Originally Posted by
bricel24
Sorry to bring up this old thread but it's better that starting a new one.
I just bought a 92 535i last week and the horn does not work. I have visited this writeup lots of times, going thru every step posted in this thread, troubleshooting every possible angle possible for a few days now. Here's what I have done:
*Tested ground from the door hinge to the carbon pin, horn works. That eliminates the possibility of a bad fuse and relay.
*There is continuity from the door hinge when grounded to the steering wheel, horn works as well.
*Cleaned ALL contacts and points of contacts including ground terminals, carbon pin and back of the slip ring.
*Bought a slip ring from PnP today, along with a steering wheel as well ($38 for both) -- slapped it on, plugged in the airbag and placed the airbag in with the torx screws in the back halfway in. Pressed the contact points in front of the airbag and it WORKED! However, after I tightened the torx screws all the way in, it stopped working again!!!
Tried to troubleshoot again, could not reproduce it. Kinda gave up for today.
Any thoughts?
