Correct
No... Both, reverse and the switch will activate front and rear sensors at the same time.
I'm not sure... I just had a spare modules around so I pulled one with the same resistance. I think guys at RadioShack can help better.
Next time you are here, pm me
You bet man!
I'll circle back and provide more info on the resistor when I fiddle with the system.. The last thing I would want to do before installing is seeing if I can use different distance sensors for the rear. The OEM sensors fit much nicer to the rear of the e36....but they fit much less aesthetically on the e31 (i was trying to be nice...they just look plain flugly), so if I can find an OEM sensor, or even aftermarket, that works well with this OEM e38 system It would be my ideal kit.
CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
My other projects:
Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
Old reply, but now with the OpenOBC project finished boards, this has ibus input, which means the pdc measurements could be displayed now!
Well well well. Just as I thought I knew everything about the E36 and surely every switch used it in the E36...
just wow. My first thought was someone had modded a PDC switch and fitted the rocker arm to it. Turns out is a "service car" switch.
That one is perfect and I can only guess a simple switch that breaks contact (it would be normally on) and simply cuts +12v or ground.
That switch sure has potential. Could be an easy solution to switch on/off front/rear pdc independently. Ok the E32 switch is nicer, but also harder to hook up as it's a momentary switch, N/O I believe.
This switch being I/O could also be perfect for my SMG's pump on/off switch. I want to put a switch that acts as a circuit breaker as I don't want to pump running every time I open the door, if I just need to get something out of my car or do some work that doesn't involve starting the car.
I could use multiple Hi-fi switches, but the symbols are wrong. With this being a nice I/O, it makes more sense, although of course not 100%.
ps: but damn, BMW charges an arm and a leg for new switches.
pps: the ETK is still not a 100% thrustworthy. It still and always has listed a sunblind switch, while the E36 never got an electric sunblind.
How did you wire this? There is only one 12v + that I am aware of to power the E38 PDC unit (green/black, pin 26).
Where did you wire the 12V + reverse signal to turn on the E38 PDC unit?
My thoughts were to power the E38 PDC unit from 12V + switched (provides PDC at all time via switch) and using a relay to provide a ground signal (but don't know where this mysterious signal is wired to the E38 PDC unit, brown/blue/yellow band, pin 19?) when the in reverse.
Thanks for the info.Will update this thread when I get my install done next month hopefully.
If anyone is interested in this project I have one complete front/back BMW PDC system available. All you would need to add is the switch.
Just for the record, is an old type module uses that uses the same "passive" sensors as the E36 or could or is the later type module used with active sensors? The old one have 2-pins, 3 for the later ones.
IIRC the facelift or at least post 3/99 E38/E39 use the active sensors. Thought they all beep. I have no clue how they would work better, if it makes a difference at all.
Well good to know. From the looks of it all the modules are the same size, or at least this E38 one is. That would mean I can use the factory bracket when I (eventually) might try this mod.
On my 328i I retrofitted the original PDC system and this has a nice piggyback wiring loom that replace pin 1 of the left rear light cluster (+12v reverse light) with a pin from the loom and than that loom has a contra-connector for that pin. Pretty need.
My M3 is factory fitted with PDC. I wondered if this works the same way, but I see the ETM now that the <ON> signal comes straight from the reverse light switch on the gearbox.
At first I want to at least get a functional PDC switch (the E32 one) working, so I am going to try that tip listed in this topic.
From VAS2VAS
I haven't checked if my M3 has a purple or yellow plug module. Didn't know there were 2 versions. The retrofit kit has the purple one.FYI, I can confirm this works on an E36 yellow plug PDC module. Momentary ground to pin 19 can deactivate/activate the pdc while reversing. I used an SMG switch from an M3 Evo which has 3 pins and when pressed closes one of the wires to ground (other 2 wires are of course ground and illumination).
Now that PDC switch has a kind of (to me) weird inner workings. The trick would be getting +12v to the pin of the green light, but that goes off when you press it to turn off the PDC. Using the reverse light +12v would not work as this is on in reverse all the time. I doubt there is a +12v out in the E36 PDC module that would go off while staying in reverse.
I think Yellow plug PDC will work with the button... Not sure about purple one.
D., why do pin 14 and 18 be connected? When I check the E36 ETM, ground is already provided to both these pins. I guess if you were to use the E36 wiring loom, you could hook it up and have ground to 14 and 18. Unless you did custom wiring.
and what is exactly the function of that diode/restrictor solderd in that empty spot?
Ah thx. Wasn't is much easier to add an extra ground wire to the connector instead of soldering that wire inside?
ps I checked my E36 PDC module. It's with purple connector. Adding pin 19 on the black connector (x300) and grounding it does not disactivate it. I guess the factory e36 pdc switch (the I/O one) simply disconnects the +12v on the reverse light imput wire.
Yeah, so no chance on using the E32 momentary switch with the E36 module.
Yes I meant with my current (purple) connector PDC module.
I guess the yellow one is the old version of the module. Haven't check what is on my M3 with factory fitted PDC, but I bet it's purple as well.
Don't really mind though, as the E36 PDC switch is fine as well. As long as I can fill all the button spaces in my SMG console with properly functioning buttons.
It's a shame the E36 lumbar switches are not lit. Modding a light in them, well I guess it's possible but not something I fancy. That way I could fit them in the center console and have easy access to them. The location on the rear side of the seat is as good as unreachable while driving.
Plenty of SMG consoles here. I could source you one, but they do ask silly money for the LHD version.
My PDC kit I bought new from BMW in 2008 came with purple connector.
Well actually, I have two PDC modules with purple connector. One from my 2008 retrofit kit and one from a second kit I once bought as a spare for cheap (or for maybe future front PDC conversion).
The spare PDC module is is HW02 SW1.9 and is built in 1998.
The 2008 kit module is HW01 SW2.0 and comes from 2004. The P/N of that module is listed as from 1998 till "now".
A little odd is that the newer one is a lower hardware version, but newer software version.
FYI the two versions (yellow plug and purple plug) also use a completely different design rear PDC gong (even though the housing is near identical). The yellow plug one uses a speaker type gong (i.e with a voice coil), and the purple one (a later design) a buzzer type gong (i.e with a flat piezoelectric disk); they have different part numbers are not interchangeable.
P.S. I've got a spare yellow plug PDC module, and a RHD SMG console in a box somewhere.
From examining it, it's a regular console that's been precisely cut-up and the plate with the switches/shift indicator is just glued on and can easily separate, so I think anyone with descent fabrication skills could easily mate the plate to a suitably modified LHD console.
Currently:
95 318is, 71k original km...
Sold:
96 316i Compact
95 M3 :'(
87 190E 2.6
95 C280
82 240D
89 735iL
85 318i
95 Opel Astra 1.4
93 Lada Niva 1.6
