- LCM + INPA diagnostics
Hello, I have a couple of questions on those two..or three
I just got my inpa usb cable and got some engine troubles..
I guess my ICV is going mad? Or I get some air from some where else?
Plus that in the engine roughness option I have some troubles with cylinder number 4 and 5, on idle it shows +300 and +1100.
The next question would be can I code LCM with NCS?
INPA does not see LCM module at all, I don't have any indications on my cluster, no errors if the bulb dies, and of course no reverse lights. NSC will help or do I need DIS or something else?
Almost forgot, m52b25 e39
Hi
How do you solved ?
What was the problem ?
Thank"s in advance
Brs
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
