Can anyone tell me what happens to the rear suspension geometry of an e36 when you raise the ride height? Are there any toe or camber changes that take place? If so, what happens... toe-in... toe-out... camber goes more negative/positive?
Thanks for the help.
Bryce Merideth
'97 328is (Calypso Red): TCKline/Koni Double Adj., VVS springs, JTDesigns f/r strut-tower braces, Eibach sways, TCKline rear shock mounts, TCKline camber plates, BMP adjustable rear lower control arms, powerflex bushings, Conforti CAIS, TRP Custom 3" exhaust, UUC Underdrive Pulleys, D-force 17x9's, Potenza RE-71R - weight:2820lbs
As you raise the rear, both camber and toe-in decrease.
Hopefully we will see you soon! Still running STX?
STX 182 - 95' BMW 325is - quickly getting slower
Forest Oaks Insurance/Mann Motorsports/The Racer's Market/Discount Tire
Blog about my STX BMW
We're taking this year off, but we should be at the Atlanta Street Tire Challenge in August... Then we'll be hitting it strong in 2012!!!!
Bryce Merideth
Toe change is pretty negligible over the range of "normal" E36 ride heights. +/- 1/32" for a 2" change in ride height.
Camber gets more negative the lower the car is. I think (going from memory) my car gained 0.5 degrees of negative camber when I dropped the rear 1.25". Roughly. I can measure it next time I put the car on the alignment rack and give more accurate numbers.
Chris
97 M3
94 325is
12 Jeep SRT8
