I have been noticing a significant exhaust smell when the heater is turned on in the mornings and when accelerating. It seems like it is leaking into the cabin.
my saturn has a pretty big oil leak and when you turn on the heat you can smell the oil burning...
I actually have the same problem (exhaust smell, but only mild), so if anyone could help out I'd be greatful.
RISKY DEVIL RISKY DEVIL RISKY DEVIL RISKY DEVIL
Well I didn't see a question mark in that post, so I guess you're just bragging. So, uh, congratulations on your exhaust leak
www.understeer.com Your source for:
Stromung|UUC|Eurosport|Hawk|H&R|Koni|Apexcone HID|Short Shift Kits|and moreUUC Evo3 SSKs are IN STOCK - free 2-Day shipping!
Your thoroughness and attention to detail put me in awe. Do you work for the IRS?
Well a question mark in the post title would suggest I am asking if anyone has or is encountering this problem.Originally posted by bimmer95
the title would actually have to be re-phrased or instroduced with a "Why am I..." or "WTF..."
And I was wondering why your post count was so high.
Hmm, none there either. Perhaps you've been breathing exhaust fumes for too long already.Originally posted by Blazin95Red325i
Your best bet is to crawl under the car and listen for the point of the leak as this really isn't a known problem on E36s. E36 exhausts tend to stay pretty leak free.
if you have an exaust leak you will hear it, and if your ears arnt tuned enough to pinpoint an exhaust leak then stick a rag in the tailpipe and look for some smoke to pour out...since its winter now the cold weather will make it easy to spot the smoke
Well it may be that my cat/muffler has a hole?
I'll check soon, thanks
I guess I'll add my inquiry to the string. I have a high mileage '02 325i and I get what I would categorize as an underhood smell from my dash outlets when I use heat but not A/C (at least I can't smell it when the A/C is on). By underhood smell I mean that slight burnt oil / coolant smell you smell under the hood. This is definitely NOT the mold smell - I know what that smells like and this ain't it. It's not strong enough to be a leak and it's been thoroughly checked. It gets worse when I dial the little wheel toward hot (red) and lessens when I dial it toward blue. All I can think of is somehow underhood air is getting into the system from somewhere. How does that little wheel adjust temp? The filter has been changed and there are no critters in there. Any ideas???
i have the same problem with my 328is and when i floor the gas pedal and then come to a stop smoke comes out from underneath the car . i cant figure out what it is from and it looks like the smoke is coming out right before the cat? if anybody can help that would be great.
