Results 1 to 25 of 34
Thread: How to remove spray paint from alloy rims
    Charleston,SC
    1996 BMW 740il
    i was hoping somebody here could help me out a bit. I have 18" breyton magics i recently got but they were spray painted flat black. Does anyone know how to remove the spray paint safely?Thanks in advance
    Jun 2006
    Charlotte, NC
    e30 e34
    It will probably be tricky, do you know if the wheels were sanded or not before they were sprayed? Acetone, mineral spirits or lacquer thinner would pull the paint off without immediately damaging the original paint, but it would take a really long time on those wheels
    '88 s54 e30, '00 m5
    Feb 2004
    SoCal
    1995 BMW 525i
    Quote Originally Posted by Coreydagreat View Post
    I don't know of any way that is safe but I do know a quick way
    buy some aircraft stripper/aluminum stripper from autozone or Kragen/O'Reilly. It's basicaly acid in an aerosol can. You spray a coat on and watch the paint bubble up and seperate from the aluminum then just scrap the loose paint off.
    Do not breath or have this stuff contact any part of your skin. Even if a little speck of it lands on your arm you will feel it burning immediately. Water neutralizes it. It's also known to cause cancer(says in the back). But its pretty damn good at rippin through paint!
    Jun 2006
    The Eagle's Nest
    bf.c e34 contour
    yep. just strip them to bare aluminum.
    then repaint /powdercoat/polish as you want.
    Charleston,SC
    1996 BMW 740il
    thanks i think i will try the aircraft and see how that works
    Portland, OR - USA
    e34, e39
    or just paint over the black
    No current BMWs.
    1994 Roadmaster Wagon
    1974 Alfa Romeo Berlina
    Aug 2009
    Sweden
    www.garaget.org/skillz
    Better to remove the paint with the suggest paint stripper, you never know if the PO did a good job on the paintjob before you and if he didn't the new paint going onto it is gonna be as bad as that, if it's starting to fall off at some time or cracking up. I know.. i've seen it!
    VA
    E63AMG/Z31/Tacoma/F31
    Aircraft stripper is the $hit! I use it often. Only other ideal way would be to have them bead blasted.
    NW suburban Chicago
    hiss by my window
    If it's a difficult wheel then media blasting or professional stripping is your best bet.
    By the time you are done with stripper and F'ing around until your fingers bleed you'll still be out $25 or better in materials.
    It cost me $20 a pop(blasting) last time.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by coolerow View Post
    Pussy, Chuck Norris uses this for bong water.
    LA Sol CAL
    93 525i
    or sand blast them ........lol
    93BMW 525i -16"momo, KN filter ,Daily driver
    Manchester, N.H.
    96 332IS 6466 turbo
    Wire Wheel acid. Spray on let sit and rinse off no elbow grease required
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Jun 2005
    Texas
    E21, E24, E34, E46
    I haven't tried the aircraft brand, but I've use Jasco aresol stripper, which is the best I've tried. It will take spray paint off in a heartbeat, but is almost completely innefective against factory wheel paint (style 5 specifically). It will take the clear off the rims with enough applications, but not the center paint. I finally had the sandblasted, which left a rough finish because it takes a very aggressive sand to remove that tough paint. Next time I would just paint over it. You can't get it off, it's definitely not going to fall off.
    Jul 2005
    NYC / NJ
    Trash
    Quote Originally Posted by ross1 View Post
    lol
    Manchester, N.H.
    96 332IS 6466 turbo
    Brake fluid will work too ...lol
    1996 332IS
    Built 3.2
    Charleston,SC
    1996 BMW 740il
    Quote Originally Posted by Layne View Post
    Would this stripper just take the spray paint off and not damn the alloys themselves?
    Bay Area, CA
    A Beamer & a Bentley
    +1.. and don't forget the time you spend doing this.
    And if you can find someone local to powder coat them also, then you don't have to worry about paint supplies, and assuring the paint will last.
    Jun 2005
    Texas
    E21, E24, E34, E46
    The stripper doesn't do anything to the aluminum at all. It's perfectly safe.
    Jul 2013
    bronx, ny
    2008 Honda Accord EX-L V
    I had spray painted my rims as a theft deterrent after my original rims were stolen last December. Stupid move! At them time, I had no intention of selling my car, a 2008 Honda Accord. Now I am trying to sell it. I learned today that simple adhesive remover will remove the paint. Other possibilities are paint thinner and graffiti remover. Try those first before resorting to the stronger stuff. The paint may not be as difficult to remove as you think.
    Jul 2006
    Hanover MA
    '11 Golf TDI+Porsche 996
    Great bump. A+ thread, would read again
    I own mostly junk. Except the Porsche, that's kind of cool.
    All the motorcycles are trash which you can read about at
    http://oneguytwowheels.blogspot.com/
    I'll update it eventually
    Thansk
    Aug 2009
    Greeley, CO
    540i6, 540iA, RX7, RdBlk
    Quote Originally Posted by GarrettSR5 View Post
    Fox
    So. CA
    are fun!
    We have a stripper that charges $25 a wheel to soda wash the wheels. Not abrasive like sand blasting. The wheel comes out ready for polish and paint without the pits that sand blasting can cause. Media blasting with something like walnut shells is much better than sand if you want to go with blasting them.
    Cheers,
    Jim
    1990 M3
    1995 E34 540/6
    1992 525it
    Butte, Montana
    Suck
    Quote Originally Posted by IronmanE30 View Post
    Cheers,
    Jim
    So, she's a stripper and she refinishes wheels? Sounds like my kind of gal.
    Feb 2010
    Slovenia
    are rusting away
    Quote Originally Posted by Binjammin View Post
    If she's a redhead or a brunette I call shotgun.
    Live slow, die whenever
    So. CA
    are fun!
    Quote Originally Posted by MehMan View Post
    LOL, I would post a picture but would most likely be breaking forum rules. Sorry guys.
    Cheers,
    Jim
    1990 M3
    1995 E34 540/6
    1992 525it
