Made them round as original end, do not try to finish with the rounded bit, just come close and do by hand with a micro file (remember I had door panels more than a year out so taking time is important factor).
Funny regarding mirror switch ilumination, so far nobody is asking but I listed it on my first picture post, lol, compliments on your good observation this is one of the very rare if not the only piece done this way, which I'm sure because I did only 1.
MParallel, now when I look again at your inner door handle pictures, think I found out the main detail, you used a WRONG (side) angle of the led strips to iluminate the handle, probably because of the fitment issue.
I don't blame you because there is very little space in there, almost no space. The trick was how to make that very little space usable and mount them good.
"his is one of the very rare if not the only piece done this way"
Done what way? Any close-ups?
What do you mean I used the wrong side? Yes I know I turned mine 90 degrees as I chose to have the part where the let sticks in point upwards, not inwards like yours.
I tested different positions and for light output, it didn't matter at all. I even testen with a piece of alu foil on top to reflect more light down, but it didn't matter.
The only thing that is a limiting factor is the width of the slit I made. I couldn't go wide as the side of the plastic is thinner.
Totally flat wasn't possible and the way you did it, I considered that position, but I thought I could never cut the hole that way to allow so.
And I am very impatient...
But there is still enough light put out to light up the handle in the dark.
I'm curious how you mounted the holder for the bulb for the outside handle.
I was surprised to find out the system uses a normal bulb and not a led, which would be much better and you will never have to replace that one as it will outlast the car.
Shouldn't be too hard to change from bulb to led. Still puts out more than enough light in the fiber optic wire.
We need to do this:
Parts are simple and cheap. It's a cover which you can see on the door, with a lightstrip underneath that gets lit up by a single amber bulb.
(Black color cover)
51419139641 - $30 F/L
51419139642 - $30 F/R
51439139837 - $26 R/L
51439139838 - $26 R/R
4x 63319122419 - $10 (bulb thing)
Transparent lightstrips.
63316958347 - $7
63316958348 - $7
63316958349 -$11
63316958350 - $11
With some imagination, you could put such a strip (shorten it) in different places. Like under the front seats, or maybe even at the rear of the hardtop, above the window.
I hope OP (Joylove) will welcome all our replies in this thread as a contribution and sharing ideas to his project and will not feel as we are hijacking his OP.
The possibilities and combinations are endless it is just how much you want to do and knowing when to stop.
I looked into E9* series door ilumination and personally did not like it, the strips reminded me of those purple neon lights on the outside underbody of some bling-bling flashy cars (not clear yet on how the new F30 series have this detail revised or left the same).
Maybe it is more cost effective for BMW to do it this way by not having individual door handle light and door pocket light, just one long strip that will iluminate the whole area, even where you don't need it.
Are there separate door pocket lights on these E9* series? because in that picture it looks like dark into pocket area where it should be light.
I did also take a different approach on the rest of interior ilumination mods and ambiant lights, but will leave it here for now, planing of making a new thread soon with general info about my E36 M3.
Not a problem with me, I'm chipping in here and there and it's nice to see so many ideas and mods and improvements and photos of what's been done all in one thread for future visitors to the site.
I have a connector on my harness for an additional illumination circuit, originally for door pockets, but have yet to hook anything up to them. I don't think I ever will because I can't find a position for the light source that I like without ripping the pockets from the door card to access the edge the driver cannot see for drilling into.
E36 DICE MediaBridge BT and iPod support Photo location of the cabrio drain holes. Custom heated seats and lumbar support retrofit. Glovebox charging sockets and cupholders. E36 PDF Schematics UK Aftermarket E36 OBC bulbs Convert rear lights from non check-control to check-control DIY BMW E36 MFSW retrofit pictoral DIY All BMWs UK cheaper source for electrical connectors, Farnell, RS BMW INPA success E46/E39 onwards E36 vert mood lighting DIY BMW E36 puddle light and inner handle illumination DIY. E36 convertible flat bungee tension strap fix DIY BMW E36 PDF manualBMW E36 vert water in motor of tonneau area fix.
Yes there are! The door light strip is additional to the door handle and pocket illuminations.
Looking forward to your topic. I always like new ideas, even for inspiration. The back in my convertible is so dark, apart from the hardtop lights. Been looking to see how I can nicely fit some amber moodlights in there.
The E38 rear lights have some sweet double amber led moodlights on them, but this unit is only available in wood and 3x the size of ours, so can't be used.
Any idea is welcome.
Must be home brewn as the E36 never had pocket lights.
Yep I didn't explain that very well, my added-in harness has socketry for door pocket and exterior handle illumination if I ever go there.Mine too, and I don't have the hard top either.
I was thinking lights either in the rear of the seat back at nipple level, which I din't really like the idea of because the seat back isn't really flat and I don't like the idea of looking directly at a light source;
Or underneath the front seat to light the rear footwells, when the seat is tilted forward to let people in then the light puddle would get bigger;
Or the idea I liked best was some sort of round lens lamp at the top seatbelt mounts pointed at the laps of the rear passengers.
Bumping this... I am hopping to achieve this look soon. I have my interior stripped at the moment and its a perfect time to tackle this.
Whats a good place to get the amber led bulbs for the handles?
eBay.
Wow... I could have figured that much out... Im asking for more info than that. Im not some newb asking the obvious. If you dont care to help someone out then say so.
Considering I wrote this guide, gave you the size & the wavelength in the first post, and answered your specific question, how exactly am I being unhelpful?
Basically asking what vender/ seller you might have bought from for quality and price. I dont know about you but there's not just 1 shade of amber. Id like it to match all the oem lighting in the car if I can
The wavelength defines the colour. 400nm is violet, 700nm is red.
Anywhere between 590 and 610 nm should do.
I just searched for amber, orange leads, sort by lowest price, shipped from china with 10 matching resistors. The advert is long since dead, it was about two years ago.
It was about £1.50 if memory serves for 10 LEDs and resistors.
Soft orange, 607 nm, from OSRAM or Vishay/Telefunken. Try www.digikey.com in the U.S.: they carry both OSRAM and Vishay LEDs.
Awesome that's what I needed thanks guys
Ok went to the website new question.. What size resistors do I need for the lights?
It depends on what LED you use and how bright you want it.
My preference is to choose a resistor that produces a current that won't exceed the LED's maximum rating at the maximum expected voltage, say, 24V for a few minutes.
For a 20 ma. max, orange LED that would be something like: (24V - 3V) / 0.02 mA = 1050 ohms. You can likely get away with a lower value resistor (and people do), but I prefer, as cheap insurance, to be more conservative and buy brighter LEDs and run them at derated currents.
At the other end, you may find some LEDs in a batch are brighter than others if you run them at too low a current, their "grouping current". In this example, that might be 1/4 the maximum allowed current or 5 ma. OSRAM shows the grouping current on an LED's datasheet – along with its pulse capability, if you want to go whole hog and sweat all the details.
Agree with all of the above, but most eBay LEDs come with 10 resistors. Have you looked at the price and minimum order quantity of loose resistors at Farnell? It's about £10 to change value from those supplied.
I picked these up from the website you provided:
http://search.digikey.com/us/en/prod...480-ND/2163743
You guys are crazy light guys. This is fairly new to me. So sorry if they seem like im asking the obvious. My friend will be the one doing most of the work. So Im going to relay the info.
Project starts tomorrow... I bought 50 LED's and plan on using a lot.
I wonder if I should do the nigh time star headliner like the Bentley's... lol JK
Only if you can make your orange stars twinkle.
This is probably the easiest think I have done on my car. So far I have the mood lights under the mirror, door handles, cup holders, and door pockets. I think I will add 2 under the dash on each side to light the floor and maybe 2 under the seats to light the rear floor. I dont wanna go overboard and defeat the whole purpose of the clean look. I think that is all I am going to do.
Any suggestions?
To the OP and others here, for more pictures of my car please see teh link:
http://forums.bimmerforums.com/forum....php?t=1838930
I'm sure you will enjoy, thanks.
Hats off sir. Power shade and working memory seats? That's epic.
I would like to do install LED lights to interior door handles, but it's not clear as to which cables you tapped into for power. Can someone clarify? I'd prefer the lights to turn on with simultaneously with gauges. Thanks in advance
