318is 1991
where can I get special tool to remove this nut?
Yes there is. Baum tools 313170. However, it's usually done with an impact driver.
"Howdy, Folks!"
Getting it off is not the problem, since an impact driver will do the job. Getting it back on properly is when you need the tool. There is another option though. That bolt is not hugely tight, and it is possible to slide the bump stop down and grab the very top of the strut shaft with a pair of vise-grips and hold it while you loosen or tighten the nut. I've done that four times now and have yet to even visibly damage the strut shaft very much. It is very, very tough metal. And even if you did damage it, it's not going to go into the strut and tear up the seals unless you are doing Dukes of Hazzard jumps with the car. And if you are, you'll have other problems lol.
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
It might. Let us know if you try it.
"Howdy, Folks!"
I tried to grab some h&r springs on the wknd, got the rears off easy but struggled with the fronts. Hopefully their still there tomorrow. I didn't even think to hold the rod down as I just keeped on spinning it with frustration. LOL
Struggled today at the yard today trying to get this nut off. Tried holding the strut, but it just kept on spinning. Finally found a guy with an impact driver, paid him $5 and they were off in seconds w/o needing to hold the strut. Word of advice, get yourself an impact driver. LoL save the struggle, curse words and time
Compress the spring
Hold the strut shaft with vice grips
Use a deep socket - comes right off
Tim
This car is AWESOME !!!
I used a gearwrench passthrough style socket and it came right off, I was able to get a smaller socket through the gearwrench socket.
"Howdy, Folks!"
http://www.google.com/products/catal...d=0CGMQ8wIwAA#
Good stuff, I've got a set myself
I hear you on that, to be honest I rather not ruin the strut as well. I think as long as you compress the spring enough it will take off the load to get the strunt mount on tight. Just use the impact to get the nut back on, then reinstall the entire assembly back up in the car. Secure it w/ the three strut mount nuts and then give the 19mm nut a final tightening w/ the impact driver.
so gonna get this for my tools collection, 45bucks for 49pc.
http://www.sears.com/shc/s/p_10153_1...4&blockType=G4
there's no load when installing H&R race spring because is so short,guess I clamp the oem strut shaft to tighten the nut. all struts are blown anyways.
If the strut is to be discarded and you don't have tools to hold the stud just grab the shaft below the mount with a vice grip pliers.
I've used a thin wall 19mm socket grabbed with channel locks and held the center bolt with crescent style adjustable wrench - real PITA, but didn't cost anything more than a scared up socket.
To get the nuts off get yourself a long breaker bar and give it a quick whack with a hammer - the sudden inertia has always done the trick for me.
