///EAC - Collapsible Water Pipe Kit for BMW N73 V12 Engines
EAC has recently added a collapsible water pipe kit from AGA which fits BMW models with the N73 V12. This pipe connects to the water pump and rear engine block. Over time, the integrated front seal of the original pipe can start to leak causing coolant to leak into the engine valley pan and out the front timing cover.
Part# 09 8042 020
Applications:
2004-2006 760i (E65)
2003-2008 760Li (E66)
The original repair is very costly, and extremely time consuming, calling for the removal of the engine, heads, upper & lower oil pans, and more.
AGA has designed a collapsible water pipe that can be installed by an experienced technician in under 10 hours!
Full article:
http://www.eaceuroparts.com/content/...3-v12-engines/
Thanks!
Jared
EAC Euro Parts
Site: http://www.EACeuroparts.com
Facebook: http://www.facebook.com/EACeuroparts
Twitter: http://twitter.com/#!/eaceuroparts
Articles/DIYs/Parts lists: http://www.eaceuroparts.com/content
"If everything seems under control, you're not going fast enough. - Mario Andretti"
