Results 1 to 18 of 18
Thread: INPA error IFH-0006
    Jul 2011
    Netherlands
    E36 325i
    INPA error IFH-0006
    hey guys,
    I'm having some problems with my INPA to work proper.
    I installed INPA 5.02 and Ediabas 6.4.7
    When i start INPA it will say if i turned the ignition on or off.
    but when I try to connect tot any module of my e36 325i I will keep getting the IFH-0006 error.
    In the INPA faq it says:
    3.4 IFH-0006: Command not accepted
    This error occurs if a SGBD is loaded in the Tool Set when the OBD connector is being used.
    Reason 1: ODB has actually been set as the interface in Ediabas.ini, but the Tool Set uses
    the multi-instance with another interface, e.g. K-Line. The setting for the multiinstance
    and the interfaces used here is made in the file Tool32.ini in the
    directory C:\Windows (for Windows XP) or alternatively C:\Winnt (for Windows
    NT). Then, the entries in Tool32.ini, or alternatively the interface apply and not
    the ones in Ediabas.ini. The use of multi-instance in the Tool Set is identified in
    the title bar, for example with “Tool32:1”, for single multi-instance.
    Solution 2: Enter the interface that is being used in Tool32.ini or disable multi-instance with
    the entry “No”.
    so i went to look up the file ''tool32''
    this is what is says in the file:
    [Programm]
    Name=Toolset
    [KONFIGURATION]
    INTERFACE01=,,
    INTERFACE02=,,
    INTERFACE03=,,
    INTERFACE04=,,
    INTERFACE05=,,
    INTERFACE06=,,
    INTERFACE07=,,
    INTERFACE08=,,
    INTERFACE09=,,
    MULTIINSTANZ=N
    LANGUAGE=E
    TOOLBAR=-1
    KOPFZEILE=-1
    HINWEISZEILE=-1
    JOB_INFO=-1
    TAB_INFO=-1
    ARG_INFO=-1
    RES_INFO=-1
    AUSGABE_SORTIERT=1
    INPA_FS_MODE=1919
    [WINDOWS]
    JOB_LEFT=0
    JOB_TOP=0
    JOB_WIDTH=9600
    JOB_HEIGHT=3075
    JOB_VALUE=0
    KON_LEFT=0
    KON_TOP=0
    KON_WIDTH=6480
    KON_HEIGHT=3180
    KON_VALUE=0
    so I have absolutely no idea what I need to change in this file to get it working.
    I hope anyone here can help me.
    greetings,
    Dennis
    ps: sorry for the grammar mistakes, I'm dutch
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    Did you make the necessary path change to your computer environment variables when you installed INPA (c:\ediabas\bin) as per the ENGLISH SETUP.pdf and did you ensure that you only updated your existing INPA v3.01/EDIABAS v6.4.3 installation with v5.02 (which is only an upgrade version).
    Jul 2011
    Netherlands
    E36 325i
    yes, i did both.
    Dec 2007
    E70 3.0sd E21 323i
    Which interface are you using?
    Jul 2011
    Netherlands
    E36 325i
    STD:OBD
    also tried ADS, witch gives me the same problem.
    Dec 2007
    E70 3.0sd E21 323i
    This may be a silly question, but did you install v5.02/6.4.7 by upgrading your original v3.01/6.4.3 installation? If not, you will probably have some files missing, as v5.02/6.4.7 is only an upgrade.
    Jul 2011
    Netherlands
    E36 325i
    yes I did
    Dec 2007
    E70 3.0sd E21 323i
    What operating system are you running and have you made the appropriate changes to the LoadWIN32=* statement in Ediabas.ini (e.g. for XP, LoadWIN32=1)
    Jul 2011
    Netherlands
    E36 325i
    running XP SP3
    and yes loadwin32 is set to 1
    Dec 2007
    E70 3.0sd E21 323i
    When you start INPA are you using INPA (_.IPO)?
    Jul 2011
    Netherlands
    E36 325i
    you mean to start inpa?
    for that I just use the shortcut on my homescreen, witch leads to INPA in C:/Inpa/Bin
    or did you mean something else?
    yes i checked it, it is the .ipo
    Jul 2011
    Netherlands
    E36 325i
    no one?
    Dec 2007
    E70 3.0sd E21 323i
    If you have followed all installation instructions exactly, the only other possible causes are that you have:-
    a). Not run the hardware setup to correct registry settings as per this ENGLISH SETUP.pdf; or,
    b). Have another Ediabas suite program such as Tool32 running or have the Ediabas Server currently open in another application.
    Carei, Romania
    318is M44
    Quote Originally Posted by David Mc View Post
    Can you give me a link where can i download inpa full version?
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    INPA works fine on my 98 Z3M, but on my wife's 94 325i it says: "IFH-0006: COMMAND NOT ACCEPTED. Program will be stopped!" I re-checked env variables, and that COM1 is correct in both places. (For my S52 I chose "M52", which is correct.) For my wife's car I chose "DME 3.31 for M50 2.5 1", which is her engine. The diff seems to be which car it is plugged into. One guess is that the plug is not connecting due to corrosion (I'm using the plug in the engine compartment). Any other ideas? thanks for any responses.
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by zellamay View Post
    Pre OBD2 cars are a completely different diag system, which uses mostly the L - line diagnostic protocols. You will not be able to diagnose that car without a true ADS interface on a true serial port.
    I would use the so called "stomp test" to identify codes on that car.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Apr 2014
    UK
    1995 BMW 328
    ^ That's backwards.
    OP What people aren't telling you:
    • You can read about 80% of modules in an E36 with a Vagcom / KKL / OBDII cable and 16 pin to 20 pin adapter
    • ADS is needed for things like KOMBI (instrument cluster) and other ADS modules like ABS on my UK 328
    • A Motronic ECU like in the 94 324 can be read with an ADS interface AND mistreku.zip files (or just use flash codes / stomp test)
    • As for the L-Line stuff, most stuff is K. The difference with ADS modules IIRC is the L line flips between send and receive
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by E36328Coupe View Post
    ^ That's backwards.
    The DME is L-line on that car above, subject of the post was DME. The only reason why we use ADS interface on these older cars is for the L-line capabilities. Or else the simple usb cables (dual or single k lines) would work on all the modules if it was mostly K-line.
    Sure the airbag module and some ABS modules are K-line. Not relevant to their check engine light.
    -Abel
