Results 1 to 9 of 9
Thread: Interior light upgrade (e39 fade on/off lights)
    Nov 2007
    Ireland
    e34 520i
    I was thinking of changing my interior lights in my e34 to e39 ones, when I had an e39 I liked the ambient lighting and the way the lights faded on and off.
    Im fairly sure I'll be ok with the fitting and all that but does anybody know how I can get the lights to fade on and off?
    Will I have to get some e39 bits or is there a circuit that I can build to do this for me?
    I also want to fit some sort of lights to the bottom of the doorcards to light the ground as you open the door, I always thought it was an nice feature. Im unsure about how I will go about this though as I don't think the e34 door card is wide enough to fit the e39 items in nicely. I was thinking maybe LED strip lights, but they might look kinda shit and I want it all to look factory.
    If anyone has any input especially on the fade on/off wiring that'd be great!
    Houston, TX
    1990 BMW 535i
    A capacitor can easily create the fading effect. Not sure if there is a central power supply for the lights or if you'd need to install a capacitor at every light socket. As I recall, Shogun had something made up for this purpose, but he used a modulator rather than a capacitor. Its definitely been done though.
    Drivertain: Getrag 260/6, E34 M5 clutch, 15 lb FW, E36 M3 shifter, Portland Driveline driveshaft
    Suspension: Eibach springs, Koni adjustable shocks/struts, M5 antiroll bars front/rear, M5 thrust arm bushings, fully rebuilt suspension/steering
    Engine: Rebuilt top end and resealed. Turner Motorsport ECU chip.
    Lighting: Euro smilies w/ 5500k HID lights, clear front corner lights
    Nov 2009
    Hudson Valley NY
    90535ia 09MuranoSL
    Here is Shogun's kit
    It handles led or incandescent bulbs, programmable, well built and easy to install.
    BMW CCA #434501
    [ 127k Miles | Dinan Engine & Trans chips | LSD | AFE Pro 5 R Air Filter | ANSA Exhaust | BavAuto Springs | Bilstein Sport shocks | | Racing Dynamics front strut brace | BavAuto DTM Lip | Driver-side wiper arm upgrade | Euro LKM ECE-B | French Market E1 Spec Hella Lows (HID 4500K 55w DDM Raptor v2) and Highs (Osram Nightbreaker +90)
    | HID Projector Fogs - 3000K 35w DDM Raptor v2 | LED Interior lights with Shogun's Dimmer kit | 7 Series Rear Map lights | Euro clear parking, tail and signal lamps]
    Mar 2011
    Vancouver, BC
    too many, see sig
    I was going to mention shogun's stuff - he has an amazing website almost completely dedicated to lighting upgrades on his E32 - all of which applies to the E34.
    Make sure you have Google Translate installed.
    Nov 2007
    Ireland
    e34 520i
    Thanks for the replys!! I pm'd him about it, but I would love to build it myself if anyone had a circuit diagram I'd be grateful!
    Nov 2010
    New Jersey
    1994 BMW 530i Touring
    Dave check out my thread "Ambient light retrofit **updated**" its in the classified section....
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Dave, a circuit diagram will not help complete, I have also a programmed chip inside.
    Even the Ferrari guys like my dimmer module.
    copied from Ferrari chat about installation in Ferrari:
    I tested many dimmers and studied several electronic schematics. None of them where satisfying enough to be implemented in a Ferrari and especially behind the M032 ECU. Dirtly electronic modules would seriously mess up this ECU! My specs were quite severe: I wanted it programmable and configurable, ground based control (I initialy thought that we would need a +12V based control), almost no power consumption in standby mode, limited heat at the heat sink and a PWM based control (Pulse Width Modulation).
    On a good day, I discovered on a BMW forum a guy from Japan who is making what seemed to be the perfect dimmer. I got in contact with him and after many email exchanges and studying his schematics, I got convinced that we have here the right product. His module is entirely programmed using a PIC12F629, just perfect! The MOS FET used is a 2SK3140 using a 4V gate and is attached to a small heat sink.
    Here a the characteristics of this dimmer module :
    - Support of normal bulbs or additional LED’s
    - Maximum control of 200W (15A)
    - Standby current drain of 1mA
    - A noise signal is applied to prevent line noise from generating false-starts or miss-functioning
    - Uses a digital IC (PIC12F629) to realize control by PWM adjustment
    The dimmer module has 4 wires
    - white : OUT ground to the dome light and LEDs
    - yellow : IN delayed ground from the M032 ECU
    - red : +12V HOT (module power)
    - black : ground (module power)
    The dimmer module can be configured using DIL switches :
    - SW1 OFF : LED + normal bulbs
    - SW1 ON : normal bulbs
    - SW2 OFF : Fade In time of 0.5 secs
    - SW2 ON : Fade In time of 2 secs
    - SW3 OFF – SW4 OFF : Fade out time of 2 secs
    - SW3 ON – SW4 OFF : Fade out time of 4 secs
    - SW3 OFF – SW4 ON : Fade out time of 6 secs
    - SW3 ON – SW4 ON : Fade out time of 8 secs
    http://www.ferrarichat.com/forum/sho...d.php?t=319055
    installation instructions
    http://www.quebecman.net/e34/InteriorDimmerModule.pdf
    have them on stock
    also the one touch up and down module for all 4 windows is available ex stock at the moment
    Nov 2011
    Ireland
    e39 530d e36 m3 e34 525i
    Having looked at the installation instructions I'm just wondering will this fade off the rear lights also or will they need to be tapped into separately or will another unit need to be used?
    Jan 2005
    Japan
    1 module per car handles all interior lights.
    here some short videos on an E32 Alpina B12
    http://www.youtube.com/profile?gl=JP...11/CSXnbV8nHkE
    http://www.youtube.com/profile?gl=JP...13/PZRnhc-buMU
    still have some on stock ready for shipment
    http://forums.bimmerforums.com/forum...ghlight=dimmer
    other gimmicks
    iluminated shifter
    http://www.youtube.com/profile?gl=JP...21/K6_KD8tZ1_M
    http://www.youtube.com/profile?gl=JP...14/kF-xlxsi9FY
    http://www.youtube.com/profile?gl=JP...19/Te6otyB8BnA
    the units look like this
    http://userimg.teacup.com/userimg/88...bs/0000831.jpg
    http://userimg.teacup.com/userimg/88...bs/0000833.jpg
    one touch all 4 windows up and down module
    http://www.youtube.com/profile?gl=JP...29/Oz02uHWlZYk
    [ame]http://www.youtube.com/user/alpinakozou#p/u/7/yEOgqk-N19Q[/ame]
    [ame]http://www.youtube.com/user/alpinakozou#p/u/8/OV2FfosPniA[/ame]
    [ame]http://www.youtube.com/user/alpinakozou#p/u/9/tY6qC1yxBbw[/ame]
    installation
    http://alpinakozou.web.fc2.com/file/...20100411a.html
