Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Thread: HELP Intake gaskets and injector swap gone bad, engine hydrolocked
  1. #26
    Jacksonville,fl
    Imola740i, turbo eclipse
    Should all be the same. M62.
  2. #27
    Dec 2009
    Dallas,TX
    '98 E38 740IL, '01 740i
    Man that blows, I loved your car man, just replace the motor and have some with it.
    TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
    BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
    WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
  3. #28
    Studio City, Ca. USA
    2001 740i
    Bimmernutz,
    What did you search to find all those motors? I am looking for a m62tu for my 2001 740i. I live in Northridge 91325 a suburb of Los Angeles. Could you help me out and do a search for me?
    Nov 2010
    Toronto, ON, Canada
    2001 BMW 740i Sport
    Quote Originally Posted by 01sport View Post
    Bimmernutz,
    Looks like that info is off the car-part.com
  5. #30
    Indiana
    95 m3 95 740i
    Bimmernutz,
    Quote Originally Posted by E38740 View Post
    He is right i tagged the info on car-part.com..I tried to pm you however I guess I dont have enough posts as of yet?. I had another acct it had been ages since I used it and I no longer had my old email acct to reset it..
  6. #31
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    Did you try to take the plugs out, crank it see if it dries out and then try again?
    Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
  7. #32
    Nov 2009
    boston
    96 740il;
    Quote Originally Posted by Edwin NL
    Yes, there was no gas in plugs, i took them out 10 hours after this happen, so possible the gas dried out by then. I am looking at 2 motors this week 1 with 99k another with 115k. I am swapping my waterpump, starter and intake manifold on the motor. Also doing rear coolant gasket, rear crankshaft seal, valve cover and timin cover gaskets, oil pan gasket;motor mounts; else should i change while the motor is out?
    Got a new set of boch4 injectors from my mechanics ls1 camaro(too scared to put other set on) he offered to sell me ls1 motor for 1200$ with 60k miles...but unfortunately i need this car back on the road in 1 month max. Plus my budget is 2,5k max. and I dont know anyone who is capable of doin this swap
    96 bmw 740il / M-pars/ bilstein shocks & Rd springs/ 750 brakes/ alpina lip / clear corners, sidemarkers and oem taillights/ ACS roof wing /M-pedals/ facelift grills and headlight bezels /Bi-Xenon/ umnitza Orion V2 angel eyes /HID low beams and fogs/ double pane windows / navigation & tv tuner / 750 all-leather black interior / floor lights/oem wood steering wheel/pornlights /wood b-pillars / wood maplight & seatbacks / window shades, black alcantra headliner/ 750 heated seats & power heated rear seat / gloss trim / lighted interior door handles/ HKS Intake / high flow cats/E60 M5 mufflers
  8. #33
    Australia
    96 - 7 3 5 i L
    I certainly feel sorry for you! If I were in your shoes I'd just replace the engine. If you're a little unsure, just go and take a Corolla for a test drive for a few minutes (you'll realise the right choice within a few second of doing that).
    I cannot believe how cheap replacement engines are in the USA! I've been casually looking for a 4.4 M62TU to replace my 3.4 M62 for months and haven't found a thing under $3000-4000 here in Australia.
    You have my sympathy none-the-less!
    Just in case you start getting desperate, don't touch the LS1. They're nasty and BMWs are allergic to them. Besides, if you really wanted that sort of hassle you should just yourself a favour and put an S62 in instead.
  9. #34
    Nov 2009
    boston
    96 740il;
    UPDATE: New motor found with 85k miles (pretty good considering my old one had 195k)
    Hopefully will be driving again within 2 weeks
  10. #35
    Dec 2009
    Dallas,TX
    Awesome, that is excellent news! Your car is too nice to be sittin'.
    What year is the motor from?
  11. #36
    Feb 2010
    Newburyport ma
    88,m5 95 740 04 XI E90
    It was definitely a hydro lock problem. I've seen it many times with flood cars. The rod bends just a little and there is no room for the bent rod and it punches a hole in the block. The hole is usually right near the starter just like yours. The other option is something fell into the cylinder and jammed the piston bending the rod. Pull the head off of the old engine and see if there is something in there or signs of that. Always good to know the culprit before petting the new engine in.
  12. #37
    Nov 2009
    boston
    96 740il;
    Thanks, I am very happy with the motor so far, its late 97 build date, but it says 98 on carfax, 2 owners, valve cover gasket appear to be done already, and looks so much better than mine. I am not gonna put vanos injectors on it, dont really wanna risk anything plus the injectors look brand new on the motor.The motor even came with complete wiring harness relays and engine cover!
    Update: finally got her back last night with new motor and lots of maintenance done.Man its amazing to be driving again....
    FYI the new motor(from 98) was completly different: the harnes was different, the fuel rail was different(no fuel pressure regulator) AC Mount and half of the sensors. It was not a fun job for my mechanic who had to take the harness off 3 times...
    I just need to get rid of exhaust leak where the headers connect to exhaust and she is back to perfect .
