Page 5 of 5 FirstFirst 12345
Results 101 to 118 of 118
Thread: Ignition tables
  1. #101
    May 2013
    Australia
    E30 M50B28 Turbo
    Quote Originally Posted by Paty View Post
    Nutzy: What are your pistons?
    JE custom for 84mm stroke and 140mm rod.
  2. #102
    Nov 2014
    CZ
    BMW E36
    Quote Originally Posted by Nutzy View Post
    It is forged pistons?
  3. #103
    May 2013
    Australia
    E30 M50B28 Turbo
    Goes without saying really.
  4. #104
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Stock M20 with o-ring block, ARP headstuds
    93 OCT
    Ebay OBX manifold adapter
    AGP/BW 256 turbo running 1 bar
    44mm TIAL wastegate
    2.5" piping/3" exhaust
    This is mostly street tuned. I have not tuned it on a dyno or try to get too aggressive....I also find that the M20 loves to be just a tad bit rich....13 to 14 AFRs for nice transition/cruising. Around 15.5, the car feels like it is too lean, stutters a bit, slight bucking
    When I get some more time, I plan to add another row down at the bottom of my VE map and make my % values the similiar on both the VE and Ignition mapsAttachment 530061VE table.jpgSpark table.jpg
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  5. #105
    May 2013
    Australia
    E30 M50B28 Turbo
    I posted in my dyno thread but got no responses, so I'll try it here. I'm just seeking some weigh-in on the timing numbers prior to actually testing on the dyno which will be a while off from now.
    The tuner dyno'd my car with 98RON in the tank and bumped up the timing a bit around the 180-200kpa range. On E85, I understand you can run a few more degrees safely in the upper RPM regions and on boost.
    So, keeping things as smooth as practical, I've added some more timing to it, but just a couple of degrees overall.
    How does that look for an M50TUB28 with 8.5:1 on 107RON E85?
    Pete
    1989 E30 - M50B28 Turbo - ZF 8 Speed
  6. #106
    Nov 2014
    CZ
    BMW E36
    Nutzy:
    I see that you've set big premature ignition even at low speeds.
    That's the maximum you can take your pre-ignition engine?
  7. #107
    Oct 2015
    Hannover Germany
    BMW E30 325i M50B25
    Any Alpha N Stock M50 Ignition Table´s here?
    My Table but i dont have a Knock Tool so is there any Stock M50 Ignition Table?
  8. #108
    Mar 2012
    Renton, Wa
    98 m3
    Ignition timing.PNG (66.2 KB)
    I wanted to give something to compare to, I tired to convert load values to KPA. This is an estimation of kpa it really is not perfect, especially down low (<125kpa)
    6465 19psi boost, 3.5" exhaust, tubular manifold, MS41 factory ecu, s52 cutring spacer
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  9. #109
    Sep 2002
    USA
    BMWs
    What fuel and compression? Seems really conservative either way.
  10. #110
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by 5mall5nail5 View Post
    93 pump, 9:1 i think theres 50-100 more in it if i can get it to stop pulling timing. Also going to add probably 4* around the 125/3-4k range. Just need to get on the dyno
    1989 535i - sold
  11. #111
    Apr 2006
    Minnesota eh?
    86 325es
    Here is my current table. It was not dyno tuned, I just made it using some math and guesstimates. I have only tested it up to about 230 kpa or so. No knock on E85 and 12:1 compression. This is aggressive timing so you will need to back off for pump gas.
  12. #112
    Chicago,IL
    330ci E46/E36 hybrid
    wow 12:1 with those values is really aggressive, even on e85. I'm at 10.2:1 and I was worried I was being too aggressive lol. Good stuff!
  13. #113
    Jun 2017
    Zagreb, Croatia
    BMW E36 compact
    Are there any ignition tables for m50b25 non vanos high compression but without turbo?
    thanks
  14. #114
    Dec 2017
    Cambridge
    E36 M50B28 GT35
    Hello. Could you send me a stock spark ignition timing map of the M50B25 engine which does not have the Vanos unit? Thanks in advance.
  15. #115
    Aug 2018
    Finland
    Bmw
    Hi!
    can someone help me? I have turbo m52b28 and i need ignition and VE maps��
    part list:
    holset hx35
    870cc siemens deka
    kdfi v1.4
    gas 98
  16. #116
    Jul 2019
    Czech Rep
    E36 328i
    Can somebody confirm me, that this ignition map is conservative enough to be a starting map ? I have checked multiple maps on internet and this is the result.
    Engine fully stock M52.
    100 oct gas.
    0,7 bar max boost.
  17. #117
    Sep 2002
    USA
    BMWs
    That looks like a decent start
  18. #118
    Jul 2019
    Czech Rep
    E36 328i
    Thanks, good to hear. I only missing one intake pipe from being boosted.
    Here is my build thread for anyone who what do something similiar.
    https://www.bimmerforums.com/forum/s...M52-Low-Budget
