Pretty decent, I suppose. If it actually sells for $6,500, then I'll be very encouraged regarding the value of mine.
Is that bulging panel full of holes below the HVAC control (see PhotBucket link) an indicator of the less-integrated aftermarket A/C system? I seem to have heard something to that effect.
Jeff
1984 320i Baur TC2 5-Speed Opalgrün (Jeff's)
1987 325e Sedan A/T Zinnoberrot (Dawn's)
1984 633 CSi 5-speed Bronzit (Ours . . . if she says so)
Jeff, My car had dealer / aftermarket A/C installed in it , which I have removed the kit came with a grill that was added to the center console to accommodate the added blower motor see pic. the ones I have seen look nothing like the one in the photo on photobucket the dealer would make a cut out in area in front of the ash tray then add the grill to hide the blower motor
Click here to join the Baur international community on G+
https://plus.google.com/u/0/communit...05332828437111
I would like to get something like this going for the TC2s also: HELP!!
Here is the first installment of what will eventually be a complete list of ALL the known TC1 Baurs in the US. While I have given only the minimum info here on these cars, I actually have tons more pics of most of these on file, which I will get to sooner or later.
For example, I have the history of Baur #917 from 2001, through 5 different owners, with pics from 4 of them! And we have tracked the Beaufort Baur, #982, from the East Coast to the West Coast, with pics from 4 different owners!
I wanted to get something up on the blog, so this post is a start. These are the US Baurs with Baur Plate numbers between #00000 and 01000 that we have some records on now. You will notice that, although we have pics, some of these Baurs are still unfound. We need your help to find them, boys and girls, so.... keep those cards and letters coming in! And there are more Baurs out there waiting to be found!
Together we have come a long way toward our goal of finding them ALL, but.... we can't do it without you. Thank you all, and ... enjoy!
Stay tuned for more!
Tom
SE Connecticut
1982 323i Baur, 1977 320i (carbed),
1978 320i (parts)
1991 325ix 5 speed, 1989 325ix (winter),
1989 325ic (summer)
1973 2002 Malaga (with frosting)
1975 Mercedes W115 300D (The Departed)
the late 1979 323i Euro (project, Now Departed)
Visit my blog: Baurspotting
http://baurspotting.blogspot.com/
BWR PWR!
Tom,
I just learned of a wrecked TC2 318i with an A/T. I will try to get the plate number for you so that it can be accounted for.
Jeff
HELP NEEDED
How the $%&* does one remove the $%&*ing interior courtesy lamp from the windshield header panel on a Baur TC2?!?
I have tried everything I know to try, and still it refuses to budge. Yes, I know about the little springy tab on the left side. No, nobody has glued the lamp assembly in there. I even took out the ActiveCheck panel (that practically FELL out!) and I still can’t get it to come out.
My motive in removing it is that there is no power to my door jamb switches and I thought the lamp a good place to start looking.
EDIT:
Sorry, coudln't avoid the automerge . . . or venting the frustration. Today, the whole day went as described above.
Jeff
I received some maintenance records from my previous owner. I really wish I didn't know what I didn't know. This car has had a lot of work done on it. Granted its 28 years old but the a/c system has been replaced twice, the fan clutch 3 times, the water pump 3 times, and the fuel system was practically ruined from sitting in storage for 6 years. I think the in-tank fuel pump is still making noise. Didn't notice it when I did the test drive but now I hear it. A/C compressor also rattles.
On the positive side I found a receipt from Baur for some parts the first owner ordered. My German isn't the best so I'm not sure if the Baur serial number is somewhere on the invoice. If someone can tell me how many digits, etc. then maybe I can decipher it.
Ross
Ross,
Judging from the photo of the Baur tag in Post # 674, a good example of a Baur number would be B43466-13. (Too lazy to walk out to the garage and look at mine!)
Normal replacement schedule for the water pump and the fan clutch is every 100K miles (IIRC; someone correct me if not). If your car has an M20 engine (6-cyl.) then the normal replacement schedule for the timing belt is every 50K miles or 4 years. Since water pumps are cheap (though fan clutches aren't), sometimes they get replaced every 50K anyway since the tech or owner is "in there" anyway to change the belt. All told, I wouldn't be too concerned about the items which the maintenance records indicate were changed frequently -- it might even be a positive indicator of how well the car was maintained.
About the in-tank pump making noise: my 320i doesn't even have one! It appears to have been built that way. If there are two small wiring harnesses connected to the top of your sending unit, then yes indeed you have an in-tank lifter pump. One harness, then no.
Jeff
Ross. US 318i's had a pre supply pump in the tank and an exterior pump. Here's a link to the in tank diagram on real oem
http://www.realoem.com/bmw/showparts...46&hg=16&fg=05
in regards to the baur # you may find just this sequence ( example 44808 ) the range will be 41308 through 43312 for 1984
Back to my interior courtesy light issue for a moment:
It is clearly made by Hella, but it bears no part number on the face of the lens.
Does anyone know what its original Hella part number was? Or what its BMW part number was? I assume that it must have been adapted from a more popular application.
I found this diagram on RealOEM under “Various Lamps”:
http://realoem.com/bmw/showparts.do?model=1131&mospid=47257&btnr=63_0254& hg=63&fg=30
Note Ref. #1 in the diagram, P/N 63311363234. It is described as an interior light for the E30 Japan package, and it is clearly designed to recess into some sort of panel. Could this be the same light unit? I can find no illustration / mention of an interior light in any of the Baur drawings.
The reason that I want to find a part number is so I can have a replacement on hand or at least on order if (when?) I break it during removal. The lamp must now come out because I ended up disconnecting one of the wires and it would require a surgical scope and instruments to get it back on while in place.
Or can I simply remove the entire panel in which it mounts from the windshield surround without too much drama / damage? That might be the way to go if it is do-able. I am counting on my fellow Baurites to give me some direction here; if not y'all, "Who ya gonna call?"
Jeff
Not sure if this is much help for you.....
My interior light on my 1982 TC1 Baur is located in the overhead roll bar. Here is a pic....
Sorry for the poor quality... camera phone pic in fading light.
I checked the Baur diagrams also.... nada. Tomorrow in the daylight I will have a look at two other E21 overhead lights..... as well as my 1989 325ix E30.... to see how they compare. My son has the E30 Cabrio, so that is not readily available.
I have never touched the unit.... so I have no experience to offer you on this, unfortunately.
I hope to get back to you before I leave for the Bav Auto show tomorrow.
Tom
SE Connecticut
1978 320i (parts)
1989 325ic (summer)
BWR PWR!
Jeff, I would have posted some help sooner however, I just got home.
Here's a sequence of pics that may help.
This is what you are talking about right ?
take a small precision flat head screw driver and insert into the slot on the opposite side of the selector switch
put very light pressure on it to realse it
Then slide that side downward
in this next shot you can see the spring clip clearly
I hope this helps Ed
On a side note the lamp switch is rather cheesy and they have a tendency to brake also where the spring clip sits in the plastic lens will become brittle over time and will also fail , hopefully someone did not glue it in place
Tom
SE Connecticut
1978 320i (parts)
1989 325ic (summer)
BWR PWR!
Tom and Ed,
Thank you both for going to so trouble much for such a stupid problem!
Ed, you have no idea how much I envy you that photo sequence -- I fought with that light for at least 20 minutes, depressing the tab while (carefully) prying from behind with a screwdriver . . . but it is still in there. If I pry any harder, it will break; I can see where it is cracked already.
I hope I can buy one of these lamps new from BMW. Does yours have a part number on it? If not, I suppose that I should just look up one for a '68 1600-2. Can you tell me where it mounted in that car? BTW, it is definitely not the same part as those in Dawn's 325e sedan.
Thanks again.
Jeff
@ Jeff
here you go 63311363234
http://www.ecstuning.com/Search/63311363234/ES175095/
Tom
SE Connecticut
1978 320i (parts)
1989 325ic (summer)
BWR PWR!
Tom
SE Connecticut
1978 320i (parts)
1989 325ic (summer)
BWR PWR!
30% chance of Rain in the late afternoon and down right chilly. I need to replace my tail light seals in a good rain storm my car's / U boat trunk get a little wet to say the least I think I'll start calling her U323
Dave T and I will meet up along the way Rodney is about 60% committed due to weather, I'll send Patrick a e-mail and see if he is going to attend.
We should meet up in the parking lot as we had discussed 6:30 ish
Do you have my phone # still ?
Tom
SE Connecticut
1978 320i (parts)
1989 325ic (summer)
BWR PWR!
Hoping to see these Baurs tomorrow at Bav
Sunday October 7th in Portsmouth NH at Bavarian Autosport annual show shine we had every generation Baur TC represented and a 1962 700 vert.
The 700 was powered by a modified R75 engine. you could eat out of this engine bay.
https://lh4.googleusercontent.com/-s...k/DSCN0176.JPG
https://lh5.googleusercontent.com/-t...5/DSCN0182.JPG
Dave T's 2002 Targa
Baurspotting is on the case doing a full inspection .
The Baurspotting mobile.
Baurspotting in Action
Last but not least My e30
Baur Spotters !
Overall it was a great show lots of nice cars and ton of 2002's
here's a link to the pics of the rest of the show
https://plus.google.com/u/0/photos/1...31532882240097
Ed and Tom,
Looks as though you gents had a great time. I know I'm nuts, but I'd really love to have a BMW 700 Baur -- of course, one of those is probably worth three (four? more?) Miss Opals.
Tom,
Is that your son with you in those photos?
Jeff
EDIT:
I just paged-through the whole album. WOW -- there were some really rare, really well-done Bimmers in attendance! I'll bet that there were some real "characters" there as well. Did Rob Siegel (The Hack Mechanic) and/or Mike Self (02 Cents Worth) make it?
J.
Ed, what's with the limerock edition m3 plaque? Was that an e92? Totally missed that one. The 700 was a neat little car! The exhaust was pretty comical.
Your car was awesome in person. First e30 baur I've ever seen. The only pictures I took were of the baur roofs and their clamps/attachments...
