This power steering pump is installed on E32 730 V8 and E32 740 V8 as well as E34 540 V8 and the EURO 530 V8, all with the M60 engine. Also used in E31 840 and in E38
While I found sources for the ZF power steering pump for the E32 735, E34 535 and E32 750 on the net and repaired my pump quite easy, I am looking for a source for the LUK pumps, model type is LFR 68. That pump delivers 130 Bar.
LUK parts number is 2106385, BMW 1091911,also Bmw-Nr:1140902 130 bar LFR 68 2105974
and Vickers
Example E34 540/530 M60:
For vehicles with Self-levelling suspension AT-TANDEM VANE PUMP VICKERS 32411141574, LUK Power Steering Pump 975012 32411141574
even ZF is used:
5' E34 540i HYDRO STEERING-SERVOTRONIC Rmfd hydro steering gear ZF 32131141483
Rmfd power steering pump 32411141570, Luk 32411141570, Cross References:32411141569, W0133-1598557 (?)
E32 740/730 M60
AT-TANDEM VANE PUMP VICKERS 32411140908. Part #: LUK-5410046100 LuK 541 0046 10 (?)
E31 840i/Ci
01 AT-VANE PUMP 32411141568 = LuK LF 68 130 bar
Trying since a long time to allocate a supplier but so far no success. Anybody knows a source?
Once in a while, Luk rebuilds come up on eBay for cheap. I paid $125 for a rebuilt one with the Luk Service tag on it. I searched for several different part numbers used on E34s and E32s and eventually found a few.
got a hint from whiskychaser: quote - LUK PS pump parts : The only parts I could find are seal kits as per this catalogue: http://srtp.us/yahoo_site_admin/asse....140132939.pdf
I imagine Schaeffler want to protect their refurb plant in D59423 Unna so you can only get a Luk pump on an exchange basis here. I couldnt even find seals in the UK so doubt you could get hold of hard parts. I know you have been trying to sort this for a while so spent some time on it. Sorry I couldnt get a better result - unquote
#1 shaft seal
#2 O-Ring
#3 O-Ring
#4 O-Ring
#5 O-Ring
#6 O-Ring
= complete seal kit (OEM #'s 515775, 0515775) , contents item #'s 1 thru 6, SRTP part number 8819
Note: no other parts are available for "LUK" series pumps. If additional parts are needed, it will be necessary to order a remanufactured or new pump. Call (281) 386 7229
with number stamped/stenciled on pump.
SRTP, Inc.
Steering Rebuilders & Truck Parts, Inc.,764 CR 383, Cleveland, Texas 77327, Ph #: 281.386.7229 Fax # 281.432.1332, web: www.srtp.us "new and remanufactured LUK pumps" "LF" and "VT" Series
I am still looking for a power steering pump repair kit for the M60. No rebuilt pumps, just a seal kit, same like the one which is available for the ZF 19mm shaft pump, the ZF kit looks like this
http://www.bimmerboard.com/members/mino/DSC07238.JPG
Just need a source where to buy. Or has someone a spare LUK pump and can disassemble it and make pics and take dimensions?
Update: Maybe that is a complete kit http://www.srtp.us/yahoo_site_admin/...214742_std.jpg from here http://www.srtp.us/steering_seal_kits__parts
Last edited by shogun; 01-16-2016 at 07:22 PM. Reason: info collected so far merged
Have you tried searching for the individual seals and such? Much of it could be industry standard items. Gaskets could be fabricated.
Just a follow up, if anyone did a repair and has a source or can make a kit available, there is much demand.
Edit: just found this 32411137707 https://www.ecstuning.com/ES54579/
BMW Gasket Set Vane Pump (Vickers-Luk) - Genuine BMW 32411137707 https://www.fcpeuro.com/products/bmw...uk-32411137707
The strange thing it shows M30 engine for the E32 http://www.etk.cc/bmw/DE/parts/fullA...ce/32411137707
Fellow Forum Members,
I have developed a DIY Repair Kit for the LUK, LF-20, LF-30, PSP's (Power Steering Pumps). I also sell a gasket kit for the LF-68
Here is my link to my 17 Websites on Big Coupe, as links do not work on BF. Look under Useful Links, then # 3. Then read the directions in RED to view the written captions for each photo. See # 9. Link : http://bigcoupe.com/phpBB3/viewtopic.php?f=24&t=28245
Here is a link to the PSP - Tandem, on the e60, e61; e63, e64; e65, e66 See # 13 LINK : https://www.bimmerforums.com/forum/s...rrent-websites
Best,
Jay
'88 M6 Cinnabar Red / Nappa Natur Highline Interior (10-87) Santa Ana, California. USA
My NEW Website, Link : https://www.jaysbmwparts.com
Booster repair
A/C Wingcell Compressor leak repair
e31 Door Handle Fix,
Jay, nothing is mentioned in your write up about E32 M60 pumps??
"BMW PSP (power steering pump) LUK (LF-30) e36, e38, e39, e46 - DIY LEAK Repair Kit, Added LUK (LF-20), Added LUK (LF-68) Jun 28, 2015–Oct 15, 2017"
I do not have an E32 740 therefore I do not know the exact model type of the maker LuK? The above info in my first post I found with google search. On Ebay I now found one offered for E32 740 and the name tag says LuK Fahrzeug Hydraulik, 6380 Bad Homburg
Model VTP68, LuK no. 02-105974, pressure 130 bar, date 12C93, customer no. 1 140 902,
offered as: BMW E32 730 730I 730IL 740 740I 740IL M60 OEM POWER STEERING AT TANDEM VANE PUMP, Manufacturer Part Number: 32411140908, superseded Part Number: 32411140902, 32411140901 removed from a 1994 E32 740i.
http://www.realoem.com/bmw/enUS/partxref?q=32411140908
realoem again says it is Vickers: AT-TANDEM VANE PUMP VICKERS 32411140908
A bit confusing
E38 has a different pump, for example: E38 740i 740iL 95-01 Power Steering Pump OEM LUK - 32 41 1 092 015
@shogun Did you end up using any of these kits? Any good? Im rebuilding a LUK LF68 for my E31 https://www.realoem.com/bmw/enUS/par...&q=32411141568 and Im working on sourcing a kit.
Buildit,
If you look at the post above were I stopped selling as there was not enough interest, well another client asked me pretty please so I am selling them again.
USA is $45.00 + $4.50 mail = $49.50
International mail is $45.00 + $17.00 mail + PayPal Int fee 5% = $65.10 USD
Jay
Booster repair
e-mail me please jay_c_stratton@hotmail.com
Jay
Booster repair
