- E46 Coolant Leak - HELP!
First time on the forum and hope someone has had this issue and could help...coolant leak coming out of exp tank cap after car is up to operating temperature. Cap, and exp tank are brand new. Could it be the thermostat?
2001 325xi
If you just topped off the cooling system it may just be extra coolant bleeding from the system. If the problem persists you might want to check and see if the cap is seated properly. Hope this helps, GL.
- You may not post replies
- You may not edit your posts
Forum Rules
