I checked all the fuses and even took off the rear cover to inspect and everything is plugged in as it should. It even squirts out fluid but it won't wipe...weird. Anyone have an idea?
'08 M5 Sepang Bronze/Portland - Modded-
'11 328i M Sport Le Manns Blue/Oyster - wifeymobile
'02 525i Touring Alpine White/Sand - Getting modded
'06 Mini Cooper JCW GP#1281 - SOLD
'10 MiniCooper S Laurel Sport Edition 1/100 - SOLD
'99 M Coupe Laguna Seca Blue/Black - highly modded SOLD
'04 4.8is X5 Estoril/Black Alcantara - modded SOLD
'01 740i Shorty Sport - TiAg/Blk - SOLD
'98 M3/2 Cosmos - Modded SOLD
'97 M3/4 Alpine - stock SOLD
Try to use a multi-meter to see if it is getting juice. If it is getting power, it may be the motor failed.
Brian
The car is telling you to delete the rear wiper.
Oh yeah, duh!!! Will do. I'll report back what I find tonight. Thanks for the tip!
Hahhaha, as infrequent as i drive in the rain,
Those times I do get caught, there is literally zero visibilty out the back once you get up to 75-80mph. It just becomes misted by water kicked up by rear 275s. I can't watch for cops at that point hahahhaah. Plus I like the look of the wiper.
If you open the sunroof while you're on the freeway and it's raining, it'll keep the water off the back window. Sounds crazy but it works!
-Joe
Let me know if you need a motor...I did the wiper delete.
Brian
Haha no...water doesn't come into the cabin at all actually. Give it a try next time even if you have a wiper and you'll see.
I personally removed mine a couple of years ago and couldn't be happier. I've driven in rain quite a few times and haven't needed it using the "sunroof" method
-Joe
check the wiring in the upper left side rubber loom, broken wires will cause all kind of issue for your wiper, license plate lights, lock... you name it...
The only other weird issue I have with the rear is that the hatch light doesn't come on when the hatch opens like it used to. Now its either off or on by switch only.
I have a rear wiper assembly for sale with motor
Just take it off..... that's what I did
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
I will let you know shortly if I will need that assembly. How much you want for it?
I like the look of rear wiper too
I still haven't gotten around to testing it yet...
Never would have tought of that... Thanks for the tip, I'll give it a try.
How did you figure this out? By fluke, someone told you about it or you studied air flow mechanics??? lol.
It would be nice to hear from the guys with larger A.C. Shnitzer style roof spoiler, if they get the same effect...
Mine quit working for a long time, then began to work again. It just quit again yesterday. That's what I get for opening my hatch.
"If the Corvette is a rebellious child of the extended automotive family, the M coupe is the blackest of sheep." - via Car & Driver
