i install v3.01 and there is no desktop icon,in programs i dont know what to start aaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
It should have created a program "group".
Start -> All Programs -> EDIABAS, blah, blah -> INPA (_.IPO)
i found but not launch , have some errors.i wos install again another ver
does anybody know will dis read dme?
and does someone hawe instruction how to install id ,now i download dis 8,5gb i hope it works
this sounds like a perfect case for using Teamviewer
My M3 is 1 of 2
i back to inpa 5
now sins last night try ing to install dis....and i stuck vhen i start virtual machine starts to boot apear scren vmvare boot and on next scren is only _ and stops that....
i try to install dis instal base byt have error when installing v44 error 205.
@david mc
thank on files and explanation bud on my laptop is onlu 25gb hdd so when i unrarr there is no space
is dis can only instal over virtual machine? can it be instal as independet os?
dual boot dis and xp?
DIS needs a UNIX operating system and can be installed natively on a UNIX machine, but you will have to use a yellow DK head with it as without vmware there is no way to communicate with a head connected via INPA/EDIABAS. A bigger hard drive is probably the cheapest option.
ewerything is fine,dis read all modules and motor on older e36 .i use interface from first post with transistors.thanks eweruone espesialy @efendi71
another question. Since i have this cable that is obd2, would dis worked with him without any modification files? or if there is what needs to be changed, since it is written in ediabas.ini the ADS interface .. i hawe this cable
pardon me the turning off the topic, but here is a lot of professional people.thanks
In EDIABAS.ini, Change Interface = ADS to Interface = STD:OBD
In EDIABAS/Hardware. run OBD Setup.
ok,and when i want to use again ads? i must cnange STD:OBD to ads
and run ads on ads setup?every time?
You should not have to run the ADS setup every time, but you will need to change EDIABAS.ini so that Interface = ADS every time.
yust that in ediabas.ini. and it works?
thanks a lot
So I've read through this whole thread but can't find what I want.
Can anyone tell me where the final schematic and BOM can be found?
I'm in the UK and want to give this a go.
post #343 on page 14 has a PDF attachment showing the schematic for the HansV MKII ADS interface (for non-OBD models)
I built this using a breadboard and a slightly modified 20-pin round connector and it works well enough with my old WinXP laptop with a real RS232 serial port, connected to my 11/94 built E38 740i
Gentlemen,
I build the MKII circuit from post #254 using the exact parts from the PDF. I triple checked my connections and everything seems to be in place. This is my environment:
Vehicle: E34 520i 1995
ECU: Seimens MS40.1
PC: Dell D610 (with serial port)
OS: WindowsXP
INPA: 3.01
I did a normal INPA install, set the interface to ADS and ran the ads utility, then rebooted the machine. I also adjusted the serial port settings to FIFO and the buffers to 8.
Unfortunately, I can't access any of the modules. When I plug the serial to my computer and run INPA it detects battery and ignition. What is strange is the way the K and L LED's behave, and I was hoping that someone with a clue can comment on them. When I first plug lead #19 into the diagnostic socket, while ignition is turned on, both LED's would light up for 2 seconds, then they would go off simultaneously. After about 30 seconds they would turn back ON for a second then back off. While attempting to connect to the ECU or run the identification test, I see K line LED blinking but L line completely silent. I'm hoping that some one reading the above description, and viewing the videos can point me to the issue in my setup.
Here are a couple of videos of my attempts:
http://www.youtube.com/watch?v=9MfKYypS9tI
http://www.youtube.com/watch?v=Yl95cy07rLA
Thanks,
I am picking up a 98 Z3 next week and I have an older XP computer with a real serial port on it. This looks perfect for my needs - I have built a lot of electronics from scratch. Where do you source the 20 pin connector for the build?
Dave
I have the Tiny ADS interface that I am trying to get working However I cannot find a plain version of INPA, Ediabas or NCS. All the ones I have are configured to run OBD only and will not let me run ADS mode.
Can anyone point me in the direction of a working INPA, Ediabas and NCS download that will work in ADS mode?
Also I am fairly competent with computers but does anyone has an easy set up and install guide?
Did you run the ADS Setup found in the C:\EDIABAS\Hardware\ADS\ADS32 folder?
And did you already change the EDIABAS.ini to run INTERFACE= ADS ?
Hi, plz post pcb file
Dann, try restarting your computer after running the ADSSETUP.exe and make sure that you have made the addition to the path statement in Windows Environment variables (Device Manager).
