Results 1 to 25 of 46
Thread: E30 Comprehensive bulb list
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    This post has been added to the DIY thread. Go here for the maintained version. http://forums.bimmerforums.com/forum...1#post26757741
    After so many times people asking what bulb goes where, I decided to create a comprehensive list of lamps and where they are used in the car. This should be fairly accurate. Please post any corrections in this thread and I'll update the chart.
    Code:
                                                            Osram/
    Location                           Qty Specs   Generic Sylvania BMW         Comments
    Headlights - Sealed Beam, Low       2  35/35W  H5006   H5006    63121468226
    Headlights - Sealed Beam, High      2  50W     H5001   H5001    63121468272
    Headlights - US Ellipsoids, Lo      2  51W     HB4     9006     63217160786
    Headlights - US Ellipsoids, High    2  60W     HB3     9005     63217160785
    Headlights - Euro Ellipsoids, Low   2  55W     H1      64150    63217160777
    Headlights - Euro Ellipsoids, High  2  55W     H1      64150    63217160777
    Headlights - Euro Ellipsoids, City  2  5W      W5W     2825     63217160797
    Fog                                 2  55W     H3      64151    63217160779
    Front Marker/Turn                   2  21/5W   P21-5W  7528     63217160793
    Side Markers (Early)                4  4W      T4W     3893     07509063576
    Side Markers (Late)                 4  5W      W5W     2825     63217160797
    Tail (Early)                        2  10W     R10W    5008     07119905337
    Tail (Late)                         2  5W      R5W     5007     07119905336
    Rear Turn                           2  21W     P21W    7506     63217160789
    Stop                                2  21W     P21W    7506     63217160789
    Back-up                             2  21W     P21W    7506     63217160789
    High Stop                           1  21W     P21W    7506     63217160789
    High Stop - Cabrio                  1  18W             921      63251372632
    Euro Rear Fog                       2  21W     P21W    7506     63217160789
    License Plate                       2  5W      C5W     6418     63217160805 Festoon 37x11
    Glove Box                           1  5W      C5W     6418     63217160805 Festoon 37x11
    Dome                                2  10W     C10W    6411     63217160912 Festoon 41x11
    Dome - Convertible                  1  5W      H5W     64111    63311374798 Light next to check panel
    Trunk                               1  5W      C5W     6418     63217160805 Festoon 37x11
    Ashtrays - Front and Rear           2  1.2W    W1.2W   2721     63217167000
    Mirror Map Light                    2  10W     H10W    64113    63311375003
    Mirror Map Light (Alternate)        2  5W      H5W     64111    63311374798 I've seen recommendations to reduce wattage to 5W
    Instrument - Wedge Base            ?3  1.2W    W1.2W   2721     63217167000
    Instrument - Plastic Base          ?13 1.2W            2721MF   62111368299
    Instrument - Illumination           2  3W      W3W     2821     07119905358
    Light Switch                        1  1.2W    W1.2W   2721     63217167000
    Shifter - Automatic                 1  1.2W    W1.2W   2721     63217167000
    Check Panel                         1+ 1.2W            2721MF   62111368299 1 + 1 for each large indicator (e.g. seatbelt)
    Digital Clock                       1  1.2W            2721MF   62111368299
    Digital Clock/Temp                  1  1.2W            2721MF   62111368299
    OBC - Buttons                       1  1.2W            2721MF   62111368299
    OBC - Backlight                     1                           65811375461 Light bar
    HVAC Panel                          2  1.2W    W1.2W   2721     63217167000
    If a bulb is not listed here and it's one of the tiny lamps, it's most likely
    a 2721 or 2721MF. Some switches have replaceable bulbs that are not listed.
    Last edited by richardodn; 02-23-2014 at 07:27 AM. Reason: Fixed PN for W3W, added listing for cabrio dome light
    "Howdy, Folks!"
    Jun 2005
    Martinsburg, WV
    01 530i 02 325Xi BEV EVC
    Excellent resource - thank you.
    Joe M in WV
    Columbus, In
    1989 325i Sedan
    Cool
    Good deal, thank you.
    If I can't stuff young Mr. Johnson up the tailpipe, I don't want it ...
    Sep 2010
    Fresno, CA
    87 88 325i cabrio 89 325
    This should have a sticky, great resource!
    Jun 2005
    S.E. PA -Ex S.W. Florida
    1992 850i -- 1991 318is
    Nice job...
    Member #18 of M42Club.com
    1991 318is Diamantschwarz Black on Black (Ammana)
    1992 850i Calypsorot Met. on Black (Brenda)
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Your welcome and thanks everyone. Now to do the same for the E28 and E36.
    "Howdy, Folks!"
    Apr 2006
    IL - 60499
    99 M Rdstr, 92 325ic,
    I am interested in knowing what LED's are being used to replace the bulbs in the light bar for the OBC. If I remember correctly, there is a resistor/LED combo that is used. Looking for the wattage on stock light bar bulbs, and size of the LED.
    Aug 2008
    The Shore, VA
    '86 325 '94 Ranger
    sticky!!!!
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Quote Originally Posted by Wojtek79 View Post
    Can't help you with that one. There are cosmetic compromises that I don't want to make when you use the LEDs. Try searching the forum for "LED OBC" or google "BMW LED OBC" to get started.
    "Howdy, Folks!"
    Nov 2009
    Salt Lake City, Utah
    87 Cabrio
    You chart shows ash tray 2721 as nla, I've recently sourced this part from my local BMW dealer, but did not keep paperwork to see if it was the same pn, anyhow, these are still available...but perhaps under another p/n.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Quote Originally Posted by 87Cabrio89is View Post
    I'm not surprised. The original 63217167000 does not show up in the online catalogs. I'll have to look at some of my stuff at home and see if there was a supersession that wasn't updated correctly.
    "Howdy, Folks!"
    Nov 2009
    87 Cabrio
    Found receipt, you have the correct pn
    Quote Originally Posted by richardodn View Post
    $4.14 for two on 16nov10 - gear selector lighting working again
    Riverside, CA
    '86es/'87is/'89i/'98ti
    This was very helpful Richard! Gonna grab some bulbs for the new OBC tomorrow...
    Jul 2006
    Syracuse, NY
    89 325ix - 02 M3
    Awsomeeee stuff thanks!
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    You're all welcome. I'm glad it helped out.
    I also edited the list to indicate the availability of 63217167000 (2721)
    "Howdy, Folks!"
    Dec 2008
    Las Vegas NV
    91 318i 04 325i
    sticky...sticky...sticky
    On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
    May 2010
    Asheville, NC
    535is, 325iC, 325iX, 318
    Anyone know what bulb is used for the convertible dome light? Don't see it on the list but maybe I'm missing it. It's not the typical festoon bulb. I need to order a few and my vert is currently garaged a couple hours away. Thanks.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    I'm not too familiar with the convertible, but I assume it's in the overhead panel above the windshield. I'll see what I can find.
    I couldn't find anything specifically on the cabrio dome light. If it's not a festoon bulb, could it be one like this?
    http://www.autohausaz.com/search/ima...3311375003.jpg
    This is the halogen bulb used in the rear view mirror map lights. If it is, it's PN 63311375003 (Sylvania 64113) and is a 10W bulb. I've seen suggestions to lower the wattage for the map lights to 5W due to heat. That is Sylvania 64111.
    "Howdy, Folks!"
    May 2010
    Asheville, NC
    It is in the overhead check panel above the windshield, it's a single non-festoon bulb. It's been a while but I think it does look similar to the halogen bulb you linked but I think the top of the bulb has a smooth domed surface, not the pointed one that you linked. I may be wrong. Thanks for the help, this thread has been very useful to me and I've got it bookmarked.
    Sep 2009
    Chile
    320i 1985 Coupe
    Thanks Richard, this is very helpful for everybody. As a matter of fact I was looking into this bulb too. I searched this number in pelican parts catalog and it throws a 1,2 w bulb that is sold without the base.
    German cars, Italian wifes, never the opposite!
    Dec 2011
    Raleigh, NC
    1990 325I
    Yeah I'mma subscribe to this one for future reference.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    With few exceptions, if it's a 1.2W bulb with no base in a BMW, it's the 2721. (BMW PN 63217167000) If it has the base it's the 2721MF. Personally, I keep a stock of these on hand as they're so common in BMWs and you can't find them in stores. They're also cheap as dirt at autohausaz.com
    "Howdy, Folks!"
    Sep 2009
    Chile
    320i 1985 Coupe
    I canīt find them in this long and thin piece of land....
    The 50th State
    1986 BMW 325e
    I agree...this should definitely be a sticky!
    Dec 2011
    Winnie
    1990 325is
    Which bulb is it that goes in the AC & Recirculate switches? I think its the 2721 but im not 100% sure enough to go ahead and order them.
