I tend to over tighten...
http://forums.bimmerforums.com/forum...rogress+photos
http://forums.bimmerforums.com/forum...6#post19108216
Thanks, this helps alot
Oh, this is the worst-looking hat I ever saw. What, when you buy a hat like this I bet you get a free bowl of soup, huh?
It looks good on you though.
Lighten Up Francis
Pull the bulb out and write down any and all numbers found on the base.
"Howdy, Folks!"
Lighten Up Francis
Well at this point, I'm doing a bit of guessing but here goes. First of all, I assumed that BMW would prefer to spec something that is already in their inventory. As the bulb shown is not original, I used it to spec the size of the base. It looks like the the base is a bayonet style BA9s. The only bulbs I'm aware of that were used in that era by BMW was the T4W and the H10W or H5W. I'd probably try the T4W first and see if that provides sufficient lighting. If not, then I'd go with the H10W. It's probably the 10W though. Dome lights in sedan/coupe were 10W.
T4W/OSRAM 3893/BMW 07509063576
H10W/OSRAM 64113/BMW 63311375003
Let us know how it works out.
"Howdy, Folks!"
I found a BA9 based LED bulb on eBay, I ordered it and will see what it does and will report back.
Sent using Tapatalk
Lighten Up Francis
I finally found the correct listing for the cabrio dome lamp next to the check panel. It's a 5W halogen bulb.
Code:Osram/ Location Qty Specs Generic Sylvania BMW Comments ========================================================================================= Dome - Convertible 1 5W H5W 64111 63311374798 Light next to check panel
"Howdy, Folks!"
Bump
Kool
Sent from my SGH-T999L using Tapatalk
I'm pretty sure I did this wrong. But, I'm in search of a bayonet LED light to replace the bayonet dome bulb in my '87 e30 cabriolet. Any clue! I'm tired of buying the wrong bulbs!
QUOTE=richardodn;21846586]This post has been added to the DIY thread. Go here for the maintained version. http://forums.bimmerforums.com/forum...1#post26757741
After so many times people asking what bulb goes where, I decided to create a comprehensive list of lamps and where they are used in the car. This should be fairly accurate. Please post any corrections in this thread and I'll update the chart.
[/QUOTE]Code:Osram/ Location Qty Specs Generic Sylvania BMW Comments ========================================================================================= Headlights - Sealed Beam, Low 2 35/35W H5006 H5006 63121468226 Headlights - Sealed Beam, High 2 50W H5001 H5001 63121468272 Headlights - US Ellipsoids, Lo 2 51W HB4 9006 63217160786 Headlights - US Ellipsoids, High 2 60W HB3 9005 63217160785 Headlights - Euro Ellipsoids, Low 2 55W H1 64150 63217160777 Headlights - Euro Ellipsoids, High 2 55W H1 64150 63217160777 Headlights - Euro Ellipsoids, City 2 5W W5W 2825 63217160797 Fog 2 55W H3 64151 63217160779 Front Marker/Turn 2 21/5W P21-5W 7528 63217160793 Side Markers (Early) 4 4W T4W 3893 07509063576 Side Markers (Late) 4 5W W5W 2825 63217160797 Tail (Early) 2 10W R10W 5008 07119905337 Tail (Late) 2 5W R5W 5007 07119905336 Rear Turn 2 21W P21W 7506 63217160789 Stop 2 21W P21W 7506 63217160789 Back-up 2 21W P21W 7506 63217160789 High Stop 1 21W P21W 7506 63217160789 High Stop - Cabrio 1 18W 921 63251372632 Euro Rear Fog 2 21W P21W 7506 63217160789 License Plate 2 5W C5W 6418 63217160805 Festoon 37x11 Glove Box 1 5W C5W 6418 63217160805 Festoon 37x11 Dome 2 10W C10W 6411 63217160912 Festoon 41x11 Dome - Convertible 1 5W H5W 64111 63311374798 Light next to check panel Trunk 1 5W C5W 6418 63217160805 Festoon 37x11 Ashtrays - Front and Rear 2 1.2W W1.2W 2721 63217167000 Mirror Map Light 2 10W H10W 64113 63311375003 Mirror Map Light (Alternate) 2 5W H5W 64111 63311374798 I've seen recommendations to reduce wattage to 5W Instrument - Wedge Base ?3 1.2W W1.2W 2721 63217167000 Instrument - Plastic Base ?13 1.2W 2721MF 62111368299 Instrument - Illumination 2 3W W3W 2821 07119905358 Light Switch 1 1.2W W1.2W 2721 63217167000 Shifter - Automatic 1 1.2W W1.2W 2721 63217167000 Check Panel 1+ 1.2W 2721MF 62111368299 1 + 1 for each large indicator (e.g. seatbelt) Digital Clock 1 1.2W 2721MF 62111368299 Digital Clock/Temp 1 1.2W 2721MF 62111368299 OBC - Buttons 1 1.2W 2721MF 62111368299 OBC - Backlight 1 65811375461 Light bar HVAC Panel 2 1.2W W1.2W 2721 63217167000 If a bulb is not listed here and it's one of the tiny lamps, it's most likely a 2721 or 2721MF. Some switches have replaceable bulbs that are not listed.
Search amazon for "64111 BA9 LED"
"Howdy, Folks!"
I got one of this off amazon: http://www.amazon.com/gp/product/B00...ilpage_o00_s00
it fitted well but not light up, is yours having the same problem?
Anyone know which one should I get?
It should be the right lamp. Did you try applying 12V directly to the lamp? (Remember polarity.) Maybe it's defective.
"Howdy, Folks!"
Just out of curiosity, did you try connecting them with both forward and backward polarity?
"Howdy, Folks!"
I'm seeing a discrepancy on the 2721LL bulbs....I got a pack the other day for the HVAC panel from Autozone and they were the correct watts and volts, but when I stopped by Advance yesterday to get a second pack for my ashtrays, it called my attention that they specify 6.5V 9.8W.
The correct wattage for those locations is 1.2W, and these have a new part # which is 2721LL.BP2, which are 13.5V and 1.2W. Be mindfull of the part number when buying these!
Correct:
http://www.autozone.com/electrical-a...ght/16865_0_0/
Incorrect:
http://shop.advanceautoparts.com/p/s...p2/99997887-P#
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
_____________________
River City Bimmers Chapter
2002///M3 Coupe, Steel Gray Metallic on black leather, three pedals.
2005 X3 3.0i ZPP, Black Sapphire on Terracotta.
1991 E30 325ic, AW, Black leather, Black top, three pedals.
Thank you! Still good 8 years later!
You're welcome. BTW, the maintained version is here https://www.bimmerforums.com/forum/s...1#post26757741
Every now and then I find a bit more info.
"Howdy, Folks!"
"I can see the light..."
thanks for this...John
