Results 1 to 22 of 22
Thread: Where to mount Water temp sensor?
    Apr 2008
    Brooklyn, NY
    2001 BMW 330i
    I currently have an aftermarket temp sensor mounted to the head next to the factory water temp sensor. Max readings I'm getting there is 120F which has to be wrong since my oil temp is 220F at the same time on s M54B30.
    I've read that the most accurate water temp is at the head.
    Here is the location I mounted the sender. Stock on the right and aftermarket on the left.
    Should I just scrap this and move it to the upper radiator hose and use the adapter below?
    http://www.iemotorsport.com/bmw/2002...seadapter.html
    Oxford, MA
    Gt35R E36/6, S60R TI/AC.
    Yes the "most accurate" reading would be at the cylinder head. But you could (much easier) tap into the upper rad hose coming out if the head. It will give you a very accurate temp, its simple and you know your reading will be correct.
    Quote Originally Posted by ///36M View Post
    F/I is a game you play with yourself. You convince yourself that with X amount of money and Y amount of time it will most definetly result in Z.
    Two-thirds of the way through X you are one-third of your way to Z. I will keep Y out of this, because the time it usually ends up taking is laughable.
    Welcome to the fun!
    Colorado
    are a waste of money
    Get rid of the hard pipe for the TB coolant lines and put the sensor at the head. With the sensor at the TS housing if your TS gets stuck closed your screwed.
    techno550 is offline Senior Member Supporting Vendor
    Nov 2003
    Atlanta, GA
    E36's + 300D
    the temp is not accurate because there is no flow through the tee, so you are reading the temperature of the tee and not the coolant. The sensor needs to be *in* the head.
    Are there any "free" ports in the head (perhaps a throttle body heater line that is no longer in use). If not, the upper radiator hose would work reasonably well.
    Michael McCoy TRM
    Aug 2008
    Topeka, KS
    1999 M3
    I used a fitting I purchased from Mr McCoy here ^ to measure temp directly in the head flow. It has a quick response and works great. If you are ok with deleting your throttle body lines then this is a great location.
    Joe
    Oxford, MA
    i used my TB heater lines for a turbo cooling lines. lol extended the hoses and ran the coolent through the 35R
    Welcome to the fun!
    Nov 2007
    Rocky Hill CT
    1995 325TI
    I, as well as a bunch of other guys, went the route of an aluminum t-stat housing tapped for the sender. Seems to be accurate to me, I run around 205 typically when I'm cruising with a 190 t-stat.
    '03 M3. Titanium Silver/Black. Bilstein PSS10, 19" VMR 710, UUC SSK, UUC LWT clutch/flywheel, UUC catback, ///Avin Avant2.
    '95 S50 TI, bad weather beater, tow rig. 210hp210tq @ the wheels
    Apr 2008
    Brooklyn, NY
    2001 BMW 330i
    Quote Originally Posted by budget76 View Post
    I would do the same but i have a plastic housing.
    The aftermarket aluminum one is unreliable.
    Colorado
    OP, don't listen to clueless people. Put the sensor at the head.
    Richmond, VA
    e28, Spec3, M3, M3, ZHP
    I just got all the parts to mount my sensor in the cylinder head. I'll show you what I ended up with once the UPS guy shows up with my last couple parts!
    Mine is for the an m50 so I'm not sure if they'll be the same though.
    Andrew Elmore
    Vancouver, BC Canada
    No racecars...
    I had an extra port in my radiator for the stock temp sensor that I didnt need so I am using that on my LS1 build. Totally useless until the thermostat opens but all good from there and dead simple.
    Mark
    Nov 2007
    Rocky Hill CT
    1995 325TI
    Quote Originally Posted by phamine View Post
    Can you elaborate why it's unreliable? I'd like to learn something, never heard of this before.
    Jun 2005
    MI
    M Coupe
    The AL housing is perfectly reliable as long as the casting is good to start with. There are rumors of high porosity castings floating around.
    - Ian
    2000 M Coupe, stripped and DE prepped
    46mm wheel bearing socket for rent - $30 deposit + $10 fee. PM for details.
    Apr 2008
    Brooklyn, NY
    2001 BMW 330i
    http://forum.e46fanatics.com/showthr...uminum+housing
    The housing is reliable. The thermostat itself is not. On the E46, the thermostat comes with the housing. I have not read of anyone using an OEM thermostat in place of this aftermarket one.
    Again, this only applies to E46s.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I have had about 4 aluminum thermo housings. All were poorly cast. I cleaned them up with a dremel. Two did not seal to the front cover so I had to remove and seal them with gasket maker. Fresh gaskets and thermo seals were used in all cases. I no longer see any benefit to the aluminum housings. I think the plastic ones flow better because they are smoother and they seal better to the engine and they last long enough.
    Upstate, SC
    93 325is Spec3
    Quote Originally Posted by Mr Estoril View Post
    I made my own adapter for the head, but it wasn't perfect. I now have the TRM piece, which is very well made. Actually, I purchased 2 to give one to another Spec3 racer.
    Bethlehem, PA
    VW Eurovan and a 4 door 330
    1. Don't listen to everyone else as they are giving you e36 advice and you have an e46.
    2. Put it in the upper radiator hose as you are not getting an accurate reading. The water temp should be around 210 when the thermostat opens.
    3. The other option is buy an AIM dash and it'll read the water temp through the ECU (what the ECU sees). Plus you'll get a host of other items.
    4. Google "OBD II Dash". There are a few companies that make a dash that plugs right into your OBDII port. Then you can pull plenty of data off of that without having any extra gauges. Plus you can use it in other cars.
    Colorado
    Quote Originally Posted by dbgeek View Post
    I use the TRM as well. Highly recommended.
    Feb 2001
    Blue Mounds,Wi
    97 M3/4, 06 M5, 03 X5
    Sorry to dig up a post from the past, but I have the TRM unit as well and am having a difficult time finding a sender that works in the fitting. I have been trying various VDO senders but the taper in the adapter doesn't allow for any of the senders I have seen from VDO.
    I would appreciate it if anybody could post a link to a sender they are using.
    1997 BMW M3/4 Cosmos Black Luxury Package 437whp 378 ft/lbs torque Dyno Dynamics Dyno
    10 psi Stage III KO Performance Vortech supercharger,
    Piedmont, SC
    E36s/E90/T-Diesel
    Quote Originally Posted by Jim M3 View Post
    Not all sender units are built the same, what I had to do sometimes is to run a drill bit thru the adapter to make sure I get the clearance that I need to screw the sender unit all the way in.
    Use a caliper to measure the O.D. of the sender unit and find the right size drill bit, keep in mind that you need 100's of an inch to make it fit.
    Rafa,
    BMW-PC F80 M3 HotLapFormula 1000 Video │ 3 Time NASA-SE GTS2 Champ │ TRM Stg.2, Coilovers & Tuning │ Racing Videos[/CENTER]
    TN
    E92 M3, E46 325i
    I have mine in the upper rad hose. A side benefit of having it there is you immediately know if you lose your coolant because the temp drops to around 100-120 when it is measuring air temp rather than water. I lost a hose at Road Atl because of overpressurization and I was able to pull off track right when it happened. If you pull temp from the head you have to have another light for coolant pressure.
    May 2014
    Vancouver,WA
    00 Maxima SE
    Whre to put the sender unit?
    Bringing this back alive.
    Anyone has precise location where we can put the sender in the T-stat housing. I found this pic, which looks like the sender it is placed in the flow of the upper radiator hose (NOT in the direction of the thermostat opening).
    This is kind of silly questions, I guess I'm wondering what the coolant flow in and out of the engine is. Based on the pic above, the upper radiator hose would carry the "hot" coolant goes in the radiator but If I understand how the thermostat works, the thermostat sensing part is in the engine head, which in this case in the flow path of the lower radiator hose NOT the upper radiator hose. UNLESS there is an opening/by pass on the block where the hot coolant goes to the thermostat side of the housing and activates it when it reaches certain temperature and retracts the thermostat open to allow the cold coolant from the radiator to go to the engine.
    Which diagram is it?
    This
    or This
    FEEDBACK THREAD
    00-03 Nissan Maxima HID Retrofit
    6th gen AV6 FX35 Retrofit
    Chassis and Suspension
    2011 Space Grey E82 N55 DCT
    2000 Sunlit Sand Maxima SE 5Spd.
    1997 Arctic Silver E36 M3/4/5.
    1997 Techno Violet E36 M3 Coupe 5Spd (SOLD).
