Thank you Kevin for the files, thank you HansV for the schematics (which i used ;-) )
Did another test yesterday and despite the fact that your DME331 file is englisch and it causes INPA to bother thatīs another language version it works almost perfect now! Yesterday i even did a first try on coding with NCSExpert/NCS Dummy, now i have autoclose on my rear windows ;-)
Thanks for all the effort all of you put into this and all the help for me. Iīll do some further tests now on my girlfriendīs e36 316i compact and my brotherīs e39 330d touring and report back.
Only issue by now is that the interface seems to be influenced by em signals so it takes sometimes a bit longer to establish connection or connection is lost during reading the values. Iīm now reading some pages on protecting from em waves and report back
greetings
Thanks to all of you and special thanks do KevinMullins for the files and HansV whose schematics i used. After copying Kevinīs files connecting DME works almost perfectly. I even did my first coding experiment yesterday, now i have autoclose on my convertibleīs rear windows. So INPA and NCS are working... Now i will build my interface again with a new pcb and try again. ATM i have some connection errors due to EM interferences....
Next Steps: New interface, better EM protection, get DIS running
Greetings from germany
Connections to the modules works better with DIS, but everything is a lot slower slower. Make sure you install the version called EasyDIS, that has some changes made to is and is the last DIS version wich also can do coding.
Just a warning:
I got some PCB's from Imall where they printed the notation on the wrong side. I soldered the components on this side as well without thinking, and that did not work very well.
If any others order PCBs, make sure to check the schmatics and component placement drawing to verify that the components are on the correct side. The power connection should be in the lower, right corner when looking at the component side.
The board is OK and worked fine when the components was soldered on the correct side.
Ah... That makes sense then, because he has it on his latest schematic revision, guess it just didn't make it onto that run of pcb's.
Your software is the "testo" live data stuff right?
The latest version I have is "testo-19-Apr-2013" ... is that the newest version?
I haven't tried yours out yet, but I can if you want since I built HansV's design based off the schematic and it seems to work on our E36's with what testing I have done with it.
Ok, I'll give it a shot next time I get the chance. Been tied up with mechanical repairs on my daughters car lately, haven't been playing with software much.
Sorry about the layout files. The track to pin 10 needs to be cut and pin 10 strapped to the k-line.
I have corrected PCB files if anybody wants to order PCBs from Imall. Just send me a PM.
Currently I am working on a round board that is soldered directly to the 20 pin connector for easier assembly. I also have a no-led version of the board with lesser components.
You get 10 boards for about 10$ from Imall.
@HansV or anyone else using the CD4053 design ... Can you access the EGS (transmission) module?
I have not been able to at all on the 1994 325i that I have been working on. Trying to narrow down if it's a diagnostics software/hardware problem or a problem with the module itself.
My car don't have a EGS module, so I have not been able to test this.
HansV --> Hello, I have question for you.
I made ADS interface according to your drawing - "ADS interface Mk1" and I can successfully connect to (using inpa or dis):
- E39 '97 - all available modules
- E60 '04 - all available modules
- E34 '93 - all available modules
but I cannot to connect to DME 3.1 Motronic and other modules responsible for engine in my car - E34, M50B25 non vanos, 12/91.
I don't know what is wrong... I can connect to other modules e.g ZKE, ABS, AIRBAG but DME .....no
I can make interface mk2... maybe it resolves my problem ??
What do you think about this ?
I'm sorry for my english but it isn't my national language.
Regards
Piotr
You should use the MKII interface, that solved the low voltage problem some had. But I do not know if this will solve your problems. You can just drop the LEDs if you dont have use for them and connect the pull-up resistors directly to 12v.
No, I took all that off when I finished putting the MKII design together and all seemed to be working well. (which it does aside from the transmission stuff)
Based on the error I get and the length of time it takes before popping up I would assume it's "trying" to access the module, possibly even "finding" the module... just gets a "IFH-0010 Data transmission to Control Unit Disturbed" error after a delay of doing pretty much nothing on-screen.
Haven't had a chance to mess with it much lately though.
This is one of the byproducts of the job. I designed it because we needed to snoop in the communications to reverse engineer the protocols. I found all the existing interfaces to get needlessly complex and pricey as they all appear to get based on BMW's early first layout.
Hi, firstly I would like to say big thanks for your pretty work on DIY ads interface. I admire that job!
Secondly, I'm seeking for some help. I made HansV ADS interface mk1 and I have a trouble with 1992 E34 530i M60 (DME M3.3) and 1996 E34 520i M50 (DME MS40.1). I'm using INPA 4.4.7, Ediabas 6.43, DIS v.44. I cannot connect DME. Connection to other units (ZKE, airbag...) is OK. EDIABAS.INI is set "Interface = ADS" and I think thats correct.
Do somebody know where is a problem? Bad version software or have I to make MK2 interface or something else?
Thanks again, guys! :-)
I would start by making the MKII version.
Some changes between version I and II made a world of difference on a lot of finicky modules.
OK, I try to make and test MKII.
In other event, I found that problem was in bad files in C:/EDIABAS/ECU. What you think about this? May be my problem also here?
I have had bad or missing files cause problems.
Insure that you have the appropriate .prg files in the C:/EDIABAS/ECU directory to match your DME's.
Also make sure you have the right .ipo files in the C:/INPA/SGDAT folder that match your DME's.
HansV you have finished a draft of the PCB (Eagle or black and white PDF or bitmap or other format) ADS interface MKII with post # 254?
I searched the whole subject, and unfortunately I did not find.
I think the names of files are OK, but I'm not sure.
Today, I try MKII version and DIS v.44 and the results are:
1992 E34 530i M60 (DME M3.3) - I can connect all units.
1996 E34 520i M50 (DME MS40.1) - I can connect all units with the exception of DME
I also try connect 520i using OBD manufactured cable (which I'm using with no problems to connect 1996 E36 320i M52 DME MS41.0) and the result is that I connect only airbag. All other units doesn't respond.
Have you tried to connect using EasyDIS? It is a hassle to install and much slower, but you can do a lot with it and it's easier to connect to the different modules without error for some reason. This could have to to with the configuration files that could be hard to sort out in INPA.
While installing I have got a problem and stop at 'New virtual machine wizard' window where we have to select a guest operating system I select Windows OS as per the OS that I have but I am unable to go to the next step. Can you help me to troubleshoot the given problem? Thanks in advance!
