Do you have any 25mm front sway bar bushings?
Jester,
I was trying to take off the trailing arms this weekend, before dropping the rear subframe. I know that the trailing arms can stay attached when dropping the subframe, but since I'm restoring all the components, I figured it would make sense to separate them now. Anyway, I can't pull the trailing arms until I disconnect the e-brake within the drum assembly. Problem is that both drums are rusted pretty solid to the hub. Any suggestions besides lubricant and beating the crap out of it with a mallet?
I have a great puller, but the arms on it aren't long enough to get around the edges of the drums. Hitting the drum to unseat it from the hub has proved to be unproductive. Considering that this car sat for 10 years, I was expecting this to be a huge PITA and it hasn't disappointed me yet. Everything I do to it takes twice as long because it's hasn't moved in years.
I am going to get those drums off, somehow, and then drop the subframe so I can send you the mounts. I'm ready to buy the lot, so I'll be making payment through Paypal before the week is out.
Thanks!
>Nick
PM sent
......... 3.8L V6 + T04Z + 15psi + e85 = 500rwhp - 10sec 1/4 mile - Hopefully .........
I'll just set the drums on fire; thanks for the advice!
M10 motor mounts?
Attila, the m10 mounts could easily be filled in the same way subframe mounts are filled. I've thought about doing mine but don't want to add any more harshness to the drivetrain.
PM sent regarding my solution to this last time I encountered this same exact problem. Without the need of a torch.
They are in the planning stages. They will be offered soon for the M10, I love them on my M20. The M10 bushings are just a little more complicated than the m20s...
yes, I am starting from scratch. Primarily because there is so much rubber mixed in with the steel, and from the mounts I've had to examine, they all look significantly deteriorated. There really isn't a good way to to solve both of the problems of the OEM design with just a filler. The filler will resolve compression, but not tensile loads. Because of this, I believe that the urethane will break the bonds with the steel and rubber and eventually fall out from vibrations.
If I decided not to start from scratch, the easiest thing to do would be to just create an insert for the upper hole. This would significantly reduce my build time and cost.
Maybe I am in left field here, but if you are going to build a urethane motor mount and want it to really make a noticeable difference, I think that the stock design needs to be thrown away and a fresh look taken. Similar to the 2002 mounts that are on the market.
In addition, filling the OEM mounts means cores for me and that is always difficult for both me and the buyer. I think that by a little more than the difference in shipping costs for cores, I can build a completely new mount that will be far superior, and the lack of core hassle will make it worthwhile.
Maybe I will try an insert & send it to you for some R&R...
John, you're crazy. I catch something on fire one time in your garage with MAP gas & you seem to relate that to every time I have pulled your sorry butt out of a bind. next time we are going to learn about body work with MAP gas
Got it, Jester; thanks! Any chance that the M10 OEM engine mounts are vulcanized rubber?
Just curious if the manufacturer used something different than the standard rubber found elsewhere on the bushings of this car.
Finally got a chance to install the rear sway bar bushings. Love the red. This has got to be good for an additional 5-7% horsepower gain.
Build Thread ---------- For Sale Thread
Got my Old Style control arms in the other day, and Man they look awesome...
Can wait to put all this stuff on.
The only thing now I worry is that I am going to be a much harsher ride than before, but other than that I an running Jesters products all over my car.
I got urethane bushings up the wazoo!!!
"..Horsepower is a measure of work done over time, or the rate at which work is done."
http://www.cardomain.com/ride/579694/1
Jester, i´m very interested in some parts, how can i contact you?
Sorry, I just saw this. You can send me a Private Message through here, or email me at
jln AT wrgd DOT com
or
the_nemecs AT frontier DOT com
Just a random question that might fit in this thread.
For those who did the steering rack bushings with c-clamps, roughly what size clamps did you use?
