Results 1 to 17 of 17
Thread: Changing caliper, how do I stop the fluid from leaking out of the brake line?
    Mar 2005
    St. Louis, MO
    E-ballin
    as the title states...bit confused here. once I disconnect the line, won't all the fluid drip out and drain the master cylinder? it looks like its too hard to clamp or ziptie... can I plug it?
    Binghamton, NY
    '80 WBA/'98 WBS/'06 WBA
    Yes, it will start dripping. Just have the other caliper there and hook the line up to the new one then top off the MC as needed.
    Nov 2010
    Amuhrica
    98 M3 Sedan
    of course it'll leak you are changing the caliper...? you have to bleed the brakes after anyway which will require a brake bleeding kit (buy at any local auto supply store). I would suggest going onto the DIY site or looking up how to bleed brakes so you don't screw yourself
    Binghamton, NY
    Quote Originally Posted by l1ttlej7 View Post
    hahaha Yeah, I forgot to mention that part. lol
    Oct 2005
    Brookings, SD
    95 M3 - Avus
    Using a stick or pole to hold the brake pedal down will help control the amount of fluid that leaks out.
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Or you can save the money and use the ancient two person method...which believe it or not...works too.
    Semper Fidelis
    H&R /// Koni /// Powerflex /// AKG
    My 3.46 LSD Build Thread
    Nov 2010
    Amuhrica
    98 M3 Sedan
    ^still need to buy the adapter that will fit in the bleed hole otherwise you get can get air in the hose, even if you are using the two person method, or at least a hose that can fit around it.
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Never had this issue and I've done it multiple times on three different E36s.
    Semper Fidelis
    Nov 2010
    East Bay, California
    1998 BMW M3 Coupe
    plus with the two person method you get an awesome leg workout!!!!
    Current: Titanium Silver 1998 M3 Coupe
    Sold: Estoril Blue 1999 M3 Convertible
    Nov 2010
    Amuhrica
    98 M3 Sedan
    Quote Originally Posted by orangehatter View Post
    so you don't even use a hose? just led it bleed onto itself? I'm confused? I've always bled with a bud and I spent the extra $10 for a tube, a cup, and a plastic adapter that fit into the bleed hole.
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Nothing to be confused about. I've never used a hose, period. Not one issue to this day.
    Semper Fidelis
    Nov 2010
    Amuhrica
    98 M3 Sedan
    ^ too much clean up bleeding them onto themselves, no thanks
    Apr 2003
    LI, NY
    '95 M3
    As long as you don't remove the old caliper, hit the sack, and then replace with a new on in the morning, it'll be fine. The amount that drips out, assuming you get the new caliper on within a few minutes, is negligible.
    Also, if you have had the brake lines loosened in the recent future (as in, they aren't still torqued from the factory), I'd also recommend removing the brake line with the caliper, vs. having to spin off the caliper. I had trouble threading the new caliper onto the line as you literally have to spin the whole damn thing. It was much easier to just remove the line (the fixed hard line is what has the hardware that spins. . .the flex line just comes off at the union).
    95' M3 - Current
    Sep 2004
    West Palm Beach, FL
    09 M3, 97 Viper, 92 NSX
    You can always use a plastic bag and zip tie the line as high as possible. It will still drip but not as bad and won't make a mess. Just re-bleed and you'll be good to go.
    Bleeding: Use 2 people.
    Pump brake pedal ~6 times
    Press pedal to floor
    Open caliper nipple to bleed the fluid.
    Close caliper nipple
    Release brake pedal
    (repeat at Pump ~6 times).
    NY
    '95 M3 + 86.5T Supra
    Go to your local autoparts store. Get some vacuum caps, which are used to cap off small vacuum ports on the motor. Remove line from caliper, plug line with vacuum cap. Nothing leaks.
    They make them in all kinds of different sizes, they're cheap, and work very well.
    Oro Valley, AZ - USA
    see my signature
    2006 R53 JCW (British Racing Green) - 1994 E31 840Ci 6spd (AVUS Blue)
    2021 F56 JCW (Rebel Green) - 2000 E38 740i Sport (Titanium Silver)
    2017 F26 X4 M40i (Carbon Black) - 2007 E91 328iT (Deep Green)
    2012 E82 135i M Sport (Marrakesh Brown) - 2015 E84 X1 (Cashmere Silver)
    2005 E53 X5 3.0i Sport (Kalahari Beige) - 2000 E36/7 M Roadster (Oxford Green)
    2000 E38 740i Sport (Oxford Green) - 1999 E36 M3 Coupe (Fern Green)
    1995 E31 840Ci Canadian (Oxford Green) - 2000 E36/8 M Coupe (Oxford Green)
    2004 E46 330Ci (Oxford Green) - 2001 E36/8 Z3 3.0i Coupe (Oxford Green)
    2002 E39 525i Sport (Oxford Green) - 2002 E36/7 M Roadster (Oxford Green)
    2001 E53 X5 3.0i Sport (Oxford Green) - 2007 E63 M6 (Silver Grey)
    1995 E31 840Ci (Oxford Green) - 2006 E86 M Coupe (Sepang Bronze)
    2001 E39 530i Sport (Aspen Silver) - 2009 E92 M3 (Space Grey)
    2001 E38 740i Sport (Sahara Beige) - 2008 E92 M3 (Melbourne Red)
    2000 E38 740i Sport Canadian (Sahara Beige) - 1997 E31 850Ci (Jet Black)
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    this metal plug is not what he is looking for, that is designed to plug and seal a brake line fitting that uses an M12X1.0 thread with a Double type flare.
    use Hydraulic Hose Service Plugs https://hydraulicmegastore.com/produ...vice-plugs-en/
