Page 3 of 31 FirstFirst 1234567891011121328 ... LastLast
Results 51 to 75 of 767
Thread: Finally Picked up My M3 LS1 Swap Candidate :)
  1. #51
    Mar 2011
    Dallas, TX
    2008 535i
    Haha, oh well
  2. #52
    Mar 2011
    Dallas, TX
    2008 535i
    Took the car apart today. What a pain in the ass. Got everything disconnected and the whole front end removed.
    Only thing left is yank out the motor, but the wife was getting angry so it has to wait until tomorrow.
    Speaking of yanking the motor, where is a good spot to attach the hoist in the back of the engine?
  3. #53
    Sep 2010
    Poland,ME,USA
    1998 m3 3/4/5 LS1/t56
    when i pulled mine i removed one of the larger bell housing bolts and with a couple washers pinched a hook between the washers and housing
  4. #54
    Jun 2005
    Portland, Oregon
    04 Allroad, F20c Lotus 7
    Quote Originally Posted by birdman2447 View Post
    same way I did mine, just make sure you have an a good selection of inverted torx sockets
  5. #55
    Jul 2003
    Irvine, CA
    97' M3 Coupe
    If you have latches, there's a hole at the back of the block that you can loop it through.
  6. #56
    Mar 2011
    Dallas, TX
    2008 535i
    I only have a shitty pep boys leveler.
  7. #57
    Mar 2004
    USA
    96 328is 6.0L
    I always used rear section of exhaust manifolds
  8. #58
    Mar 2011
    Dallas, TX
    2008 535i
    Thanks for the tip, I ended up using exhaust manifold and jack to keep it balanced.
    Ready to come out!
    Finally!
    All empty.
    Had to fit all this crap back in the garage. No space lol!
    Btw, anyone ship a S52 + transmission? I need to put it on a pallet for pickup, but it won't fit attached and has tendency to fall over lol.
    Also where do you buy reverse torx bits?
  9. #59
    RTP Area, NC
    2010 335i
    Quote Originally Posted by Kaane View Post
    I just slipped normal sockets over them, the 6 point kind, but harbor freight is a good place if your only going to use them a few times
    2010 - BMW 335i M-Sport - Lemans Blue Metallic
    BMW PPK2, JB4 with NLS, Backend Flash, BMW PP Exhaust, Misc Appearance Mods, Boost Addictions Diff Brace, BMS DCIs, BMS Clutch Stop, VRSF Catless DPs
    Previous:
    1995 M3
    1998 323is
  10. #60
    Jun 2005
    Portland, Oregon
    sears sells a lisle complete set for not much cash and they'll warranty them in store (or at least they've told me they would.)
  11. #61
    Mar 2011
    Dallas, TX
    2008 535i
    Shipped my old motor out today, now I have some space in the garage
    I ended up getting an ACT clutch. Rated for 725lbs/tq. Ordered Ford 30lb injectors.
    Corvette FPR arrived today. Terminator Heads are at West Coast cylinder heads getting cleaned and inspected.
    Vorshlag mounts should be here by the end of the week.
    Ordered a new oil pressure switch and coolant temp sensor, since I sent my originals with the motor.
    Going to start doing the brake lines and fuel lines while waiting for parts.
  12. #62
    Oct 2007
    jacksonville, fl
    e36 m3 Ls2, 318I, 325is
    moving pretty fast!!!! keep it up
  13. #63
    Mar 2011
    Dallas, TX
    2008 535i
    I am trying to order all my brake related stuff to relocate the abs module.
    Can someone tell me all the fittings they used?
    Line is 3/16
    I know it's all Iso bubble flare.
    So M10 1.0 tube nuts? M10 1.0 Union?
    I noticed that some fittings are larger? Are they M12? What union for those?
  14. #64
    Mar 2004
    USA
    96 328is 6.0L
    It looks like you have it under contrl.
    I don't remember the nuts 100%, but to the best of my memmory, the smaller ones are like you said M10X1.0 the bigger ones are M12X1.0. The line is 3/16 or 4.75mm.
    Make sure that when you get the unions, you buy steel ones and not the brass. Brass will strip before you will be able to tie it up. Also, make sure you buy unions for bubble flare as there are different types of unions. For the lines that have M12 bolts on ABS side, just use M10 for the union side.
    This stuff is pretty cheap at PepGirls and Advanced
  15. #65
    Mar 2011
    Dallas, TX
    2008 535i
    M12 bolts would need a M12 union?
    Or use a M12 to M10 union?
  16. #66
    Mar 2004
    USA
    96 328is 6.0L
    I had problems finding M12 unions, so I just cut off BMW side M12 and put M10 so I could just use another M10 union.
  17. #67
    Mar 2011
    Dallas, TX
    2008 535i
    true, I did get a new iso flare tool. I guess I can reflare it.
  18. #68
    Mar 2004
    USA
    96 328is 6.0L
    Just remember to do couple of practice flares before you cut off BMW side
    Here is what I did to mine. The BMW side is a little mangled up, because initally I was trying to bend the lines to get the ABS unit stuffed higher up, under master cyl. and then finally moved it forward.
  19. #69
    Mar 2011
    Dallas, TX
    2008 535i
    Has anyone else found a M12 1.0 union for 4.75mm Line? It would be nice not to have to cut off those factory fittings.
  20. #70
    Jun 2005
    Portland, Oregon
    you're asking about two different things - do you want an m12x1.0 union - as in already has connectors on both sides and you're just connecting? any auto parts store should stock those.
    do not use compression fittings on brake systems - I did for a little while and i'm sure plenty of others have as well but if you have the option or for the long term it is the incorrect way to do brake lines.
    also I don't remember which swap kit you ended up going with but with the samberg kit you're going to have those lines along the frame rail right at the corner "piece" be way too close to the header potentially even touch it - I had to run mine along the frame rail bottom up to the master cylinder to clear the heat zone
  21. #71
    Mar 2011
    Dallas, TX
    2008 535i
    I am not using compression fittings. Just an union between two M12 1.0 tube fittings.
    I am using Vorshlag mounts and will be using their headers as well.
  22. #72
    Jul 2003
    Irvine, CA
    97' M3 Coupe
    Nice progress. Don't let Irvine's HOA catch you, haha.
  23. #73
    Mar 2011
    Dallas, TX
    2008 535i
    haha no shit, they are evil. I have to hide everything nightly.
  24. #74
    Mar 2011
    Dallas, TX
    2008 535i
    I've been looking some more for those M12 1.0 Bubble Flare unions and I can't find one. Did everyone cut their lines like Bimerok and reflare them using M10 1.0 nuts?
  25. #75
    Mar 2004
    USA
    96 328is 6.0L
    Don't be afraid to cut them off. You disassembled half of the car and worry about the fittings? You're not going back now and putting the engine and ABS back, so there is no difference whether to flare new line or existing BMW.
