Ok, when did this start to happen? Has it always been overheating since owning it 2 years ago? If not, when did it start to overheat? Maybe you could trace back the works you've done that can affect the cooling system? Maybe you can also try using straight water just for testing if it will still overheat? Also does it overheat even if the AC is off? Maybe the condenser is heating up too much. Yes a lean mixture can heat up your engine. Why do you suspect this?
Guys, don't use water inside cooling system please Antifreeze not only doesnt freeze but it also contains anti corrosion additives....
Sent from my Samshit SM-G900F using Tapatalk
Yes she has always been overheating since I own her.
without AC it takes much longer to overheat, but with AC on, it just take a few minute after stops the car.
I'm suspect of lean mixture because amount of hydrocarbon in exhaust gas test was only 76ppm and her tailpipe is always clean!.
I'm using Turner motorsport chip in ECU (the only modification I've don on her) but same result with the OEM chip.
I used only 2 liter of antifreeze in 12 liter of coolant (about 16%). the rest filled with purified (membrane filtered) water.
Ok so it can't be waterpump because the rad is hot and the air coming out of it is hot as well. So it basically leaves only radiator itself or the fan. To me it sounds more like a faulty fan clutch (new part doesn't mean it couldnt be faulty) or the fan isn't the right one. Because if it doesn't overheat when driving that means that the radiator is working and when there's more airflow, the engine runs fine.
What fan clutch did you get? Sometimes cheapo ones tend to be bad out of the box. If it's OK, then the fan has been previously replaced with the wrong one with less blades or smaller diameter.
Or the explanation is simply that you live in sauna xD. Did you get the car from some "cold" place and you live yourself in quite a hot one? It might lack hot climate option.
The car came from japan 63000km on tacho.
fan and fan clutch are Ok. clutch start engaging when 76 deg seen on digital temp sensor and fully engages on 85 deg in every engine rpm. I've checked it by a portable tachometer while reving the engine up to 5000rpm fan does revs about 5000 rpm too (very laudly and make storms of hot air).
I can't understand why this engine makes such a heat!
Fan@5000 is a bad clutch.
Should disengage at lower revs.
Ever had the MAF checked or rebuilt? M5 MAFs can go out of spec which could cause a lean condition. Although performance would suffer and it would run hotter all the time.
Jut throwing ideas. Hot at idle would indicate to me:
1. a lack of flow through the radiator (I.E. partial blocked rad, or pump issues)
2. Inability of cooling system to keep up with heat generated by engine (hg Leak pushing exhaust gas into cooling system)
I understand your frustration.
Just about every M5 that I know coming from Japan has had a head gasket issue. Mine included. They have horrible traffic and the cars just sit and idle. I suspect that your head gasket is an issue of some sort. good luck but that is where I would put my
Money.
Something is wrong internally with the motor.
HG failure on low mileage cars that sat for years and years is not uncommon.
Compression / leak test the engine. I'll bet you have two adjacent holes that are lower than the rest.
________________________________
Nik
91' M5 3.9L Stroker
92' M5 3.8L
95' 540i6 Supercharged
95' 540i6 4.7 Stroker
95' 550i6 M70 Conversion
compression test 1.jpgcompression test result
you've loosed the bet my friend! (loool)
Leakdown test or hell the $5 liquid tester. Blown HGs won't send compression numbers down meaningfully, they will show up in leakdown.
Just did it right now. I don't have leak down tester but I brought up pistons one by one to TDC and ..... by 100psi compressed air from air compressor.
just cylinder 2 has very little leakage to the crank case (very small fisssss sound from oil dipstick) . the rest are in perfect condition.
No leakage to each other or to water circulation system.photo_2017-08-24_22-27-57.jpg
Where do you live? I mean is it hot there? What are the temps? And can you give give me last seven characters of your vin?
There's different water pump and pulley for hot climate versions.... Maybe that could be the cause for overheating
I'm guessing he lives in Tehran. Did the e34 ever get a hot weather package?
demet
Japan should usually have a hot weather package.
But yea OP, check the part #s
Dont rule out water pump - it could have lost a vane or two on the pump as has lost all its efficiency.
