got a blown engine that needs a headgasket, it on the stand already, but i havent started it yet. my question is, how many of you do it without the special BMW tools like the cam locks and vanos tool? have any of you made any DIY tools? Im thinking about measuring the distance between the cams and cutting/machining a piece of stock to fit in between them to prevent them from moving. anyone have any other tricks? if it comes down to it, ill just rent them
There is nothing particularly special about the BMW tools. As long as you somehow lock the cams and flywheel, you should be fine. You could also probably get away with not using the gear wrench.
is there a headgasket DIY on here? I always thought you had to have those locking tools or you would really fook it up. I think the tools (or replicas of them) can be purchased on ebay very cheap.
-M3J0N
The bently manual has a picture in it that shows how to make a cam lock out of sheet metal, I'm sure you can find something to lock the flywheel in place. Youre probably not going to be able to replicate the car turning tool, but its really only more of a convience thing. The upper timing chain tensioner holder is just wire, the lower apparently isnt nessicary. Finally the vanos testing tool is a bajo fitting with a air compressor fitting attached.
That being said, paypal someome a couple bucks and borrow theirs. Youre going to spend a bunch of time gathering materials and making things work anyway. If you only need them once, just get a loaner.
If this is your first time ever doing a head gasket I recomend that you do a little reading before you attempt the job is really not to hard I would look at pelican parts they have a decent write up remember the cams are hollow and will snap if not removed correctly as for tools I have done without but to get timing perfect you will want to use lower chain tensioner tool as for vanos test tool a waste of time buy reseal kit since you will have it off already you may also want to have head hydro tested for cracks depending on your confidence in your diagnostic skills if not the second time you pull head will at least go faster if you can't find anyone else to rent you tools send me a pm I will help you out also look at elpaso tools they are fairly cheap and basicly sell Baum tools that have minor defect or blemish
S52 Wisco/trm pistons eagle rods top mount 6266 (etc) (etc) zionsville fatboy radiator VDP oil cooler setup
obd1conversion baffled oil pan push/pull eletricfans m50manifold CAI JB lightweight flywheel VACsolid motor trans TMSsolid diff subframe mounts tc-kline/koni adj rear shocks tc#550rear springs tc#600front springs tc ride height adj tc/koni adj coilovers tc monoball camberplates tc monoball shock mounts tc monoball RTAB TMS monoball adj rear control arms TMSmonoball upper inner CAB tc derlin frontCAB 323 lsd uuc evo3 SSK 18" RD sport RS2
I did mine withouth any BMW tools. So yes.. its possible.
And it was my first ever HG change, and I have no training what so ever in mechanics.
S50B30 Euro, not the simplest I6 to start my weekend mechanics carrier with.
1995 E36 M3 GT #111
3.0L S50B32 EURO Single Vanos with ITB's and Twin Garret GT2252 Turbo
VEMS Standalone (www.vems.hu) most features enabled.
Brakes, suspention, rollcage, seats, harness, wheels and tires.
at the very least just get the cam locking blocks and correct fly wheel lock pin.
better safe then sorry.
"If you can leave black marks from the time you exit a corner till the time you brake for the next turn, then you have enough horsepower." --Mark Donohue
Have done about 10 headgasket/cam changes without any tool or flyhweel pin...
it's completly overrated
where is the best online DIY for a headgasket swap?
-M3J0N
to remove the head, I did not use any tools. But, the tools can come in handy for installation/timing.
This is my signature....
Head gasket - http://www.pelicanparts.com/bmw/tech...ead-Gasket.htm
VANOS and timing - http://www.pelicanparts.com/bmw/tech...aft-timing.htm
I like the Dr. Vanos stage II instructions, available in PDF, for the vanos and cam timing. They line the arrow on the exhaust sprocket up with the top of the head, which helps get things started correctly. Good to read a few sets of instructions and look at pictures so you really understand what you are doing.
Without the cam blocks, it is easy to be slightly off on the cams and never know it. I recommend that special tool at a minimum. I have done it without the rest or by improvising as to the rest. You can use the back end of a drill bit for a flywheel lock. I have done the job several times with no flywheel lock pin since my flywheel did not have a hole. There is a TDC mark on the front cover.
Why risk it? Just buy the tool.
Yeah,
if you're getting into E36 BMWs... you're most likely gonna STAY INTO them for the haul or longer.
Buy the tools. They're cheap, fancy and scented.
Bro - you just res'd a post from 2011.
Repent.
