Results 1 to 24 of 24
Thread: Can anyone explain the e30 tps mechanism?
    Ontario
    '86 325e
    My car has been having symptoms of a faulty throttle position sensor with bucking, hard shifts, idle problems etc. I unplugged the tps today and didn't notice any difference in the way the car performs.
    So I took it off and took it apart but didn't seee anything wrong inside other that it was drenched in oil. There is a little white box with a clicky thing that I think is pushed when the throttle is all the way closed, I assume for idle...Also 2 little prongs that push together when the throttle is all the way open...But there seems to be no active mechanism that would detect throttle position for regular throttle.
    Does anyone know how they work for certain?
    here is a picture. note the oil drenching
    Oct 2008
    Media, Pennsylvania,
    1991 325i
    Well the throttle position sensor is really only used for WOT and Idle. Between those two it doesnt send a signal to the computer.
    1991 BMW 325i(Current Daily) (S52)
    I have carburetors, and I'm not afraid to use them!
    There are always other fish (engines) in the sea (Craigslist)
    Life is about enjoying the engine you are sitting behind.
    Ontario
    '86 325e
    ohhh...how common is it for the idle sensor to quit? Would it being drench with oil ruin it?
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Not necessarily ruin it, but it could prevent the contacts from closing. Cleaning it out would take care of that.
    The only E30 with a throttle position sensor (as opposed to switch) is the M42.
    "Howdy, Folks!"
    monterey, ca.
    e21, e30 m3. e46 330ci
    the throttle position switch signals the computer when throttle is closed and then again for wide open. the computer trims the fuel accordingly.
    Quote Originally Posted by richardodn View Post
    not so much of a sensor, but a potentiometer.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
    Feb 2010
    MYRTLE BCH SC
    86 porsche 930, 88 325is
    the thing that caught my eye was "drenched in oil". sounds like you have a lot of oil blowby, due to bad rings.
    how are the plugs, wires, cap and rotor? not to mention compression/leak down?
    check the TPS with a multimeter. make sure the 2 contacts have continuity when closed, then make sure it is adjust properly at idle. off idle it really has no function other than to say it is not at idle.
    make sure you dont have any air leaks too.
    [__] RUNNING: [__] NOT RUNNING: 86 PORSCHE 930
    [__] RUNNING: [__] NOT RUNNING: 88 BMW 325is 200K+
    [__] RUNNING: [__] NOT RUNNING: 2000 MERCEDES E320 WAGON
    [__] RUNNING: [__] NOT RUNNING:99 GRAND CHEROKEE 160K::
    [_:_] RUNNING: [__] NOT RUNNING: mazda B2200
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Quote Originally Posted by Tom D View Post
    That's how many automotive sensors work. Variable resistance due to position (AFM, fuel level) or temperature (temp gauge sender)
    "Howdy, Folks!"
    Jan 2006
    East SF Bay Area
    e46 M3 coupe, e30 325is
    Sorry to correct you guys but the TPS is not a potentiometer nor does it provide any voltage or current dividing.
    The TPS is comprised of two normally open contacts, one of which closes during idle and the other during wide open throttle. As you can see in the picture, its nothing more than a pair of contacts and another pair inside the micro switch.
    Its simply a switch toggled by throttle position. It is also normal to see oil inside of the unit, every TPS I've ever removed and opened had some oil. The oil comes from oil vapor which feeds from the valve cover breather hose into the throttle body itself.
    Its best to test the adjustment with a DMM but it can be tested by listening. Near idle, by moving the throttle cable arm, you should hear the "click" of the micro switch. At near 70% full throttle, per Bentley manual, you should hear another click. If you're hearing only 1 click, its out of adjustment range and needs to be readjusted.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    monterey, ca.
    Quote Originally Posted by gmannino View Post
    ……..Sorry to correct you guys but the TPS is not a potentiometer nor does it provide any voltage or current dividing.
    that's exactly what richard and i both said. the potentiometer or sensor if you will, only came on the M42 powered E30. the M20 E30 had a switch.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    Jan 2006
    East SF Bay Area
    Yup, just noticed that. Sorry lol
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Ontario
    '86 325e
    Yep it was definitely not adjusted properly. There is a click now that wasnt there before.
    Now that I think about it, I remember taking it off last november and not knowing how to reinstall it or whether it mattered which way it was turned then fastened. The car seems to not buck and go insane at low rpm with the clucth out now.
    Oct 2003
    Dallas, Texas
    E30 & a ZHP
    how to adjust TPS?
    How does one go about "adjusting" the TPS? I have a high idle issue on an S14 motor (idles @ 1200 RPM) and rumor has it the usual suspect is a bad or maladjusted TPS. It is not the exact same part number as on the M20 motor but looks very similar and is easier to access.
    Any feedback appreciated...
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    I don't know any of the particulars of adjusting it on the S14. Have you looked over at http://www.s14.net/forums/ ?
    "Howdy, Folks!"
    Dec 2004
    Huntsville, AL
    87 325is
    I don't have any docs on this but if the TPS on an S14 is similar and has just idle & WOT switches, it probably would be adjusted the same as other E30's. That means adjusting the TPS so that the idle switch closes when the throttle stop arm is 0.030-0.060" off the idle stop screw.
    You can necessarily go by the click. The idle switch can click and yet not make an electrical connection. Use an ohmmeter to verify operation of both the idle and WOT switches. When adjusting the TPS is is best to use a meter or test light.
    Jim Levie, Huntsville, AL
    Sep 2011
    chicago
    85 325e
    ....and make sure the computer sees the signal. With an open you can adjust all your life and never get it from point a to point b. (If adjusting does nothing)
    I like to test stuff before I replace it, it makes me feel better about expensive parts.
    idle thread
    Most recent discovery on my pre-owned e30: car has the ability to alter my lifestyle indirectly through use of my wallet.
    Jul 2003
    nova
    8 BMW's & a Ford p/u
    re: s14...the tps is mounted with two screws. when they are loosened you can rotate the tps on the throttle shaft slightly to adjust it at idle.
    Jul 2013
    CT
    1989 325i 4 Door 5sp
    Reviving an ancient thread...
    Thanks very much for the photo of the inside of the switch. My switch is adjusted correctly but the WOT function is intermittent which is to say it sometimes "beeps" the multimeter and sometimes the resistance lingers around ~25-75 ohms. This to me sounds like oil on the contacts. I see the little plastic tabs around the perimeter of the switch... did you just use a pick to open this puppy up?
    One wrinkle - Bentlely specifies the WOT test by "slowly opening the throttle". When I do this by hand, in a relaxed manner I get continuity pretty much 100% of the time. When I simulate "flooring it" or the stomp test I get decidedly mixed results. Does anyone know if ~25-75 ohms would lead to enough voltage to trigger the full throttle signal to Motronic?
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    you can use whatever to undo the little latches. pick, small screwdriver, knife tip, whatever.
    as far as the rest of your question, no idea
    No e30s again.
    Dec 2018
    Germany
    1990 E30 325i 4 Door
    Quote Originally Posted by somecarguy View Post
    Are you having any issues when driving and actually going WOT on the pedal? or is it not running yet?
    Jul 2013
    CT
    It was running "fine" before the teardown, but there are several threads on dyno results of cars where the ECU doesn't receive the WOT signal, doesn't go into closed loop mode and therefore runs at the wrong AFR at WOT. I'm not necessarily chasing extra ponies I just want the car to run (and self-diagnose) as it was intended.
    Aug 2019
    Australia
    E30 323i
    How did you guys even get this thing open? I'm scarred the plastic is about to break if I use too much force.
    Are those 4 plastic prongs on the top half actual clips that need to be pried outwards away from the bottom half?
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Most of the time you really don't have to open it up. Just drill a couple of small holes on the bottom (when mounted) to allow any oil to drain out. Use some cleaner (electrical contact cleaner, brake cleaner, carb cleaner, etc.) sprayed into one of the holes and flushed out the other. Make sure you don't end up accidentally spraying it in your eyes. That's usually enough to get it functional.
    "Howdy, Folks!"
    Aug 2019
    Australia
    E30 323i
    Some people just dont want to drill holes into these expensive little parts
    I got mine open with difficulty. They are glued closed, so first time will be a biatch. Trying to knock the bottom half off was very awkward because the only spots you can grab it (or clamp it with a vice) presses the edges of that half onto the very other half you are trying to knock out.
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    drill a small hole carefully it will stop it happening again and cause no issues
    BMW E30 325is M20B33 in the making....... ITB's, roller rockers and stroked to the hilt
