Im starting the building process of an S42B20 tomorrow. Im getting a complete block for $166, yes I have contacts and they are legal. Im also getting 86.5mm M3 pistons for $166. I will also get a cyl head and build it up for the high revving I will be doing. I have a long process ahead of me but it will be fun.
Tom - are there any changes necessary to the intake manifold to get more air in for the stroker?
Gizmo - definitely keep us posted!
What crankshaft are you going to use? A custom one? Are you going to start with a stock M42 head and convert it to solid lifters?
It's about time someone did this!
Hope everything goes smoothly
And DEFINATELY keep us updated
"Aerodynamics is for those who cannot manufacture good engines." - Enzo Ferrari
"A Gentleman does not motor about after dark" -Joseph Lucas
how exactly would the crank be modified?Originally Posted by 943184dr
I call BS - there's no bmw driver that can't run his car faster than any magazine has ever done before.
-Joe
make sure to post updates and LOTS of pics!
BMWMOFO C6MPACT
Yeah, definitely keep us updated on this.
Originally Posted by GDB
This would be accomplished by modifying the lobes and installing larger bearings. and as far as the intake manifold you may want to get one of my custom build units but I think if all you did was the stroker you should be fine with the stock one but i'm not sure
Tom
Tom, I am interested in your intake manifold setup, and possibly the stroker, as they say there is no replacement for displacementOriginally Posted by 943184dr
I am sure alot of us here are the forum would be interested in pictures of your intake manifold, what is done to the manifold? Is it just ported and polished stock manifold or a custom fabbed manifold and how much more does it flow over the stock manifold, and are there still provisions for the intake manifold runner switch over?
Also if you are modifying the lobes on the crankshaft and making them larger, with larger bearings, you will need custom connecting rods to accompany the larger bearings.
As for the intake manifold that I can have under development as soon as my car is up and running. It would be a custom built peice forming an entirely new manifold out of billet alum. that would utilize a standard shape TB. This will be prototype on my turbo motor as soon as money comes along. it would have individual runners and a new injector runner as well. I can come up with pricing if you all would like for the intake manifold but unfortunatly wont be built for a little while unless someone wants to place an order for as soon as the car can move under its own power i can have it built.Originally Posted by Tiperformance
As for the crank, all you would need is larger bearings i beleive. This is a kit that my source has you choose the specs of the pistons and send them a crank i beleive then a few weeks later you get a stroker kit. that is with my initial source but I am going to see if waterhouse will do it for me which then that would reduce the cost alot because you then wouldn't have to get pistons and it would be just a modified crank to increase displacement.
Tom
Any idea for what type of Tb you will be using. Will it be a BMW unit, or something from another car (mustang, camaro, etc).Originally Posted by 943184dr
-Joe
Most likely something cheap and very effective like a mustang tb.Originally Posted by GDB
Tom
Im going to be using the E36 M3 Euro ITBs, we have an abundence of 'em floating around in SA.
The block I have is the M44 which has an 85mm stroke to make it 1.9lt, with the 86.5mm M3 pistons it will be 2.0lt. Something I noticed is the M42 crank position sensor sits on the front pulley, whereas the M44 has it towards the back of the block, it picks it up on the no4 crank lobe.
Also, can someone tell me why the M42/M44 has a cam sensor and a crank sensor?
I will update the thread as I go along.
If you stroke the motor, you will need to get shorter rods at the very least. Otherwise you'll be wondering why your pistons suddenly pushed the head off the motor.Originally Posted by 943184dr
I'd love to see the intake in person once it is developed (I'm just a bit up the I-5 / I-405 corridor from you).
-Derek
'95 318i
These guys can do custom steel billet cranks . For a 4 cylinder, they are about $5K AUD - about $4K USD for an one off. Of course, they may be cheaper for a group buy ...Originally Posted by DerekVa
This is because the cam rotates at half engine speed which is required for sequential injection and one coil per cylinder ignition. The crank sensor is for rpmOriginally Posted by Gizmo316i
Yes pleaseOriginally Posted by Gizmo316i
Damn all this talk, now I want a S42
Got a new bimmer. 2006 e90. 330i. More to come. First big boy car.
Gizmo316i, i sent you a pm
Great thread guys! Lots of good information in there! Keep it up!
San Diego German Car Club; BMW Wiki - Support them and add content!
M42 Club Member #89; FS: (1) Sparco Milano racing seat
So i am wondering.
i'm sure it's possible to do a low compression 2.0L m42 motor built for lots of boost.
I am also a 318er and im going to buy a new car soon to use on a daily basis and my 318 will serve as a project mobile.
Anyone have an experience with m42's and FI
Here is an ecel spreadsheet with the M42's numbers using the listed modifications (in the sig). The run conditions are in the spreadsheet as well, in English & SI. The numbers are using a DIN correction factor.
This might come in handy for anyone looking to do...whatever...with the M42 & some performance numbers are needed.
Just wondering what the status is of this project.
BTW: this thread at e36coupe.com has some great info on an ITB setup using 2/3 of an Euro M3 S50 ITB set. Sounds like it would be perfect induction setup for an S42 replica motor--especially if you could get someone to fab a carbon fiber airbox for you (like an S14 touring car intake) and could kit up a Split Second MAF system as well.
-Derek
'95 318i
Refer to: http://forums.bimmerforums.com/forum...hlight=itb+m44Originally Posted by DerekVa
A carbon airbox would definitely be a nice upgrade. Hell, if I had the time and resources that would be a good project upgrade to make myself in adding to the ITB setup since the stock plenum isn't exactly a featherweight. Raw carbon fiber isn't cheap though.
anyone know what all differences are between the e36 m42 and the 1991 e30 m42 engines is? i know that the e30 motor didn't have a knock sensor and had a different intake and exhaust manifolds. is there anything else? as i'm found several motors and parts motors for sale but they are out of e30 cars so i'm not sure if they are usable as i need the same things as e36 cars (stronger)
Tom
That all depends on how the crank is modified, you can move the lobes further down allowing still enough clearance for the pistons to clear the head. but even if new rods would be needed I can get them for about 600 for chromoly rods and 800-1000 for titanium.Originally Posted by DerekVa
Tom
A bump - any updates?!
