I upgraded to 6.5" components in the kick panels. Should I discard the OEM baffle or trim it to fit?? Also, should I add Dynamat to the kick panel where the speaker is mounted?? And would Dynamat help inside the kick panel on the actual outer fender part?
I am just looking into what will be more beneficial. I am in the middle of my whole install.
Thanks,
Mike
Yes dynamat the kick panels:
What I eventually did was cut the back of the factory foam-insulation away so the speakers had a larger cavity, but still provided the insulation and dampening of the foam. Oh I dynamatted the whole area as well.
What is the biggest diameter of the speaker one could fit into e36 kick panels (with cutting obviously)?
Thanks.
