Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Thread: Automatic no forward gears
  1. #26
    Mar 2018
    Asia
    1992 E32 M60 V8 RHD
    i have this problem on my 5hp18, no forwards, only reverse, and if i put the lever into "2" it also goes to reverse, i ended up changing the sift valve selector assembly, the plastic piece broken into two. i might think of sending the broken one to a lathe shop and let them machine one aluminium for me..as for now, bought a used selector valve from a friend, i believe one day the problem will come again.
  2. #27
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    shift valve selector assy material has been changed by ZF. I have each 2 of new the new material ones on stock : ZF 1043 327 069 for 4HP22/24, ZF 1056 327 173 for 5HP18, 19, 24, 30
    Troubleshooting list from the 5HP18 repair manual, same applies to 5HP30, maybe that gives you some hints:
    Condition........................... Cause............................................. .......................... Remedy
    Position Park position does not engage
    a) Shift linkage between selector lever and transmission mal-adjusted
    b) Excessive friction in parking lock mechanism
    a) Adjust selector lever, refer to 24 00 007
    b) Replace parking lock parts (connecting rod, pawl),refer to 24 34 006
    Park position does not hold (slips)
    Shift linkage between selector lever and transmission maladjusted
    Engine cannot be started in N or P, or can be started in all positions
    a) Shift linkage between selector lever and transmission maladjusted
    b) Transmission switch faulty. Starter motor inhibit relay or power line defective
    b) Replacing transmission switch, refer to 25 16 080. Replacing/repairing relay between inlet lines
    Position R : No reverse gear
    b) Clutch B destroyed
    c) Brake D destroyed In this case also no engine braking effect in position 2,1st gear
    d) Brake G destroyed
    e) Refer to "Troubleshooting Valve Body"
    b) Exchange transmission, refer to 24 00 046
    c) Exchange transmission, refer to 24 00 046
    d) Exchange transmission, refer to 24 00 046
    Hard engaging jolt P-R or N-R
    a) Idling speed too high
    b) Refer to "Troubleshooting Valve Body"
    a) Refer to Test Plan
    Backup lights do not light up (electrics OK)
    a) Transmission switch faulty
    b) Shift actuation between selector lever and transmission incorrectly set
    a) Replace transmission switch, refer to 25 16 080
    b) Adjust selector lever, refer to 24 00 007
    Car moves or creeps
    b) Clutch A defective (welded solid)
    b) Exchange transmission,refer to 24 00 046
    Position D: No power transmission
    a) Clutch A destroyed
    b) 1st gear one-way Gear defective
    c) Shift linkage between selector lever and transmission maladjusted
    a) Exchange transmission,refer to 24 00 046
    c) Adjust selector lever, refer to 24 00 007
    Hard shift impact N - D) (neng > 1500 rpm
    b) Also refer to "Troubleshooting Valve Body"
    a) Refer to Inspection Manual
    No shift (warm or cold)
    No shift: Shift 1-2
    a) Brakes C1 and 2 faulty
    b) Insufficient oil supply to brakes C1 and C2
    Shift 2-1
    Shift 2-3
    a) Clutch F faulty
    b) Insufficient oil supply to clutch F
    Shift 3-2
    Shift 3-4
    a) Clutch E faulty
    b) Insufficient oil supply to clutch E
    No braking effect:Shift 4-3
    a) Brake band C2 faulty; in this case shift 1-2 not OK
    b) Insufficient oil supply to brake C2
    No shift:Shift 4-5>>>Refer to "Troubleshooting Valve Body"
    No shift:Shift 5-4>>>Refer to "Troubleshooting Valve Body"
    No shift:Shift 5-4
    Clutch A faulty, in this case no 1st ... 4th gear
    Shift from full load to kickdown too long
    a) Plates broken
    Engine spins in shift 2-1
    a) Poor friction torque at plates
    b) 1st gear one-way Gear not OK
    a)b) Exchange transmission,refer to 24 00 046
    Engine spins in shift 2-3/3-2
    Engine spins in shift 4-3
    b) 3rd gear one-way Gear not OK
    Engine spins in shift 4-5/5-4
    No engine braking effect, no manual downshift 5-4
    a) Clutch A damaged
    No engine braking effect, no manual downshift 4-3/3-2
    a) Refer to "Troubleshooting Valve Body"
    No 1st gear, no braking action
    a) Brake D faulty
    a) Replace converter, refer to 24 40 006
    No converter lockup clutch
    a) Torque converter faulty
    Engine dies when moving off in Drive (converter lockup clutch always engaged)
    No positive engagement in forward or reverse
    a) Driver pressed off impeller
    Noise: Noise in all positions
    a) ATF level too low
    b) Valve body leaks
    c) Oil strainer dirty
    d) Round seal on oil filter missing/faulty
    a) Correct ATF level, refer to 24 00 026
    b) Replace valve body, refer to 24 30 006
    c) Replace oil strainer, refer to 24 31 156
    d) Replace round seal, refer to 24 31 156
    Leaks Oil dripping from converter bell housing
    a) Round seal on oil pump body leaks
    b) Round seal on pump body leaks
    c) Radial oil seal for converter leaks
    a) Replace round seal, refer to 24 31 020
    b) Replace round seal, refer to 24 31 020
    c) Replace radial oil seal, refer to 24 31 020
    Leak between transmission case and oil sump
    a) Mounting bolts loose
    b) Gasket faulty
    a) Tighten bolts. For tightening torque, refer to Technical Data
    b) Replace gasket, refer to 24 11 008
    Leaks Output leaks
    a) Radial oil seal for output flange leaks
    b) O-ring for transmission extension leaks
    a) Replace radial oil seal, refer to 24 12 016
    b) Replace O-ring, refer to 24 12 016
    Manual shift valve shaft leaks
    Radial oil seal faulty
    Replace radial oil seal, refer to 24 12 106
    Transmission plug leaks
    a) Plugs loose
    b) Seals faulty
    a) Tighten plugs For tightening torque, refer to Technical Data
    b) Replace seals
    Oil cooler pipes leak
    a) Oil cooler pipes loose
    b) O-rings faulty
    a) Tighten oil cooler pipes. For tightening torque, refer to Technical Data
    b) Replace O-rings
    Position R: No power transmission in reverse
    a) Signal wire to solenoid 3 grounded
    b) Valve piston for reverse gear lock not in parked position
    a) Repair/replace wire harness, refer to 24 35 501
    Hard engaging jolt in position R
    a) Damper of brake D malfunctions
    b) Modulation pressure too high
    c) Wire to pressure regulator faulty
    d) Pressure regulator faulty
    a) Replace valve body, refer to 24 30 006
    b) Replace pressure regulator, refer to 24 34 861
    c) Repair/replace wire harness, refer to 24 35 501
    d) Replace pressure regulator, refer to 24 34 861
    Position D:No power transmission forwards
    a) Damper A blocked
    b) Signal wire to solenoid 5 grounded
    b) Repair/replace wire harness, refer to 24 35 501
    Hard engaging jolt in position D
    a) Damper of clutch A malfunctions
    b) Wire to pressure regulator faulty
    c) Pressure regulator faulty
    d) Modulation valve malfunctions
    c) Replace pressure regulator, refer to 24 34 861
    d) Replace valve body, refer to 24 30 006
    Hard shift jolts in general
    a) Modulation valve malfunctions
    b) Repair/replace wire harness, refer to 24 34 501
    Position D:No shift 1-2
    a) Wire to output speed sensor faulty
    b) Output speed sensor faulty
    c) Signal wire to solenoid 1 grounded
    d) Shift valve 1 seized in parked position
    e) Damper C2 or clutch valve C1 seized
    f) Shift valve 3 seized in parked position
    b) Replace speed sensor,refer to 24 34 871
    e) Replace valve body, refer to 24 30 006
    f) Replace valve body, refer to 24 30 006
    No shift 2-1
    a) Signal or positive wire to solenoid 1 faulty
    b) Solenoid 1 faulty
    c) Shift valve seized in pushed position
    b) Replace solenoid 1, refer to 24 34 853
    c) Replace valve body, refer to 24 30 006
    No shift 2-3
    a) Signal wire to solenoid 2 faulty
    b) Solenoid 2 faulty
    c) Shift valve 2 seized in pushed position
    d) Pulling valve 2-3 seized in parked position
    b) Replace solenoid 2, refer to 24 34 853
    No shift 3-2
    a) Signal or positive wire to solenoid 2 faulty
    b) Shift valve seized in parked position
    c) Pulling valve 2-3 seized in pushed position
    Position D:No shift 3-4
    b) Solenoid 3 faulty
    d) Damper E seized
    b) Replace solenoid 3, refer to 24 34 853
    No shift 4-3
    a) Signal or positive lead to SV 1 defective
    b) Shift valve 4 seized in parked position
    c) Damper C2 blocked
    No shift 5-4
    a) Signal wire to solenoid 1 grounded
    c) Shift valve 4 seized in pushed position
    Car moves off in 2nd gear engaged
    a) Signal or positive wire to solenoid 1 faulty, in this case no 5th gear
    b) Shift valve 1 seized in parked position
    Car moves off in 3rd gear engaged
    a) Signal or positive wire to solenoids 1 and 2 faulty
    b) Shift valves 1 and 2 seized in parked position
    Car moves off in 4th gear engaged
    a) General positive wire faulty (transmission without current)
    b) Shift valves 1, 2 and 3 seized in parked position
    Shift transitions in zero load positions, full load shifts too hard
    a) Modulation valve function not O.K.
    d) Damper malfunctions
    Shift transitions of full load and kickdown shifts too long
    a) Pressure reducing valve 1 or 2 not O.K.
    b) Modulation valve function not O.K.
    Engine dies from shift 2-3/3-2 (overlapped control)
    a) Signal or positive lead to SV 4 defective
    b) Solenoid 4 faulty
    c) Pull/push valve 1 moves too hard
    d) Aperture for damper G clogged
    e) Damper F moves too hard
    f) Pull valve 2-3/3-2 moves too hard
    b) Replace solenoid 4, refer to 24 34 853
    Engine dies from shift 4-5/5-4 (overlapped control)
    a) Signal or positive lead to SV 5 defective
    b) Solenoid 5 faulty
    c) Pull/push valve 2 moves too hard
    d) Damper C2 malfunctions
    e) Pull valve 4-5/5-4 moves too hard
    f) Damper A moves too hard
    b) Replace solenoid 5, refer to 24 34 853
    Converter lockup clutch - Shift transitions too hard
    Converter clutch function impaired
    a) Signal or positive wire to solenoid 6 faulty
    b) Solenoid 6 faulty
    b) Replace solenoid 6, refer to 24 34 853
    Engine dies when stopping car in drive position (converter lockup
    a) Signal wire to solenoid 6 grounded
    b) Converter lockup clutch valve seized in pushed position
    c) Solenoid 6 faulty
    c) Replace solenoid 6, refer to 24 34 853
    Shift speed and shift quality generally not O.K.
    Temperature sensor not O.K.
    Replace wiring harness,refer to 24 35 501
    Troubleshooting peripherals
    Idling speed control (throttle valve electronic engine power
    control)
    Wrong shift points, oscillating shifts
    a) Engine idling speed too high or too low
    b) Idling speed control valve faulty
    b) Replace idle speed control valve, refer to 13 41 500
    Kickdown switch
    No kickdown shifts, only partial load/full load shifts
    a) Wire harness faulty
    b) Kickdown switch faulty
    c) Kickdown switch maladjusted
    a) Repair wire harness
    b) Replace kickdown switch, refer to 35 41 480
    c) Check adjustment, refer to 35 41 480
    Program switch: No S program or only S program
    a) Signal wire to program switch faulty
    b) Program switch faulty
    b) Replace program switch, refer to 61 31 265
    No W program or only W program
    b) Replace program switch,refer to 61 31 265
    Position switch (selector lever):No shifts Car remains in shifted gear
    a) No positive supply/fuse faulty
    b) Signal wire faulty
    c) Switch faulty
    a) Replace fuse
    b) Repair wire harness
    c) Replace switch, refer to 25 16 080
  3. #28
    Jan 2005
    Japan
    and another case of a broken manual shift valve on 5HP30: E34 540i transmission stucked in D https://www.bimmerforums.com/forum/s...n-stucked-in-D
  4. #29
    Jan 2005
    Japan
    bmw zf 5hp30 transmission technical service information Read more at: https://en.bmw-club.cz/manual_download.php?id=1416
  5. #30
    Jan 2005
    Japan
    pic of a broken manual shift selector valve, this one is from 5HP, but the 4HP almost looks same.
