Results 1 to 14 of 14
Thread: E30 GTS2 325is
    Nov 2009
    St. Charles IL
    E30 Racecar, Audi A4
    E30 GTS2 325is
    For Sale: 89' GTS2 325is - $7.900
    100% turn key, well built, very clean and very reliable. Car weighs 2340 without driver
    Drivetrain
    Low mileage M50 NV 24 vlalve engine transplanted in 2010
    2 D"Sylva chips available - 1 for 93 oct and 1 for 95 oct
    186 HP and 167 TQ at the wheels with 93 oct chip - dyno sheets available
    Stainless steel full length headers
    All new belts, hoses, motor mounts and water pump
    power steering delete
    3.90 LSD rear end
    Getrag 265 transmission - shifts perfectly
    short shifter - delrin shifter bushings
    Clutchmasters FX500 4 puck racing clutch and pressure plate
    Suspension
    Koni adjustable coilovers front and rear
    Ireland Engineering custom adjustable rear subframe
    Ireland Engineering sway bars
    Ireland Engineering camber plates
    M3 control arm bushings
    reinforcement plates welding on shock towers, sway bar mounts and control arms
    Poly bushings all around
    Safety
    Professionally built, tig welded, heavily gusseted, 1.5" chrome moly cage - NASA and SCCA legal
    Kirkey Intermidiate seat
    Schroth 6 point Hans harness - expires 2015
    3 nozzle halon system
    right side window net
    quick release suede covered Momo steering wheel
    Longacre wide view mirror
    2 sets of wheels - 15x7 Kosei with Toyo RA1 225/45/15 and brand new set of Hoosier rain tires and 15x7 D-Force wheels
    AMB hard wired transponder included
    Many spares - spare M50 motor (currently apart), Getrag 265, 5 puck clutch disk, 2 DME's, rotors, new control arms + bushings
    Call William at 630.584.2364
    Nov 2009
    St. Charles IL
    price reduced - $9,900
    Nov 2009
    St. Charles IL
    price reduced - $8500
    Jun 2008
    Syracuse
    2002 325Ci, 2005 M3 Competition; 1997 Lexus LX450
    Linky for photo album no workie!
    Nov 2009
    nyc
    90 m3
    This car is bad ass
    Aug 2011
    naperville,il
    92 honda civic
    what a steal. can this thing be registered and driven on the streets?
    Nov 2009
    St. Charles IL
    price reduced $7,900
    Aug 2009
    Lake Arrowhead, CA
    75 BMW 2002, 82 320
    After a number of false starts, the car is getting it's turn in the rotation. I have become it's care taker, going on 3 plus years and as it would happen the SCCA is contemplating a rule change for PF in the world of Solo2. If it in fact happens, you would be able to run an E30 with a 24 valve motor and be legal.
    On a local bases I can run in what we call Historic 2, for cars up to 1985. The E30 got it's start in 1984 and as a continuation of the model it's "good to go".
    All of the safety gear is out of date, but in the solo2 world it's not an issue. The fluids are getting changed. The oil pan gasket is getting changed. The half shafts are getting changed. It's getting a new radiator with an electric fan and a Red 46 sump guard.
    Again, if anyone knows of William Garbato please let me know. Thank you.
    David Barrish
    Jun 2014
    Germantown, TN
    2 E36 M3, 1 E46 328i
    I don't quite understand your post... are you selling the car... or are you the new owner and giving the previous owner a heads up on what your plans are for the car?
    Aug 2009
    Lake Arrowhead, CA
    75 BMW 2002, 82 320
    Sorry for the confusion, just taking a stab at finding the previous owner.
    David
    Aug 2012
    finksburg, MD
    88M5 95M3x2 72'02 08 550
    This is a great looking car. If I didn't already have a race car I would definitely be tempted. When I showed my wife the price of 7900 for a complete package she almost lost her breakfast. My last check for annual upgrades and refresh was 5k.
    Nov 2009
    St. Charles IL
    Hello David, I just stumbled upon this old post. Were you still looking to connect with me?
    Nov 2013
    Stone Ridge, VA
    1995 BMW M3 Coupe
    Not sure why he didn't PM. Kinda makes sense why you wouldn't be monitoring this old thread.
    Aug 2009
    Lake Arrowhead, CA
    75 BMW 2002, 82 320
    Thank you for the ping. I have the car up and running. In fact I just had it detailed, it looks great.
    I had a chance to run the car at an El Toro autocross with the Cal Club, it was a blast. With any luck I will have it at VARA University, Buttonwillow, in January.
    David
