEM e38 M-Pars refinished Hypersilver with Michelin PS2's 245/40/18 front and 265/40/18 rear, DRT drilled and slotted rotors, Hawk racing pads, Blue racing brake fluid, stainless braided flex lines, Brake Bomb, e36-Sport steering wheel w/airbag, tranny filter/pan seal, 88,000 miles and always more to do.
30mm spacers are massive and will add vibration to your ride. Personally, if I were to run spacers, I'd go with the rogue engineering ones (available in 10-18mm) because they are lightweight, hub centric, and have a bevelled edge to pry them off your rotor hat if and when they seize on.
One thing I regularly do to help prevent that from happening is use a wire brush wheel on a drill and brush all of the rust off my wheel mounting faces and brake rotor hats, then generously apply some anti-seize compound (I use a Loctite-branded copper-based anti-seize lubricant).
I used the 1010 wheel offset calculator and 12.5mm would put your half inch wider wheel all on the inside, thus same on the outside.
So my original guess was right on. Try this calculator: http://www.1010tires.com/wheeloffsetcalculator.asp
Yes, My initial guess was as correct as the math formula used in the calculator. So your 8.5 inch wheel with 20et and a 12.5 spacer would sit exactly the same place as mine on the outside. While being 12mm or about 1/2 inch closer to the strut on the inside. No Interpretation.
No spacers with Alpina!
+1No spacers with Alpina!
No spacers with my MK I's either. ET is 5mm Front & 21mm Rear.
91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
Got it lowered, and I have my spacers on the way.. I have the Magnaflow with X-pipe done, and removed the resonators, which sounds perfect. The Wokke Chips, I have a Dinan Trans Chip coming, Drilled Rotors on the way.
I have been debating on the body kit, but can seem to make myself pull the trigger on it..
Looks way better lowered!
What size hole in the x-pipe if you don't mind sharing? This has quite an effect on torque.
Not sure of the actual size of the hole.. We bent two pieces of 2.5 inch pipe, so they would come together in about a 5 inch length connection.. We then cut each side of the pipe in that 5 inch run so they would fit together, and then welded them toegher.. If I had to guess I would say the hole was about 2"+ tall and about 4.5" long.. It worked real well, and sounds great..
__________________________________________________
Cars
AC Schnitzer Type II fitment came with Spacers....
Front: 19x8.5 et 9 (with 6mm spacer)
Rear: 19x9.5 et 6 (with 15mm spacer)
Vibrations: None!
E31 M73 Forever
No spacers with E31 specific M System IIs...but then again I'm not looking to fill the wheel well up too much.
8 x 17 fronts w/245x45x17 (10mm ET)
9 x 17 rears w/275x40x17 (19mm ET)
Bill
Current stuff:
91 850i
http://forums.bimmerforums.com/forum...ictureid=11012
01 Porsche 996 Cab
1 Audi tt Conv
1 Jeep Wrangler Sport
1 Chevy 4x4 crew cab
71 MGB GT x 2
47 Willys Wagon - fixin'
54 Chevy 1/2 ton - fixin'
[/SIZE]
HRE Comp90 3pc forged.
9.5 X 19 Front 245/35/19
11.5 X 19 Rear 295/30/19
No spacers, custom offsets and hub bores..E31 specific.
No rubbing..
@OP..Be careful on the type of body kit you choose. If you go ACS like mine, you'l destroy it within an hour being that low upfront. Just my $0.08
1991 850i,80k miles,Wokke2000 Software,M3 Style Trunk Lip Spoiler,35% Tint,Zimmerman Cross Drilled Rotors,Limiters Disabled,1.5 inch Drop,AC Schnitzer Lower Front Spoiler,Mark850 design Roof Spoiler,HRE Comp90 Wheels 19x11.5 & 19x9.5, 295/30/19 245/35/19, Dinan Stage 2 Adjustable Sway Bars.
30mm (et -3) front and 15mm (et +12) rear, no wobbles. Good spacers shouldn't cause vibrations..
2.8 Z3 coupe + 6 speed || 200kW electric 1970 Jaguar XJ6
RONDELL Type 58
18" x 9" with 245/40/18 Front
18" x 10.5" with 285/35/18 Rear
No spacers, no rubbing...
'93 850Ci - Mineralweiß Metallic
2001 740iL - Titansilber
ALPINA B7 -Alpinweiß III
