I just rebuilt an s52 and am getting ready to put it in, and thought about the issue of timing, is there a way to set the timing without using bmw special tools?
(this thread is here because im sure the majority of people who know about this frequent the FI section.)
-Andrew Mensah
you could make the template for the cam tool that is in the bently manual. I think it also has dimensions for the FW lock pin.
Just rent them from someone for a few bucks and Your good to go or if You think that You'll be timing these motors, just buy the set-up, use it then rent it. It will pay for itself in no time.
"If you can leave black marks from the time you exit a corner till the time you brake for the next turn, then you have enough horsepower." --Mark Donohue
When I did mine I just went ahead and bought it. Although my FW lock pin didnt fit. I ended up haviing to use a punch. I would say just buy it but after you see what the tool looks like you think man, that could be machined in about 30 seconds with a mill. but whatever . I had the money at the time so I just got it .
Alpine White --- E46 M3 --- Maximum PSI --- Precision 6266 --- Custom 3" Exhaust --- Statusgruppe --- Varrstoen ---
The rest is just smoke and tires
-Snails- The real reason the tortoise beat the hare.-
Get the tools off ebay - its easier. And yes, if you set your cams without the tools, you will be buying valves unless you're a freak and can see a cam lob a couple degrees off while on an angle in an engine bay
yup get the tools.
FW lock you can use a socket extension or punch as stated above. On the cam timing chain, you can use a nail to lock down the tensioner.
You guys better not give the OP a hard time.
I wouldn't rig the flywheel lock - mine have always fit, they need to be pretty darn exact if you actually want the motor at tdc. Not locking the flywheel at tdc is as risky as not putting the cams in square.
Yeah s long as the thing isn't pointed/tapered. The flywheel lock is not tapered, and then is undercut to a nipple at the end that is also not tapered. With a punch, you could stick it in there and have it an an angle and be "lined up" The tool should fit its not hard to make I have a few and haven't had an issue.
-Andrew Mensah
Any trouble's getting the exhaust sprocket onto the exhuast cam after a .140 headgasket?
Didn't seem as if the chain was a tiny bit short? Slipped right on with plenty of slack?
Use a straightedge and be done.
Get the tools. End of story. Even with the proper tools, it's hit or miss getting it right.
a.) Set timing.
b.) Spin engine a few times
c.) Check timing.
d.) Cuss at engine because it is slightly off and needs set again.
e.) Repeat
Seriously, I did that about 10 times before I was 100% happy with the results. Just remember that if your VANOS is sliding properly, that it's going to move a slight bit as you turn your exhaust cam - this is normal and a-ok as the VANOS controls the position of the intake cam (within reason) as long as you initially set it correct.
That makes me hope to god mines right.. I only did it once.. it ran fairly normally although I had a bad maf at the time.. don't make me nervousOriginally Posted by mcoupemindy
how do you check if your vanos is timed right ? I had a lot of trouble getting mine to rotate. We fabbed up a tool that was kind of ancient but it worked out. Hope it works =/
Take the VANOS unit off the car. Use the cam timing tools and set both the intake and exhaust Now, with the cams locked with the timing tools, push the plunger on the VANOS all the way in and push onto the intake cam. The due to lining up the plunger will move out a hair or two (normal). If your VANOS plunger is almost completely in when the cams are both locked with the timing tools, it's correct. The exhaust is MUCH more important to time nuts on.
If you were Charlie Sheen you could set them with your mind.
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
I set my m52 and s50 euro without cam tools, just a ruler for the m52 to make sure both cams are lined. S50 has timing marks.
I'm not an expert but I did it as well.
It is hard to find timing tools in my country.
