Page 4 of 6 FirstFirst 123456 LastLast
Results 76 to 100 of 128
Thread: Honolulu auto parts and services compendium
  1. #76
    Dec 2007
    Kailua, Oahu HI
    1982 Mercedes
    Quote Originally Posted by The Beastmaster View Post
    From the stealer. Probably under $20.
    Last time I checked they wanted more than $50.00.
  2. #77
    Dec 2011
    Ewa Beach, HI
    03 M3 Convertable
    Yup, jus picked it up $52!!! What a scam, it's just plastic.
    Sent from my iPhone using BF.com
  3. #78
    Mar 2001
    STR, MUC, LHR
    I love turbos!
    Quote Originally Posted by bmemac View Post
    For a Roundel? They're nuts!
  4. #79
    ajitaw is offline Why would you want a BMW?
    Sep 2008
    Kailua, HI
    1990 BMW 325is
    Hawaii Import for both my roundels... $25-27 front-rear... just as cheap as anyone online and good quality. Just make sure you look at them before you leave. I had to go through 3 before I found one without defects/damage.
  5. #80
    Honolulu, HI
    2001 BMW 325ci
    Quote Originally Posted by ajitaw View Post
    Yeah they're surprisingly priced well, I got oem wipers for $20 off what dealer wants!
  6. #81
    Dec 2008
    Haleiwa, HI
    E60 M5 | Ducati M796
    Does anyone on island do SMG coding? I really could use a Euro SMG flash
    E60 ///M5 | 2012 Ducati Monster 796 | E92 335i Retired
    ///team BMW hawaii
    "If everything seems under control, you're not going fast enough"
    -Mario Andretti
  7. #82
    Honolulu, HI
    2001 BMW 325ci
    Quote Originally Posted by Shieldze1025 View Post
    Did A&A do anything?
  8. #83
    Mar 2012
    Kailua, HI
    2008 128i Convertiable
    Windward Side
    Tenn's Automotive
    263-1076
    Awesome, Honest, and does not charge more for BMW's and has all tools and electronics.
  9. #84
    Mar 2012
    Kailua, HI
    TnT tinting is the best!
    Joe
  10. #85
    Jul 2013
    Honolulu
    1998 740iL
    Purchasing a 1998 740iL, current owner reports that the ABS light is on and the speedometer
    does not work. I suspect the wheel speed sensors, but it may be the ABS module, and it
    may be both. Which of the shops are recommended specifically for diagnostics and electrical
    work? Should I inspect/repair/replace the speed sensors myself, hoping it is one of them, and
    then do an ABS module rebuild if that doesn't work? Or should I pay for BMW diagnostics?
    My shop in Kailua, Clyde's, said they don't have the diagnostic equipment to help; claim that
    it is special BMW diagnostic equipment, which knows the codes. Also, even if you get the ABS
    and speedometer repaired on your own, how does one remove a persistent error code that is
    a legacy and no longer correct?
  11. #86
    Honolulu, HI
    2001 BMW 325ci
    I need tint removed quick and cheap lol, where should I go? Thanks guys!
  12. #87
    Mar 2001
    STR, MUC, LHR
    I love turbos!
    Quote Originally Posted by Connor92 View Post
    I did it myself. Strip the tint, spray goo gone on the adhesive, wait a few minutes and use a razor blade to scrape it off. For defroster lines, you can use a plastic scraper instead of a razor, but be careful. Just wait longer for the goo gone to work in.
  13. #88
    Honolulu, HI
    2001 BMW 325ci
    I'm scared to scratch my windows lol, maybe someone can help me? Thanks in advance
  14. #89
    Mar 2013
    Mililani
    2006 M3 and 2010 X5M
    Connor, you won't scratch the glass with a razor as long as you are careful. Used razors to remove stickers in glass many times and never once scratched the glass.
  15. #90
    Honolulu, HI
    2001 BMW 325ci
    Any recommendations for an ac shop? I need a recharge and see if there's a leak in my ac system
  16. #91
    Sep 2003
    in front of you
    E36 M3
    rennwerks recommended A-1 auto for me in the past, and i've been happy with the service there...shop is in mapunapuna, the guy's name is mau...much cheaper than i expected...will definitely go back if i ever need a/c service...
    big chad + drunk wimmenz = FTMFW
    jarod + sterling + tom = ROFL
  17. #92
    Honolulu, HI
    2001 BMW 325ci
    Quote Originally Posted by poser View Post
    Thanks! Will check them out
  18. #93
    Oct 2013
    Bellevue, WA
    E70 X5 XDrive3.5i
    Who should I go to to look at my fuel filter/line for my E39 ??? Should I just install myself or is a shop a better idea? I have worked on Audi and GMC before.
  19. #94
    Aug 2013
    Honolulu
    e82
    Can anyone recommend someone that can fix a curb'ed alloy wheel? I tried yelp but nothing comes up.
  20. #95
    Mar 2001
    STR, MUC, LHR
    I love turbos!
    Alloy Wheel Repair Specialists http://rimrepairhawaii.com/index.htm
  21. #96
    Aug 2013
    Honolulu
    e82
    Thanks, I'll give them a call!
  22. #97
    Feb 2012
    Honolulu, HI
    2011 Space Gray E90
    Quote Originally Posted by worries View Post
    Try ask the dealership who they use, it's some guy that does it in a truck or something. I made them sandblast and re-finish all 4 wheels on my e90 CPO I just picked up
    The guy did a sick job!
  23. #98
    Aug 2013
    Honolulu
    e82
    Quote Originally Posted by anti808 View Post
    I actually went through an old friend of mine that does rim repair. His business is called Rimcraft, and they mostly work on dealer cars(pre-owned), but also do on location personal vehicles as well. It took about 1.5 hours, and he was able to completely restore my badly curbed wheel. In fact, I can't even find the spot that was damaged. If anyone is interested, PM for a contact - I don't have his business number off hand, just his personal number.
  24. #99
    Feb 2012
    Honolulu, HI
    2011 Space Gray E90
    Sounds like that might be the dude that does it for bmwhawaii. He does SICK work.
  25. #100
    Feb 2012
    Honolulu, HI
    2011 Space Gray E90
    Anyone on oahu do coding?
