Results 1 to 8 of 8
Thread: Coupe Rear Quarter Panel Window Replacement Motor. DIY Needed
    Wake Forest, NC
    2009 BMW 335i
    I have searched and searched for this. Dane came up with a couple of DIY but unfortunately they were for the adjustment of the windows not the actual motor replacements.
    Does anyone have a good source for a DIY or if you have a Bentley Manual can you tell me if there is a section in there for the Coupe Window Motor Replacement since mine is loaned out at the moment.
    Phil
    Nov 2010
    Sweden
    320ciE46,325iE92,520dE61
    sorry I canŽt help but it would be a good 1 to know as mine are quite noisy and maybe IŽll need to do this soon (I hope not!!!)
    May 2010
    Lexington, KY
    2005 325i Silbergrau 5sp
    Hi, Phil, yes there is a section on 2-door window alignment in the Bentley. There is also a "close with door shut" feature explanation, as well as a motor replacement page or 2.
    "you vill haf goose pimples" Meyle HD CABS, sock mod, and new hoses, pulleys, belts and water pump.
    Weisslicht LED AEs from JleviSW that came in a Khoalty-looking box.
    Nov 2010
    Sweden
    Oli mate I think the OP was asking about the rear window motors not alignment
    May 2010
    Lexington, KY
    Right Tymm, I told him the different sections present in the Bentley manual, specifically addressing the 2 door model.
    May 2010
    Lexington, KY
    My bad, sorry, OP did not see the rear quarter panel (not door) in the title. So there is a window that goes up and down in the rear quarter panel on a 2 door coupe?
    I'll look in my Bentley again tonight..
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    It "pops" out the window on the Coupe, the verts drop into the body. I know that you have to remove the plastic covering that is at the top of the side bolster in the rear seat to get access to the motor. I haven't need to replace mine, just took it off for the tinting of my rear window and saw the motor in there.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Wake Forest, NC
    2009 BMW 335i
    Quote Originally Posted by dworthy
    This is that I am nor sure of how to so take the plastic off on the backseat to get to the motor I know there Is a little pin at the top but that's it
