Page 2 of 8 FirstFirst 12345678 LastLast
Results 26 to 50 of 181
Thread: E36 Front PDC
  1. #26
    UK
    1998 328 convertible
    The connectors are a pig. Costly, and I can't find the USB one, which appears to be a + shape with a circular outer, with four pins in the + arrangement.
    Normally you just need to round the corners a bit to get them to fit.
    EDIT: Before - note right angled corner to fascia part.
    After, slight rounding.
  2. #27
    dancerst's Avatar
    dancerst is offline life is a dance... BMW CCA Member
    Virginia Beach, VA
    E36 SC,E31 840ci,740iL
    Quote Originally Posted by MParallel View Post
    Why use a ASC switch and not a E32/E34 PDC switch? Then it looks 100% original and already has the extra control light inside.
    PDC switch:
    Finally, I found that rare swith.... in Moscow
  3. #28
    UK
  4. #29
    dancerst's Avatar
    Virginia Beach, VA
    Quote Originally Posted by Joylove View Post
    Love it. Where did you get the flush mount recessed 3.5mm socket from?
    I made it myself ))
    You can look pictures here... http://www.e36club.ru/forum/showthread.php?t=181998
  5. #30
    The Netherlands
    DE-spec E36 328i/M3 cab
    How's did you wire the pdc switch? Already to the front pdc module? The wiring circuit of the switch seems a bit complicated. Is there a +12v coming on when pdc is turned on that activates the control light?
    IG:
  6. #31
    dancerst's Avatar
    Virginia Beach, VA
    See attached diagramm
    Attached Files Attached Files
  7. #32
    The Netherlands
    Unless the electrics are the same, you posted an E38 doc, while that pdc switch is e32 specific.
    IG:
  8. #33
    dancerst's Avatar
    Virginia Beach, VA
    PDC switch pinouts are the same.
  9. #34
    The Netherlands
    Quote Originally Posted by dancerst View Post
    Ah it's just the design. Well I already knew the pinouts, I just wonder where the +12v originates from that activates the green light. That diagram only lists 4 wires and none for the control light, unless the same source is used for both the amber light anf the green one.
    IG:
  10. #35
    Jul 2010
    Ireland
    1996 E36 318is
    How do you do the back PDC if you already have an auto dimming rear view mirror? Looks to be the same sensors to me?
  11. #36
    The Netherlands
    Quote Originally Posted by JerCotter7 View Post
    Totally different.
    PDC sensors are located in the rear bumper mouldings. The auto dimm mirror sensors are located in the mirror (one in the glass, one on the front. if more light at the glass side is measured compared to front, this means an external light source is behind the car and possibly blinding, thus the mirror dimms).
    IG:
  12. #37
    Jul 2010
    Ireland
    1996 E36 318is
    So in that case I have the sensors in my car but for some reason or another they aren't working? I don't have any OBC. Just an analogue clock. The wires from the 4 sensors run into the car as well. So confusing.
  13. #38
    dancerst's Avatar
    Virginia Beach, VA
    Look carefuly to the right corner of diagramm.
    There’re 2 wires from PDC Module (1- momentary ground input, 2- control light output)
  14. #39
    The Netherlands
    I thought that was the night illumination for the "PDC" text.
    What sensors? I don't understand? Do you have an auto dimm mirror, or pdc? Or both?
    Also, now you bring in the OBC, which has no relation to either PDC nor the mirror.
    Maybe someone put in the rear pdc sensor for show and didn't hook them up?
    IG:
  15. #40
    dancerst's Avatar
    Virginia Beach, VA
    For the «PDC» text there’s grey-red wire on the switch.
  16. #41
    The Netherlands
    Hmm yes I even saw that listed. I don't know what I was looking at. Must have looked to quickly.
    If I understand correctly and look at the switch diagram then
    pin 2: red/grey illumination
    pin 5: ground for both lights
    Then by pressing the switch pin 6 is powered, which turns on the PDC module and this module puts out power to pin 4 for the control light.
    Looks to work by some bi-polar transistors.
    Too bad it's a momentary switch and NO. I would like to make it NC so I could wire it in for my rear pdc as I'm not doing front PDC in the near future, maybe never.
    So my idea was to have the switch wired NC so I can put it in reverse and activate PDC, without having to also push the switch. Only to turn it off while in reverse if I would want to. And use the reverse wire +12v to turn the control light on.
    But I doubt if the E36 PDC module has an output for the control light, as the rear PDC never have a separate switch to turn it on off. Otherwise it will only be a dummy switch only for its control light in it.
    Or if I would want a difficult route, use an PDC module with front PDC and use the front sensors on the back so you use the circuit meant for the switch. But that seems like a waste of time and money.
    IG:
  17. #42
    dancerst's Avatar
    Virginia Beach, VA
    I’m not sure 100% (because I forgot) but I think E36 PDC Module can be wired with PDC switch. You can try it by putting momentary ground to pin 19.
  18. #43
    Jul 2010
    Ireland
    1996 E36 318is
    I have the dimming mirror and PDC on the back bumper. Just no beeping when reversing. I thought it used the OBC to beep when getting close.
  19. #44
    dancerst's Avatar
    Virginia Beach, VA
    Open your trunk, pull back left «capret» cover and see if you have PDC Module.
  20. #45
    The Netherlands
    As I (tried to) explain before. Well I did say it very clearly: there is no autodimm sensor in your bumper. The auto dimm sensor is inside the mirror.
    I do wonder why you think you have one in the bumper. I think you are confusing a part with something else.
    IG:
  21. #46
    Jul 2010
    Ireland
    1996 E36 318is
    Yeah got that, thanks. Now to figure out why it's not working then install them on the front as well.
    What I was trying to say in the post was that I have both. But my PDC isn't working and I knew there was wiring going into the car from the sensors. I always, wrongly, assumed that it was for the auto dimming mirror.
    I now know that the sensors in my bumper are for the PDC and not the mirror.
    EDIT: Where is the actual beeper? All 4 sensors are clicking when in reverse.
  22. #47
    The Netherlands
    Under the steering wheel. Unless it's a retrofit kit, then It will be in boot(trunk).
    IG:
  23. #48
    Jul 2010
    Ireland
    1996 E36 318is
    Thanks. The wires were under the steering wheel and there was also a blue wire that has to be connected to the same speaker so I'll have to find out what that is too. Pity someone removed the speaker so I have to order one from ebay.
  24. #49
    Jan 2003
    USA
    BMW M3
    Pdc
    I am just starting doing this now, will have to relocate the alarm led in order to make room for PDC switch in there (all other switch slots are taken).
    Will keep you posted once finished.
  25. #50
    dancerst's Avatar
    Virginia Beach, VA
    Quote Originally Posted by M3C
    Don't forget to take photos during installation
    Sent from my iPhone using BF.com
  1. E36 e36 Front and rear seats in tan
    By AndrewH in forum Exterior Lighting & Body Parts
    Last Post: 10-20-2010, 03:49 PM
  2. E36 FS: E36 Front Knuckles/ Spindles/ Hubs/ Wheel speed sensors- CHEAP $55 shipped
    By sweet e36 pimp in forum Suspensions, Springs & Shocks
    Last Post: 07-27-2010, 06:56 PM
  3. E36 wntd e36 front crontrol arms
    By 3lm3rom3ro in forum BMW Parts Wanted
    Last Post: 03-15-2010, 01:29 AM
  4. E36 NJ: 1992-1994 e36 front bumper
    By amancuso in forum Exterior Lighting & Body Parts
    Last Post: 01-04-2010, 02:28 PM
  5. E36 E36 Front Caliper New
    By Momikey in forum Brake Kits, Rotors & Pads
    Last Post: 12-06-2009, 10:29 PM
