Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 53
Thread: Effectiveness of Vented / Extractor Hoods?
  1. #26
    Montreal
    2002, e30 M3, 535
    Lee likes this thread. ;-)
    1969 2002 racecar + 1989 e30 M3 racecar
  2. #27
    Dec 2007
    DFW, Texas
    1997 BMW 328iS
    It is a pretty awesome thread.
    I have a question, is it better to block of the kidney grills and leave the bottom open or block the bottom and leave the kidney grills open if the radiator is being ducked though the hood?
    Christopher
    Christopher
    STX 197
    1997 328is
  3. #28
    Morgan Utah
    1995 M3
    I am going to block the kidney's and tilt the radiator as far forward and low as I can mount it, part of why going dry sump on the LS swap, to move the engine back and down as far as possible so I can duct all the air possible out the hood.
    I am searching for the right radiator, shortest one I can find, as well.
    Rick
    -1997 332ti CA edition street/track completely rebuilt in progress
    -2012 Duramax dually, Ultra high end audio, maximum sound deadening, perf, handling, custom leather.
    -2007 V8 4runner, murdered out, we love it buy might sell it instead of leaving it parked a few years.
    -2012 43' Voltage Toyhauler, not quite a race trailer but will make it work, going full time RV all over NA with it to run on all the tracks I can
  4. #29
    Norfolk va us
    Z3 Track prepped DASC
    I may be the King of dumb ideas but has anyone developed a wheel that moves air across its center, I think F1 did, or does something like that, it would seem to at least go in the right direction for air flow and reduced under car pressures. Or will simply ducting do all that can be done without creating more than is solved.
    I move a lot of air across the brakes or at least I think I do, without hoses, with openings and diverters in the front and even though I don't need cooling in the rear I am considering moving some air there also.
  5. #30
    Pittsburgh, PA
    99 M3, 98 323is
    Quote Originally Posted by albrazzi View Post
    Isn't that what the flat disk oz racing wheels did on dtm and e30's for a while?
  6. #31
    Mar 2004
    USA
    96 328is 6.0L
    Very interesting thread.
    I know it's been a while, but wouldn't the duct for the radiator be better slanting the other way around (from buttom up and intake from the bumper instead of kidneys) since the venting is on top of the hood? Or is it doesn't really matter and air passing through the radiator fins will straighten out anyway?
  7. #32
    Northern KY / Cincinnati
    e36 Track Car
    The goal is to force the air to go through the radiator and not escape around it.
    Regards, Nate.
    www.DriveFasterNow.com
  8. #33
    Feb 2009
    Mountain View, CA
    06 GTO, e36 race car
    I don't think it will matter - the flow rate through the radiator is low - 15mph at 100mph according to these guys:
    http://forums.hybridz.org/topic/5594...nel-test-data/
    http://forums.hybridz.org/index.php/...datsun-s-30-z/
    (those are two very interesting threads btw)
    When thinking about flow through a radiator, don't think about air speed or air direction or such. Think about air pressure. It's the pressure difference between the front and the rear which forces air through the cooler. The aims should be to get the pressure at the front high, the pressure at the rear low, to prevent any air from escaping around the cooler and to avoid letting air into the car without that air doing something useful (ie: cooling something that needs it).
    I was at Miller Motorsports Park last weekend. It has an utterly ginormous front straight - 131mph, despite it being 4400 ft above sea level. It's a great place to test aero drag changes. First session I went out with the lower grille blocked off and did a couple of laps. Jumped out, removed the cover then did a couple more laps. According to the GPS data it made exactly zero difference
  9. #34
    raleigh,nc
    325ci 2001, track ca
    Quote Originally Posted by flink View Post
    and your exiting through the hood? nevermind see it in picts on page 1.
  10. #35
    Morgan Utah
    1995 M3
    If we could duct the air of the radiator like the C5R and C6R Vettes it would be the best way to do this obviously and not just for cooling, free downforce, less drag, better cooling.........smaller inlet........
    If not for keeping the chassis legal for certain classes if I go W2W in the future I would move the engine way back and then could do the hood that way. I am moving it as far back and down as possible while still having a stock firewall location(I will have to get a waiver on that as we replace nearly all of it with new sheetmetal to clean things up a bit)
    Looking at different CAI units, had a Y shapped one before on one of my Vettes but had to have the MAF after it so no real space savings. The other method used commonly is a big elbow to the driver side but it would still block a huge amount of air as limits the ducting to much.
    So, I might use or make and intake over the top of the radiator, that will be laid forward as far as possible and shorter than stock height, lowered in the chassis, etc....This would take a bit more fabrication and sealing but allow the largest and most effective duct out of the radiator and over the hood.
    I have a GTP style hood and another hood with a nice center exit duct from another project I am considering molding it into the GTP hood.
    I am doing many other aero things to the car as well, E46 CSL style bumper, ducted undertray/splitter, biggest Brooks wing custom made to bring the uprights out of the fenders by the trunk lid, dual plan, huge, tunable diffuser, flushed in Lexan, vented fenders, lexan 1/4 mirrors, small CF mirrors barely poking out into the wind........
    I might also go ahead and do a ducted, directed, etc....flat bottom
  11. #36
    raleigh,nc
    you need to invest in some 5v absolute pressure gauges, around $10 each. hook them up to your gps datalogger. ive got a couple along with a 5v differential gauge.
  12. #37
    Feb 2009
    Mountain View, CA
    Quote Originally Posted by sstecker View Post
    I'm old school
    Yes, it would be nice. Also some way of measuring downforce (strain gauges, shock pots?). CFD, wind tunnel... I'm rather tired of making changes and not being able to measure or notice any effects!
    What have you been using those sensors for? Are they useful?
  13. #38
    Morgan Utah
    1995 M3
    You know you have the wrong car when you can hit 122 on the shorter straights then only 128 halfway down the main straight then like hitting a brick wall, just will not go faster. Then pull into the pits and the head instructor comes down from the tower to look over your "little SUV" because he could not believe the lap times then notices on street tires and says something like holy sheat! Also when you get sideways at 90 and made the save even though you are supposed to let it go if that far gone but your decades of dirt and snow kicked into autopilot. When you have $30k into mods, still get 28 MPG on road trips, full interior, Recarro Speeds and 3 point Schroths, no real safety gear besides long sleeve cotton shirt and long pants, helmet......and just ordered your 4th brake upgrade and 18x10.5 wheels and slicks....enough time on the long straight at MMP to figure out going faster was going to cost another $30k so you would have a $90k Forester which is pretty retarded at best, it is time to build something else.
    So I did, twice, and actually had another track car and went through a couple of others short term ones....now building a pretty nuts E36M3. I should of finished the Vette or the other car but wanted a BMW because my son loves them so much, having fun with it but it will be the most expensive car I ever finished building and the fastest.
    Rick
  14. #39
    Jul 2005
    St. Louis
    '88 e30 M3 (GTS2)
    What's the big deal.....just make some room for the air to flow up and out!
    I'm seriously considering running a NASCAR style rear spoiler. The whale tail numbers in the link piqued my interest!
    What the hell....I may just stick the bubble hatch from an old Capri and a whale tail on it and call it a day! I need some weight back there anyway.
    All kidding aside, if there were no rules (other than safety) how would you modify the aero side?
    Damon in STL
    Damon in STL
    '88 e30 M3/M42t - GTS3 #72 - Motorcraft Ign., Volvo Injectors, Thrush Turbo Muffler, Open Source ECU, Aerospace Connectors, Lowes Polycarbonate, Alumacore Front Splitter and Rear Diffuser, Honda Radiator(s), Racer's Tape (white), Tornado, Various Stickers, Farm Implement Paint (gloss white), Nationwide Series Windshield (Fontana version), GMC Boost Solenoid
    My current car: e30 M342t Evolution
  15. #40
    Feb 2009
    Mountain View, CA
    Quote Originally Posted by Damon in STL View Post
    That's NASA GTS.
    I want to bolt a couple of cessna wings to the doors. I see nothing in the rules to prevent it, but it might be a social faux pas.
    More practically: learn from the DTM cars. The 2012 rules. I doubt if anyone does more CFD and wind tunnel work on production body shapes than those guys.
  16. #41
    Jul 2005
    St. Louis
    '88 e30 M3 (GTS2)
    That's NASA GTS.
    Go for it! Wait that's Chump Car or Lemons.......
    DTM is very secretive other than what you can see. Have searched and searched and uh searched.....
    So, what is wrong with NASA GTS? There is absoultely nothing wrong with using your brains instead of your wallet.
    Damon in STL
    Damon in STL
  17. #42
    Apr 2008
    Ft. Lauderdale
    06 MINI Cooper S
    JongBloed wheels are designed to flow air across the brakes and be more aero effiecient. that is their claim. your results may vary.....
  18. #43
    Feb 2009
    Mountain View, CA
    http://blog.caranddriver.com/lemons-...r-honda-civic/
    Easy! http://www.sportscardigest.com/car-p...-benz-clk-dtm/
    I like GTS, although I do wish they'd drop the "g" and consolidate it with STx and perhaps PTx. But I hate with a passion making changes and being unable to measure their effect!
    Quote Originally Posted by beaner06 View Post
    Yes, there are some wheels which are also fans/turbines and I expect they'd help cool the brakes and possibly increase downforce. I've seen some on production cars, but they're the same on all four wheels, so two of them blow in the wrong direction!
    I once came across a patent on exactly this concept, presumably not enforced...
  19. #44
    LA, CA
    E46 M3, ITR
    A proper vented/ducted hood makes a difference. My setup is fully ducted intercooler/rad/hood and you can see the "heat haze" exiting the hood. Of course I only notice the haze when I'm on my cool down lap.
    Our kidney grilles are blocked off, with the kidney grilles open we saw loss in cooling efficiency due to disrupted airflow.
    My Time Attack build:
    http://forums.bimmerforums.com/forum....php?t=1799131
    Thanks to: Okada Projects, JRZ Suspension, ESS Tuning, Klassen Wheels, Project Mu, AEM.
  20. #45
    raleigh,nc
    you need to do differentials ie test on both sides of radiator at same time. with kidneys open, the air from bottom duct may be exiting the kidneys. with the headlight opening you could be pressurizing the engine bay. without fender liners you may be pressurizing the engine bay. without a gurney lip on the leading edge of your hood exits, you may have air entering the hood instead of exiting (check 2013 dtm). check how tonester tapes all the edges, leading edges of exits, etc.
    exits on 2013 dtm
  21. #46
    Chicago
    E36 325i, E34 535iTm
    If only we knew of a car maker who thought of this 20+ years ago ...
    -tammer
  22. #47
    Oct 2007
    sterling hts, michigan
    02 M3
    Any body else experiment with this? Looking to add additional cooling under the hood, especially exhaust side.
  23. #48
    Jul 2003
    Tempe, AZ
    95' M3, 98' M3/4
    Quote Originally Posted by Inflame View Post
    What part?
    We have talked about venting at the center section of the hood right behind the radiator and seen reduced coolant temps with increased front end grip. Blocking off the front bumper inlets to reduce drag on time attack cars. Venting like the GTR hood with vents on the side but those are just general engine bay cooling if the air flow in the engine bay is playing nice.
    Buying wheels because they could cool your brakes are cool if you are trying to get the most of out a limited brake system but most of the time ducting from the front bumper works best for the price.
  24. #49
    Aug 2008
    St. Louis, MO.
    e36 332i
    Wrap headers with header wrap or get them ceramic coated to try to keep the heat in the exhaust and not in the engine bay. Venting the hood helps in numerous ways. Lets out heat, lowers pressure of engine bay for better cooling (radiator) and better front end grip.
    I wrapped my headers and it made a huge difference.
  25. #50
    Reston, VA
    SpecE46, 99LS/M3, 07GMC
    Quote Originally Posted by eye145 View Post
    +1, even on my stock headers I wrapped them. Underhood temperatures went from "pop the hood after a race and hot air to the face" to "pop the hood and wasn't hot till you got really close to the engine". My hood vent goes in this week.
