Yes, as far as I know. Please try it and let us know how it worked.
Yes I believe so. Although I don't have an OBDII car to test it on, I believe that this interface becomes an OBD interface (in ediabas/inpa terminology/configuration) if you short pins 20, 17, and 15 together and connect them to pin 7 in the OBD connector.
Very nice of you benemorius and Lowclock, thank you! Does it work with Carsoft? Did any one test it?
If an ADS INPA adapter will work with carsoft, then this adapter will work with carsoft. Otherwise it will not. I believe the answer is negative, but I have not read up on these matters in quite some time now.
Last edited by benemorius; 08-19-2011 at 04:50 AM. Reason: neglected to specify ads (vs obd)
OBD interfaces work with carsoft, ADS don't.
Hi Benemorius:
After several days of researching, I decided to prototype your interface and I finally took out my scope after a full day of unsuccessful testing with INPA 5.02 (installed from INPA.iso).
I discovered that the DTR line is always set high (output from USB to Serial cable) and shutting down the RXD line which was significant. I got around that by moving the RXD line to the other side of R15. I also joined TXD1, TXD2, and RXD together at pin 20 of the 20-pin connector along with a jumper to pin 17. I did not connect the IGN line because INPA was constantly indicating Ignition and Battery OFF - Probably something with the USB interface.
I followed the instructions in this thread:
http://www.e46fanatics.com/forum/sho...d.php?t=770882
e.g. - I added UBAT=OFF to OBD.ini immediately after Retry=ON (next line). I also created a registry file (as indicated in the thread) and added it to the registry for the serial port.
After making the above changes and the change to you interface - success!!!!!! I spent <$20 for parts, $20 for USB cable (Prolific PL-2303 chip set) and some debug time - Thanks for your efforts and ingenuity with the circuit (Schmitt trigger cleans up the spikes on the returning waveforms). Regards, Joe
If i build this cable, which software would work with it ?
I'm so desperate, i can't erase an airbag error on my '93 E36, no service/person in my town has an ADS tester, can't find one for sale in my country, only OBD/OBD2
Thanks so much for taking the time to provide feedback. I'm sure this information could help someone else in the future. It sounds as if your serial adapter may indeed have been acting funny, though I should restrain myself from offering too much speculation until I have reacquainted myself with the subject again. I'm glad you were able to get it working and make use of it despite the problems you encountered.
I've personally used both INPA and easyDIS with success and no (apparent) missing features. In fact, resetting my airbag light with INPA was the first thing I did with it, I believe. This was on a '94 US e36.
Additionally, according to jarda's input concerning carsoft and OBD INPA adapters, it seems as though carsoft should work with it as well if you do as I instructed a few posts ago for turning it in to an OBD adapter. I have not personally tested this configuration. Do note that on a car which requires an ADS interface (as opposed to an OBD interface), you will not be able to communicate with some of the modules if you use an OBD interface. I don't presently recall which modules will work and which will not, but that information should be present (in one form or another) in the openobc thread. This is true regardless of which software you use, as it is due to the fact that an OBD interface does not transmit on the RXD line which is the only line that certain modules are listening on.
Thank you for the answer benemorius
For pin 14 and 19, should i take 12v and Gnd from the car's battery ?
enjoy !.... and provide feed-back
Can I use NCS Expert with this Interface ?
OK, the car is 94 325iC (US version with ADS) and EDIABAS 6.47 and INPA 5.02 on IBM T30 using the serial port configured as COM1. No connection with carsoft 6.5 and 6.1. INPA see the battery but not the ignition key and any module. I was wondering if there is some points were I can check the voltage eventually to troubleshoot the schematics or if there is any way to figure out if the problem is in the INPA installation. I appreciate all of your help guys!
i have done the interface, it's working , at least at the level of battery and ignition. further, i will need some assistance in e36 "debug"
to the question raised for the q1 connection with resistors, try to imagine tjhat this is the back of the board, different from when you look at the transistors (usually, from the top. i had myself the same problem when designing the board, i was suspecting a flaw in the cad soft... the flaw was mine - misreading the positioning of the "q's"
Can you connect with all modules in E36 using this interface?
well, i have tested the interface today, it's working.when you install inpa make sure that you choose ads interface
not ads/ obd.
i have erased information in my airbag module, i have reseted the inspection time/mileage, i have found that the errors in my abs module are dued to a faulty sensor (rear right... which i am going to test it more thoroughly tommorow; i have checked all the instrument cluster module, well, at least what i know to do.
referring to the question raised if this interface connects to all modules, i cannot answer , but i think if you get it to communicate with two or more modules, then you have the right thing.
beware of com port 1 beeing occupied by stupid active Sync
OK.I will make it and test on E36
By the way.I found other simple ADS schema but built on MAX232 and specific K-line drivers.Acc to information it should work fine with ADS cars.
I would test it as well but PCB needs to be created.
Can anyone make PCB to that schema?
[QUOTE=PitrekT;22747771]OK.I will make it and test on E36
Can anyone make PCB to that schema?[/QUOTE this is for an OBD based system; different !!!! the can system also uses k-line but you have to have also the L-line for older bmw's !!!
nevertheless , i will try to make a pcb in one or two days for your schematic...
I comapred that schema with other ADS interface and main difference is exacttly in one component GAL.Orginal ADS interface has GAL but this one no.It seems function of GAL was replaced by two 74HC... chips.
As I know CAN system doesn't use K-line just CAN-H and CAN-L
Anyway tahnks for your support in making PCB
See here: I took that design and modified it slightly to use a different regulator, more filtering, and SMD components:
http://forums.bimmerforums.com/forum...php?p=22903159
1999 ///M3 TiAg | Heated Power Vaders | DDM Projector36 5000K 55W HIDs | DDM 3000K 35W HID Fogs
DDM Smoked Corners | DDM Weighted Shift Knob | K&N CAI | Mishimoto AL Rad w/Zionsville AL Shroud
Stewart HiPo Water Pump | Samco Hose Kit | 16" SPAL Puller Fan | Viper 5701LE Security
E36 OBC is now open! Join the effort: BF.C Thread | openOBC Wiki
Hi,
I've "built" the breadboard now. Only problem is, no luck communicating. Neither ECU, ABS or Instrument Cluster. Even when not connected, INPA says "Battery: ON". Cannot get Ignition to change from "OFF". Battery is still "ON" even if I disconnect the usb<->serial adaptor.
Moved RXD on computer-side as stated earlier in this thread, no change (what would that have to do with IGN detection anyways)
Interface = ADS, INPA starts just fine. Works with KKL409 and Interface = STD:OBD, on my E39. The car I want to connect to is a '92 EU E36 325i Coupé. Tried with my car batteri charger, connecting GND to - and IGN+BAT to +, no luck.
My USB-Serial adaptor is a Prolific PL-2303. Checked with the settings stated earlier in this thread.
Hope my english makes sense.
Troels
Denmark
Unfortunately, BMW has programmed their ADS driver in such a way that it only works with a real serial port. Forum member jarda has written a tool to make it work with pcmcia and presumably pci serial ports (see here and here) but I don't think anyone has found a way to make it work with usb-serial adapters. It should be possible, but no one has written the software yet.
