Results 1 to 19 of 19
Thread: How do I retrieve SA code from car?
    Aug 2008
    Charlotte, NC
    E38, BNR32, E36, B5S4
    Looking to retrieve the SA option number from my car, how do I access that code? Also, how do I reprogram the new SA code back in?
    2001 BMW 750iL Black on Black fully loaded
    1997 BMW M3/4/6 - Awaiting turbo
    2001 Audi S4 - VR6 turbo swap in progress
    2016 ZX14R
    1993 R32 GTR V-Spec
    Germany
    93 e30 327i / 95 e34 540
    what car exactly?
    Aug 2008
    Charlotte, NC
    E36, need to code out the auto trans package to be exact.
    2016 ZX14R
    1993 R32 GTR V-Spec
    IcemanBHE's Avatar
    IcemanBHE is offline ¿pǝpɹɐʇǝɹ noʎ ǝɹɐ
    Wichita,KS/FortCollins,CO
    (4x7)+8=36
    Well..for one...it should be on the fusebox cover....
    Second...if you load NCS and find your car...it will retrieve the GM and SA code.
    Philadelphia, PA
    2005 M3 & 2004 330i
    Load the ZCS with NCS Expert, then enter the SA code into one of the decoders to determine what the actual options are
    Aug 2008
    Charlotte, NC
    So if I want.to code out the automatic option, what modules do I program?
    2016 ZX14R
    1993 R32 GTR V-Spec
    Philadelphia, PA
    2005 M3 & 2004 330i
    You would probably have to:
    1. Edit the ZCS (note in some cars, you have to change both the GM and the SA strings to remove the auto option)
    2. Write the new ZCS to the module(s) that store that information using the ZCS_SCHRIEBEN function
    3. Recode a few modules (I'd recode everything to be safe)
    4. And most importantly: Reflash the DME with the manual software (you'll have to look the software number up and input it manually)
    Aug 2008
    Charlotte, NC
    And I can do all of this with ncs expert? Where can I get a manual software number?
    2016 ZX14R
    1993 R32 GTR V-Spec
    Philadelphia, PA
    2005 M3 & 2004 330i
    First 3 steps you can do in NCS Expert. DME programming needs to be done with WinKFP.
    You can lookup the manual software number at bmwfans.info. Look up an M3 with the same build date as yours, but select the manual transmission option. Then in the part number lookup, go to "engine electrical system" and then go to "Control Unit DME, programmed." The last 7 digits of the DME part number is the software number. You would enter those last 7 digits as the "ZB Number" in WinKFP
    Aug 2008
    Charlotte, NC
    I can use realoem right?
    2016 ZX14R
    1993 R32 GTR V-Spec
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by Smitherines View Post
    RealOEM doesn't have the programmed versions listed. At least it doesn't for the E46. I never checked for the E36.
    Aug 2008
    Charlotte, NC
    When in ncs expert, and it asks me for the CBD name.of the DME, what do I enter?
    2016 ZX14R
    1993 R32 GTR V-Spec
    Philadelphia, PA
    2005 M3 & 2004 330i
    Pic? I've never seen NCS expert ask for anything like that
    Aug 2008
    Charlotte, NC
    Quote Originally Posted by TerraPhantm View Post
    Work with me, it's upside down, but you'll get the idea, tell me what I'm doing wrong.
    2016 ZX14R
    1993 R32 GTR V-Spec
    Philadelphia, PA
    2005 M3 & 2004 330i
    Oh okay, I see what you did.
    After loading expertmode, hit the "VIN/ZCS/FA" button, and then hit "ZCS/FA f. ECU" - pick E36 as the chasis. It'll pop up with a list of modules you can read the ZCS from. (Or maybe there's only one module for the E36, idk). Pick one, and it'll read the data off your car. Now that you loaded your car's data, you can modify things. To modify the ZCS, hit "Enter ZCS". Keep the VIN as is. Then change the GM, SA, and VN strings with whatever you need to change them to. If your calculator doesn't calculate checksums, remove the last digit from *all* of the strings, even if you didn't change them, and let NCS recalculate the checksums.
    Once you've got the desired ZCS, hit "back". Go to "process ECU" - pick whichever module you read the ZCS from initially. Change the job type to "ZCS_SCHRIEBEN" and execute the job. Now click on "SG/SGET" and pick the other ECU that stores the ZCS (if there is one). Do the same ZCS_SCHRIEBEN job. Now go back and hit "process car". Every module will be recoded to the defaults for the new ZCS.
    Aug 2008
    Charlotte, NC
    I'm quick.....
    Take a look at that. It's looking for a file that doesn't exist in that folder. Can you hook me up with that file?
    Thanks!
    And do I have to edit the GM and VN numbers for my situation? What do they do?
    2016 ZX14R
    1993 R32 GTR V-Spec
    Philadelphia, PA
    2005 M3 & 2004 330i
    Hmm, looks like your NCS Expert install is incomplete... which version of INPA/EDIABAS did you install? You should install EDIABAS 6.4.3/INPA 3.0.1
    I would send you the daten files, but I have a feeling you installed EDIABAS 6.4.7/INPA 5.0.1, which is missing a ton of files.
    Look for ediabas-6.4.3-full.nrg in the 4shared site. When you get to the WinKFP part you'll need to update some software, but otherwise that 6.4.3 package should have enough for the NCS Expert stuff to work
    Aug 2008
    Charlotte, NC
    I did install the correct image. I'm using 6.4.7/3.0.1 right now. Could you zip your E36 folder and email it to me?
    What other configuration do I need to do use WinKFP?
    2016 ZX14R
    1993 R32 GTR V-Spec
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    How do you what GM, SA, or VN string to change it to, although you know what you want to accomplish?
