Page 3 of 19 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 470
Thread: The E36 Diff Thread
  1. #51
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Quote Originally Posted by drew1320 View Post
    Bravo, great write up.
    Question - what is the manufacturer of the diff? I know its a 188mm but want to purchase a new ring and pinion and have some resources but need to know the manufacturer.
    Thanks.
    BMW used Gleason and Klingelnberg gears. Unfortunately a new set off the shelf is rare unless you are looking for 3.91 or 4.10. Other ratios have to be sourced from used differentials.
    Semper Fidelis
    H&R /// Koni /// Powerflex /// AKG
    My 3.46 LSD Build Thread
  2. #52
    Jun 2004
    USA Charlotte NC
    1999 M3 Coupe
    Wow.. What a great read.. Many thanks to the OP for such a detailed
    how to on the diffs..
    What gear oil do you use and how often do you change it out..
  3. #53
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Quote Originally Posted by Mikem53 View Post
    I'm using AmsOil Severe Gear 75W140 with about a half a tube of AmsOil Slip-Lock friction modifier. The Severe Gear is a 50,000 mile interval.
    Semper Fidelis
  4. #54
    May 2009
    costa del scotland
    e36 318iS
    awesome write up
    i have been trawling the web to find this info for sometime now and constantly drawn a blank
    thanks
    there is 1 minor detail i would like to clear up though, this only really applies to the euro cars
    the euro 3.0 M3 came with the medium case LSD, same as the smaller 6 cylinder engines and it will fit inside the non M differential carrier and you can use the 320i etc propshaft if you swap the input flanges
    the euro M3 EVO 3.2 came with the large case LSD
    if anyone is considering fitting the M3 EVO LSD to anything other than a M3 EVO, the EVO differential carrier is needed
    thanks again for the write up
    easy sailor
  5. #55
    Jul 2004
    Houston, TX
    36 Cylinders
    Hi this is a great write up! If I wanted to replace the clutches inside my differential, is it necessary to replace all the parts you replaced? Just trying to get a range of costs for mine. I believe the clutches are gone for good... it struggles to inch the car forward when one output shaft isn't connected (broken... snapped clean on acceleration... have no clue why). So that prompted me to want to rebuild my differential in the future. I found this thread and I'm bookmarking now and I'll be re-reading it again to understand some more.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  6. #56
    Oct 2007
    Chandler, AZ
    E36 323is/5
    You will want to replace all of the bearings and races when you dig that deep...they do not last forever...Do it right the first time so that you don't have to do it again.
    As far as the output shaft, are you saying that the actual axle that plugs into the differential snapped or the half shaft that runs from the axle to the wheel?
    Semper Fidelis
  7. #57
    The Netherlands
    DE-spec E36 328i/M3 cab
    This is such a great topic. Lately I have been reading into diffs as I (finally) got an original LSD for my 328i. Amazing details, pics, write-up. Appreciated.
    It's amazing to see how much goes into it. I never was aware of how critical things are even even that you had to set these in the first place, like all the preloads and stuff.
    I knew about the pinion preload, but never realized there is also a preload on the actual turning of the pinion (or is that the same as the bearing preload?).
    I don't understand the carrier preload though. Is this the turning resistance of just the carrier when it sits in the casing, without the pinion installed?
    It also seems that preload and backlash are interactive with each other, like in they effect each other. Then is must be a pain if you think you have the correct backlash, but then mess it up again because of wrong preload and vice versa.
    So how is carrier preload set? There is no crush sleeve or anything or even a bolt to fasten. Or has it to do with the endcaps behind the output flanges?
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
  8. #58
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by orangehatter View Post
    The half shaft that runs from the axle to the wheel. Also known as the CV axle or output shaft Seen on RealOEM. The 328 came with 38mm diameter ones too. I'll get pictures of it soon. I was like this when I saw it. I'm not 500 hp ++... It happened during a brief acceleration moment with wheelspin, I didn't dump the clutch though. I'm glad it didn't happen 2 weeks ago at the track (MSR Houston).
    So I just finished swapping the axle and did both rear wheel bearings while I was at it (PITA..) If it wasn't for me doing the whole job inside my dad's machine shop (with AC) I would have gone crazy. Luckily I was able to make presses and pullers on command.
    2. Another question is if you can add just one extra clutch and plate to the differential to have 3? I can adjust and machine anything for size no problems... but I'm just wondering if it has to be added in pairs?
    Thanks for you time.
    PS. Do you have measurements for how much force (besides the loose "25%") the clutches are supposed to hold from one side to the other? Like I said, with the output shaft broken on one wheel, I could barely get the car to move forwards, so I called a tow truck.
    -Abel
  9. #59
    SATX, USSA
    ESS 625++
    Thumbs up
    great info OP, thanks for sharing and explaining it perfectly.
    ESS 625
    RAGE AGAINST THE MACHINE
  10. #60
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Quote Originally Posted by MParallel View Post
    It is the same as the bearing preload. It's the total rolling resistance of the pinion gear with both bearings, the crush sleeve, input yoke, and pinion nut installed.
    Yes, it is the turning resistance of just the carrier as it sits in the casing without the pinion. The ring gear must also be installed on the carrier to measure this.
    They really do not play into each other as much as you may think. Left to right shimming on the housing end caps determines the backlash. Once you figure out what thickness shims work to get the correct preload on the carrier, you add or subtract from each side to keep the combined thickness the same and shift the carrier either right or left to get more or less backlash.
    You do not have to add in pairs, but if you do add an odd number, the two will go on the side of the spider gears opposite of the ring gear. The endplate is what will need to be machined down, and this will be the combined thickness of the clutch and dog-eared plate.
    The exact range of numbers is in the TIS link that I provided. It should be in Newton meters and listed as "break away torque."
    Quote Originally Posted by Patrón View Post
    Thank you.
    Semper Fidelis
  11. #61
    Jul 2004
    Houston, TX
    36 Cylinders
    You're awesome! Thanks for your replies.
    Do you know of any reason as to why my output shaft broke right through the shaft part? It doesn't seem to be a common thing, I've searched.
    -Abel
  12. #62
    Oct 2007
    Chandler, AZ
    E36 323is/5
    The only thing that comes to mind at the moment is that the limited slip somehow completely locked and caused the axle to shear apart. It really isn't a common issue unless you are running 100% lock (like a spool) or you are putting loads of torque to the wheels.
    Semper Fidelis
  13. #63
    Nov 2008
    SF Bay, CA
    72 + 75 2002's
    Just picked up a 3.46 LSD as the last piece to my rebuild. Awesome thread and great work OP!
    Current_SeeDee 1972 Type 114 Luna 1975 Type 114
    Past___Veronica
    1994 e36 Le-Ah 1987 e30
  14. #64
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Quote Originally Posted by Spyke View Post
    Thank you!
    Semper Fidelis
  15. #65
    Cocoa, FL
    1997 318ti
    Incredible information in this thread, thank you for putting it together. Can you tell me where you did your part number research? I'm going to be putting together a small case diff and would like to look up the parts for that.
  16. #66
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Quote Originally Posted by Entropyman View Post
    A lot of the part numbers I found through sites like RealOEM. As far as the bearings and races go, I looked through Timken's website and then cross-referenced that to what was actually in the differential that I had sitting in front of me...
    Semper Fidelis
  17. #67
    Aug 2008
    Noblesville, IN
    '99 M3, '14 Civic
    If I ever need to do this, this is the perfect thread. . . . . . . and your relatively close to me as well.
  18. #68
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Yes I am...I can give tips, hints, info, or hands-on if need be.
    Semper Fidelis
  19. #69
    UK
    BMW M3 Evo Cabrio
    great write up - many thanks to the topic starter!!!
    a noob question though - how does one test the diff? or what are the symptoms of a failed/becoming close to failed diff?
  20. #70
    Georgia, Tbilisi
    BMW 330 T
    hi.
    where can i buy
    33141203801
    BEVEL MATE SHAFT ?
  21. #71
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Quote Originally Posted by maxott1 View Post
    hi.
    where can i buy
    33141203801
    BEVEL MATE SHAFT ?
    That part is no longer available from BMW. You have to gut it from a used limited slip spool.
    Semper Fidelis
  22. #72
    San Francisco, CA
    95 M3 GTS2/ST
    Backlash and Pinion Depth
    I had a question regarding setting pinion depth, pattern and backlash.
    Some places indicate that you should set backlash prior to checking the pattern for pinion depth. For example, http://www.differentials.com/technic...n-instructions
    "Check the pattern for proper pinion depth only after setting the backlash. Brush three or four of the ring gear teeth with a moderate coat of gear marking compound in two different places on the ring gear. Rotate the ring gear past the pinion gear three or four times and then back so the pattern can be seen."
    Believe it was indicated in this post that you set the pinion depth, check the pattern and then check backlash.
    It seems there is no clear cut answer, but was wondering if anyone could shed light on doing this.
    Looking to attempt a 3.46 swap from an e30 to an e36 and was trying to figure out proper order.
    Thanks much for the great thread.
  23. #73
    Oct 2007
    Chandler, AZ
    E36 323is/5
    Really it can be done in either order. It was more of personal preference on my part. Changing the depth of the pinion really has zero effect on the backlash and I'd much rather know that my depth/tooth pattern is correct to avoid disassembling the pinion again from the differential. Backlash is controlled by the lateral shimming of the carrier and ring gear assembly, and that can easily be removed and adjusted as needed.
    EDIT: To add to this also, you will likely find that the BMW gear sets have very good tolerances and will likely require no adjustment on the pinion depth to get a nice clean, acceptable wear pattern.
    Semper Fidelis
  24. #74
    San Francisco, CA
    95 M3 GTS2/ST
    Thanks much for the response. It's easy to get overwhelmed with all the different opinions on how it should be done. I guess what really matters at end of day is the pattern and the preloads on the pinion and carrier.
    I picked up a medium case 3.46 LSD. The condition of everything seems great so far. A friend and fellow forum member Flink loaned me his extra e36 M3 3.23 Diff to swap into. I'm in the middle of taking them apart and while waiting on parts, was trying to learn how to check/set backlash and preload. First hurdle was figuring out why the LSD and gear wouldn't fit into the other case and found that the trigger wheels were different - the donor LSD had a larger wheel than the e36 case could accept. I swapped them and it fit fine.
    I am basically copying what you did, following your thread and when done, I will do a writeup as it may further help others. I am not having to swap the ring gear to a donor LSD as I'm putting everything into the e36 case, so won't need to get into spacers for the ring bolts.
    So far, bought most of my stuff from rmeuropean - one thing I found in buying the bearings ( at least for the pinion) the SKG ones come with the races. From what I gathered with the Timkens, the races needed to be ordered separate. Not a big deal, but I think that's what accounts for the cost difference?
    Found these links to be helpul - the first is an instructor from an Automotive Tech class showing how to do setup:
    [ame]http://www.youtube.com/watch?v=dAqAqODmcj4&feature=related[/ame]
    This one has a simplified pattern correction explanation that I liked. Reading that wheel on the TIS gave me a headache
    http://www.drivetrain.com/parts_cata...tructions.html
    A couple other questions:
    1) When swapping the pinion for a first try pinion depth check, would the better shim candidate be the one that came with the 3.46 case and pinion I am swapping? I need to check the thickness and compare, but I would think that would make more sense than using the one that came from the 3.23 case. The pattern after doing a test fit with the original shim under the rear bearing race looks heavy on top of coast and drive side - meaning I need to move the pinion closer to the ring, and the pattern closer to the root, right? I am guessing that the other shim that came with the 3.46 is thicker, but will need to measure.
    2) Did you end up having to use the Mercury shims? If so, where did you order them from?
    3) For the axle caps and carrier shims containing the carrier bearing races, should those stay with their respective original cases or go with swapped LSD, Ring and Pinion unit? Maybe it doesn't matter if you are changing the carrier bearings and races anyways, but one set of mine looks much better than the other.
    4) is the marking on the pinion set at the factory in relation to the Ring gear or the case the pinion originally went into? For example, on mine it is marked +5.
    Thanks again for doing this writeup.
  25. #75
    Dec 2007
    SF bay area
    1998 M3 / 2000 S2000
    regarding Lock up modification (for the center section) - I have done many, many........ of these.
    IF adding 1 more to any e30 or e36 differential for a TOTAL of 3 clutch discs + 3 dog plates, NO MACHINING IS REQUIRED.
    there is a 4mm spacer at the bottom of the case. Remove this steel spacer, replace with 1 dog plate and 1 clutch. if you order 2.0mm for these it will be = identical stack.
    IF you want 4 clutch discs in the stock e30 or e36 188mm LSD, then the top cap would have to be machined. Some BMW OEM LSD units in 188mm have a thin top cap and 4 clutch disc conversion can be accomplished with 0 machining or modification. This is going deeper in parts bin compatibility than most DIY-er's will have parts for.
    Some rare bird 188mm LSD's came from BMW with OEM 4 clutch discs. also Asymetrical center ramps (40/25% locking on accel/deccel)
    Wanganstyle Powertrain
    http://www.wanganstyle.com/
    S54B32 E36 M3 DTA S100 Sedan Street car full swap:
    http://forums.bimmerforums.com/forum....php?t=1437471
