I am trying to change my clock in my 2000 323ci convertible. The display mode next to he odometer is stuck on the temperature. I keep pressing in the button on the left of the steering wheel to change the display mode to the clock so I can change the time, but the display mode does not change. Does anyone know why this is happening?
Thank you.
On my 2000 328ci the button to change the time, temp, travel meter etc. is on my turn signal lever. It's the button on the tip with an arrow. Not sure if this helps...............?
Is your car off and the key in ignition postion 1?
yes, i think so. i put the key in and then one click to the right. is that position 1? and isn't the display supposed to change also when the car is on?
Yes, that is correct. It should still be able to cycle through also, both when the car is on and off. I believe when it show the clock on the obc, you should push the needle on the right of the steering wheel, and hold it down for a few seconds. Then you can twist the needle to the left or right to adjust the time.
clock does not show. only thermometer. can't switch it out of thermometer mode. and when i press button on dash to the right of steering wheel, it changes from farhenheit to celsius. can't get clock.
I am actually having the same problem. I think my OBC button on my signal stalk is faulty. I'm gonna eventually order a used one off ebay to replace it, hopefully thats all it is.
yes i am using the BC button. it doesn't do anything.
Same issue guys, did replacing it help?
