Here's what the sellers of the kit didn't tell you. To convert a full auto top to manual you need use that they sent you but you also need to cut out some of the full auto linkage in the full auto frame. This is what you just found out. I have converted 2 frames for customers. You will need to use a sawszall or 4inch grinder and cut the offending linkage out of the way. You will also now need to find the parts to convert your tonneau to "full manual" This is a cabling system in the tonneau area and handle that is installed in the drivers side rear speaker cover. If needed, I have all the parts to convert the tonneau to manual.
By default I'm probably very knowledgeable about all the convertible options and functions. PM or text me if you want more information.
Greg
I also have an e36 very that stops right before it latches on to the windshield. The top motor doesnÂ’t start at all. Could this be the module or is there another issue that IÂ’m unaware of. IÂ’m not sure if itÂ’s the module since the other motors work without a problem.
I'm also debating doing this swap or getting my convertible swapped from full auto to semi or full manual. My top was working great 3 weeks ago, then I was removing the backseat and accidentailly pulled the motor release, so I attempted to re-sync/reset the top, and the motors didn't want to cooperate, then I manually opened it for 3 weeks the few times I deemed it worth taking down with a drill, then the hook motor stripped or jammed, no I can't get the top down completely. I'm just to the point I want the simplisity of the manual top that my cousin's 1997 318i had. 66 6 can I message you?
