- Hood Latch
Hood Latch
Since i purchased my E38 i always had a hard time opening the hood. I have to pull the lever from the inside twice for the hood to open. Is there an adjustment i can make so my hood will open without me pulling on the inside lever twice? Sometimes it does not open at all and i have to go pull up on the hood and then run back and pull on the inside lever like 2 or 3 more times. Is this normal for the E38?
John
You might need to adjust the hood pins. There are two of them and they can be raised by unscrewing them. Often the springs wear or break out of the bottom and it causes the hood to not pop up when the release is pulled.
51-24-8-187-291 BUFFER STOP with ejector
$4.08 each plus shipping at Crevier, probably about $8 at my local dealer.
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to a new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Are they easy to replace? Can you E-mail me the ETK for the replacement? If you can.
John
Now that's my kind of repair!! With that being said I would prefer that mine don't break...
Diver
2000 740iL
So you think by replacing these 2 items i will not have the problem with the hood anymore? I thought it would be a lot more to it than just this.
John
Mark, you are me hero. I just unscrewed them a bit, now works like a charm. Again thank you so much Mark.
John
Ha! You owe me $89.00 for one hour labor!
A little WD40 helps. Check if you have more problems, as you may see the spring has broken through the bottom.
M.Wong
I am having the same problem with mine thanks:
USN RETIRED
I am telling you Mark is a great guy. He has a lot of knowledge about these E38's. Again thanks Mark.
John
P.S.
Where do i send the check to?
kickass - just found this thread and had the same issue on my E39. Loosening up the hood pins a bit did the trick - been bugging the crap out of me. Thanks!
Remember if the pins are not sticking up when the hood is open, you need to replace them! I've seen some where the pin itself isn't popping up and people have unscrewed the assembly just to have the rubber surround actually trying to lift the hood!
They are so blasted cheap, if your pin isn't stickin up and is stuck in the rubber surround, replace it!
2001 740i Sport Black on Black, 16:9 Nav, Basslink, M-Pars, Chrome Strong Strut, Quad Brake Lights, Crystal Tails, Solaris Signals and Back Up Lights, Power Folding Mirrors, Chrome Guage Rings, Chromeline Headlights, CCFL DDE's, Euro Rear Fog Light Switch, Carbon Fiber Pedals, RevHigh CAI, M5 Style Trunk Lip Spoiler, Blacked out '97 Grills, White and Black C.F. Roundels, HID Fog Lights, Magnaflow Street SS 14816 Mufflers, DICE HD Radio, iPod, Sirius Satellite, Brembo Cross Drilled Rotors, New Painted Calipers, SS Brake Lines, MKIV Nav Computer. Coming soon: Bluetooth.
1988 325iC Triple Black, in restoration process.
1984 633CSi Black on Black - Shark Perfection
- You may not post replies
- You may not edit your posts
Forum Rules
