Page 24 of 24 FirstFirst ... 1415161718192021222324
Results 576 to 599 of 599
Thread: (Almost) free DIY ADS interface
  1. #576
    Dec 2018
    germany
    1994 BMW 325 Cabrio
    Hello,
    I copied everything. Only the pins I could not connect from "cd4053be". I do not understand, there are 16 pins .. on the pdf is at pin 1 -> 11 why? I am sorry for my English
    Is the number 11 on the Picture Pin nummer 1 and:
    14 - pin2
    10 - pin3
    15 - pin4
    9 - pin5
    4 - pin6
    12 - pin9
    13 - pin10
    2 - pin11
    1 - pin12
    5 - pin13
    3 - pin14
  2. #577
    Dec 2018
    germany
    1994 BMW 325 Cabrio
    I dont understand with the chip "cd4053be".
    Is number 11 - pin1? number 12 - Pin 9?
    number 5 - pin2? number 13 - Pin 10?
    number 10 - pin3? number 2 - Pin 11?
    number 15 - pin4? number 1 - pin 12?
    number 9 - pin5? number 5 - pin 13?
    number 4 - pin6? number 3 - pin 14?
  3. #578
    Jan 2019
    *оссия
    Александра
  4. #579
    Jan 2019
    *оссия
    Александра
  5. #580
    Jun 2017
    Indonesia
    E34 530i
    Red face IFH-0009: NO RESPONSE FROM CONTROL UNIT INPA e34 530 v8
    #Edit: Solved , I re-build that HansVMKII Board , and now it talking to my e34 530 RHD non EWS via DIS v44
    Need Help , sorry my english is not really good.
    with help of my friend we re-create board schematic in eagle and build it. when i plug in to the car it light up right away , connect to battery and ignition dot in INPA ( from ediabas-6.4.3-full), but it got same problem again IFH-0009: NO RESPONSE FROM CONTROL UNIT Car is E34 530i M60B30 RHD. My installation folder is in C drive and a fresh windows xp 32bit on pentium 4. i also follow up the instruction from klaas :
    a- execute instprog.exe
    b- Installed with rectification program UK and selected ADS (not OBD), and installed just EDIABAS and INPA
    c- Set the environment variable PATH: addes C:\EDIABAS\BIN
    d- restarted laptop
    e- Executed ADSSETUP.exe and restarted again
    Ediabas.ini Files is like this , or maybe i should try using DIS ? anybody have the link to download it ?:
    Thank You
    ; Interface
    ; Description : Connected diagnosis interface
    ; Default = EDIC
    Interface =ADS
    ; Additional information (in German) :
    ; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
    Here is my error picture and my stock COM1 Setting,
    Attachment 644681Attachment 644682Attachment 644684
  6. #581
    May 2017
    Germany
    1995 E36 328i
    I built a case for my interface, maybe its useful for other people: https://www.thingiverse.com/thing:3438136
    It has a 5mm hole for a power led and a D-SUB 9 cutout
  7. #582
    Apr 2018
    The Netherlands
    1994 BMW 325i
    [QUOTE=klaas;30145951]
    Quote Originally Posted by MParallel View Post
    It is a mod made by FAL for mistreku that bypasses the EWS check for the 3.3.1 DME in version 4.4.7. This INPA version can only read DME of cars with EWS and it wont continu to the engine menu if the car has no EWS. Probably FAL ripped the code out that checks for EWS presence
    See screenshot of this post made by FAL to mistreku:
    Attachment 640452
    https://www.bimmerforums.co.uk/forum...41/index5.html
    You should, after clean installation (i have no access to my laptop with INPA but i believe it was like this):
    - Rename existing SGDAT\DM331K20.PRG ---> SGDAT\DM331K20_WITHAWS.PRG
    - Copy mistreku DME331.PRG -> SGDAT\DM331K20.PRG (rename it to this after copy)
    - Rename existing \Ecu\DME331.IPO ---> \Ecu\DME331_WITHAWS.IPO
    - Copy mistreku DME331.IPO --> \Ecu\DME331.IPO (same name)
    It now picks up these files instead of the AWS ones.
    Sorry for the confusion im maybe creating.. i think this instruction might be wrong (but still try it 2nd if you cant get it to work):
    ----WRONG
    RIGHT, just do this:
    - Copy mistreku DME331.PRG -> SGDAT\DM331.PRG
    The DM331K20.PRG.. ive renamed it to DM331K20_WITHAWS.PRG just to make sure EDIBIAS/INPA is not using that
    [QUOTE=TRF434;30147762]
    Quote Originally Posted by TRF434 View Post
    klaas,
    I got it to work by adjusting the data transfer speed from 16 to 8 bit on COM properties. Thanks a lot!
    Sorry i have not repied..
    Strange that that fixed it..
    I think i gave the wrong instructions:
    ----WRONG
    This was right i believe:
    The DM331K20.PRG.. ive renamed it to DM331K20_WITHAWS.PRG just to make sure EDIBIAS/INPA is not using it.
  8. #583
    Sep 2017
    Hungary
    1997 BMW E36 320i
    Hi there!
    So i built my own diagnostic ADS interface from here:
    https://www.bimmerforums.com/forum/s...terface/page21
    POST #508
    thanks for these for E36328Coupe!
    so after that, it's working very well with Inpa and NCS, i can code my car and read out oll of my modules, but now i decided to use DIS.
    yes. DIS.... i know a littlebit about DIS and i also know about this, this is a "hard understand" software instead Inpa.
    so i can't connect my car with DIS via owned ADS interface.
    can anybody help me? what coud be wrong with that? Thanks a lot!
  9. #584
    Jun 2020
    GER
    e39
    Hello,
    i am looking for the latest gerber file for hannsv mk2 interface. Could somebody help me?
    Thanks!
  10. #585
    Dec 2019
    Netherlands
    BMW 316i E2 1996
    Lets see if this thread is still active..
    I made the circuit and it works somewhat. The indicators work, and I can access at least 2 modules; the EWS and Instrument Cluster. But when I choose "DME 1.7 for M42 / M43" I get an 0009 error in INPA 5.0.2
    I checked the cables between the 20 pin and DME and everything is connected.
  11. #586
    Sep 2017
    Hungary
    1997 BMW E36 320i
    Hi there!
    Couse its not working with this ecu. I cant acces too. You have to look around in this ecu with tool32.
    Every other ecu is worked for me except this. I dont know why
  12. #587
    Dec 2019
    Netherlands
    BMW 316i E2 1996
    Just wanna say, I made it work, I mirrored the ground cable on the DB9. Everything is working and I just reprogrammed the EWS to work with and Ebay chip tune
  13. #588
    Sep 2017
    Hungary
    1997 BMW E36 320i
    can you kick off the EWS? if you say yes, HOW? and what with? can you point me? thanks a lot!
  14. #589
    Dec 2019
    Netherlands
    BMW 316i E2 1996
    I didnt see an option to just "turn it off", but when you go back, read the DME and look for the ISN code(for me it was 3 characters, can be "c4t" or "cat") and write it down. Go back to main menu, scan the EWS and there is an option to code in the ISN overthere. When you type it in you see "0xdog", leave the "0x" and replace "dog" with your ISN from the DME. I hope this helps.
  15. #590
    Sep 2017
    Hungary
    1997 BMW E36 320i
    Thanks. Is it in the Inpa software? Or NCS or something else? Or do you know any guide for it?
  16. #591
    Dec 2019
    Netherlands
    BMW 316i E2 1996
    You can find it all in INPA. I used INPA 5.0.2. Basicaly my previous message was a short "guide"
  17. #592
    Mar 2019
    POLAND
    1997 BMW E36 323i coupe
    Hi i made this ADS interface from #1 post and works well with INPA and my old laptop with rs232 and windows xp. But i have i issue with ncsexpert. I can't read ZCS and VIN. I tried did that in DIS v44 too but without success. And i have question what line would belong to "coding things", wchich element on scheme i must check or how to check the correct work of the entire interface? With INPA i can connect to engine ecu, airbags and nothing more. Car is euro e36 m52 '97 coupe
  18. #593
    Sep 2017
    Hungary
    1997 BMW E36 320i
    hi there!
    i built a few boards, which are fun, but i wondering to build another one with less components. So i took Hans's circuit, and tried to transfer it to the simple strip board. i didn't test it yet, what are you think about guys? Is it good, or absolutley wrong? Or anybody has a layout with this circuit to strip board? I also know, there is a layout for this, but i can't make my own board, i can just work with strip boards. So Hans, if you read it, pls check out my new board
    And one more thing, now here is winter time in my country, and my boards just broked down. WTF??? the cold is very very bad for these boards, it's about -10C. 141551340_5351541401587854_295427655536605382_n.jpg141747697_263074191864238_1034684624304698842_n.jpg142143675_396528638309933_9081546115083502951_n.jpg
  19. #594
    Jan 2022
    Palmerston, Manawatu, NZ
    1994 BMW M3
    Kevin you mention you know DME3.3.1. Are you able to help me? Simply cannot get INPA to talk to my DME. Starting to think it cant be done. Happy to PM?
  20. #595
    Apr 2018
    The Netherlands
    1994 BMW 325i
    Hi,
    If other modules are working (i always try to KOMBI first as its fast), then you probably are missing the DME331.IPO and DME331.PRG modified files by mistreku
  21. #596
    Nov 2007
    SF, bay area
    94 740, 74 wagoneer
    Quote Originally Posted by sikirman View Post
    Simply cannot get INPA to talk to my DME. Starting to think it can’t be done. Happy to PM?
    Make sure that your wiring is proper: I built the basic interface from post 1, but could not make it work... upon recheck, I had awrong resistor 4.7K instead of 47K, upon recheck 2 some wiring was missing and upon recheck 3 I had built the DB9 plug reversed, most of us will be using a female DB9 to go into the PC male serial port. Check this site:
    https://www.codrey.com/embedded-syst...communication/
    and this schematic toward the middle:
    I still have issues but managed to get some basic infos. I am using ediabas 6.4.3 which install INPA 3.0.1, Compag NC8430, with XPsp2, real serial port
  22. #597
    Jul 2021
    Greece
    BMW e46
    Hello there!
    First of all, a big Thanks to everyone that has helped/contributed to this thread. After reading tons of pages and forums about how to fully diagnose my e36 318i (M43) 1997, I decided to build the ADS interface as described in post #1. I am using a newly installed INPA known to work on ADS mode, according to the page 7 of the "z3 diagnostic forum". The laptop I am using is a Panasonic cf-18 with a physical serial port, running windows xp 32 bit.
    I have triple checked the schematics and connections but I am still unable to access any module. Power and ignition (INPA black dots) work as intended, and INPA loads without errors, indicating to me that probably the INPA is configured correctly, but still getting errors when trying to access a module. Serial port is set to com1, ediabas.ini configured correctly.
    I am running out of ideas what might be wrong.
    Any help is greatly appreciated.
    Thanks,
    Kostgeor
  23. #598
    Sep 2017
    Hungary
    1997 BMW E36 320i
    Nice work!
    Can i get your pcb layout? Both sides, and the component values pls
    Thanks a lot
  24. #599
    Nov 2023
    South Africa
    94 E36 MCL2, 71 2002 Tii
    Hi there,
    I'm struggling to get my interface working, I've checked my pcb a few times and pretty sure I've got everything connected correctly, but who knows (MKII design).
    Currently I can get dis and Inpa to recognise my ignition, they also start to communicate seemingly, but when I choose a module i.e. dme, it tells me I have an m62 engine and the chassis data etc seems corrupt (The car is actually a 1994 e36 318is m42).
    When I plug my interface into the 20 pin and my laptop serial port, all the leds turn on which seems incorrect according to KevinMullins video. Ignition does get brighter when turned on, but I would assume dtr should be off as well as k line. When I start a job the K and DTR lines are the only ones that flicker, the rest remain on.
    Is there anything you recommend I check?
