Page 5 of 31 FirstFirst 12345678910111213141530 ... LastLast
Results 101 to 125 of 767
Thread: Finally Picked up My M3 LS1 Swap Candidate :)
  1. #101
    Mar 2011
    Dallas, TX
    2008 535i
    Going back to my swap.
    I got my new 7.325 pushrods. Got the valvetrain assembled, valve covers back on the motor.
    Just picked up my resurfaced flywheel. New Slave Cylinder from Autozone (Thanks Tongboy)
    Waiting for my Braap Modified clutch line.
    Going to remove the subframe next and weld reinforcement plates for the motor mounts.
    Got my new walbro fuel pump, going to install it this week and finish the fuel lines.
  2. #102
    Costa Mesa, Ca
    93 BMW 740i
    thanks for the info, good luck with the rest of the build. I would like to check it out when its done, I am in south OC often... and sorry about kind of thread jackin'
  3. #103
    Mar 2011
    Dallas, TX
    2008 535i
    Finally got the motor installed. Still waiting for the headers and driveshaft, but at least I can get the rest of the stuff done. I am very happy with the new age hotrods mounting kit. Everything lines up great, good clearances all around.
    New ACT clutch and new chromoly flywheel being installed.
    Ready to go in!, yes the motor mount bracket is in the wrong position! It was fixed before proceeding
    New Age Hotrods motor mounts.
  4. #104
    Oct 2007
    jacksonville, fl
    e36 m3 Ls2, 318I, 325is
    looking good!!!
  5. #105
    Jul 2003
    Irvine, CA
    97' M3 Coupe
    Those mounts look nice. My car is finally running. I think. Just need to get it aligned, and I'll be able to drive it daily.
    You're smart, and did the clutch before putting it in the car. I did it with the engine already in the car. Not fun, to say the least, haha.
  6. #106
    Mar 2011
    Dallas, TX
    2008 535i
    Bring your car over! I'd love to get a ride in it
  7. #107
    Jul 2003
    Irvine, CA
    97' M3 Coupe
    PM me your address and number. I can drop by on my way to get gas later. I don't have a passenger seat belt installed yet, but you can check out the car.
    -Don
  8. #108
    Oct 2008
    Orange County California
    Stuff N Things
    Im in the area, can i come by and check it out? I have a turbo car that im very much considering putting a V8 in.
  9. #109
    Mar 2011
    Dallas, TX
    2008 535i
    Sure, PM me.
  10. #110
    M5Hunter is offline Still has a E39 Supporting Vendor
    Nov 2009
    Hanover, VA
    E39
    Looks good! Is there room to mount the stock A/C compressor with the NAHR mounts?
  11. #111
    Mar 2011
    Dallas, TX
    2008 535i
    yes, but not much clearance. Would have to pull the engine to remove the AC compressor.
  12. #112
    Sep 2010
    Poland,ME,USA
    1998 m3 3/4/5 LS1/t56
    I am about as far along as you are with the swap. Just wondering what you did for heater core hoses. I just bougt some line from autozone, but its the stuff off the roll. Where the line makes the 90ish degree bends comming out of the fire wall are you able to use universal hose? or should i look for prebent pieces?
  13. #113
    Nov 2009
    Hanover, VA
    E39
    I used the stock bends and used a coupler to connect the heater hose to it.
  14. #114
    Mar 2004
    USA
    96 328is 6.0L
    I went to the back of either Advanced or PepBoys and found prebent hoses. Ask them to let you go in the back to find a hose and they have no problems with it.
  15. #115
    Mar 2011
    Dallas, TX
    2008 535i
    I stole Tongboy's idea and used his part numbers to order prebent hose from rockauto.
    I ordered 4 of them.
    GATES 28472 Heater Hose $ 12.03 $ 0.00 2 $ 24.06
    GATES 28480 Heater Hose $ 12.95 $ 0.00 2 $ 25.90
    So much easier and you don't have to use any couplers.
    Btw what kind of hoses did you guys use for the low pressure brake reservoir to the ABS pump?
  16. #116
    Mar 2004
    USA
    96 328is 6.0L
    The low pres brake line must be something that can handle brake fluid otherwise it will eat it through very quickly. I found some locally that was intended for VW
  17. #117
    Nov 2009
    Hanover, VA
    E39
    I cut the hose in half and used hard line to connect them
  18. #118
    Sep 2010
    Poland,ME,USA
    i am unsure if the line i bought is up for the job. but i found trans cooler line. the salesmen at the hose supplier i use for hydraulic equipment said it is up to the task as it is very low pressure. Still unsure if the line is dot compatible
  19. #119
    Jun 2005
    Portland, Oregon
    04 Allroad, F20c Lotus 7
    use low pressure power steering line or hydraulic fluid return hose, transmission cooler also works - basically anything oil approved low pressure and you'll be fine.
    I still need to order the longer coolant hoses so I don't have the couplers in the lines unneccessarily
  20. #120
    Mar 2011
    Dallas, TX
    2008 535i
    Got headers finally They look pretty nice! Should have them on the car this weekend.
    Driveshaft arrived today
  21. #121
    Mar 2011
    Dallas, TX
    2008 535i
    OK, this weekend I was going to install the headers and the engine for the final time. Run into some clearance issues.
    The nahr headers are a total pain in the ass, they can only be installed with engine out of the car and even then i am having clearance issues with passenger header and oil pan.
    I was hoping to use a GM ac compressor, but it's hitting the frame rail. I am most likely going to hammer it in a bit to create some space.
    AC Clearance
    Header hitting the oil pan.
  22. #122
    Nov 2009
    Hanover, VA
    E39
    I thought it looked a little tight for the A/C in there. I dont think there are any headers that will fit the drivers side and go in and out with the motor in. I am disapointed to see the oil pan clearence issue. I would have them take care of that if it was part of thier kit.
  23. #123
    Jun 2005
    Portland, Oregon
    How are you guys putting your headers on?
    I put the motor in then the headers then the steering rod/shaft...I thought that was normal...
    I thought the nahr guys always called for the 318 compressor, which is of course smaller.
  24. #124
    Mar 2011
    Dallas, TX
    2008 535i
    They do use the smaller compressor, but I did ask if I could use the GM one, he said there should be some space. Some = none.
    It's not the end of the world, not the last time I will use a BFH on the car lol
    Nahr headers go around the motor mount, they are impossible to install with engine installed.
  25. #125
    Jun 2004
    PA
    Too many to list...
    Is it possible the one tube that hits the pan was installed improperly in the jig prior to them welding? I mean it doesn't even look remotely in the correct location.
    Doug
    '97 M3/4
