which 20v motor did you use?
How much HP do you estimate?
AEB out of 98 passat
this season going to be sweet
Should be about 250w @ 15lbs but capable of around 300 at 20lbs. Eventually I want to have a equal length exhaust manifold made and maybe intake.
I thoroughly enjoy that your car has a vw motor in it.
better have a oil pressure gauge . those motors like to have oil pump failures! but i approve of this thread forsure.
Very cool build man, nice work
1993 318i L33/T56 Swapped Drift Thingy L33 Blew Up Time For LS2
Your car is awesome, I've posted it somewhere before I think but here's a shot of it at First Class Fitment 2011. I'm excited to see this build come back to life (or the thread anyway).
ha when we arrived that day i remember looking over a few spots standing where my buddys corolla was showed and saying "hey theres that e30 that flew by us on the highway, huh"
anywho CIB 2012 was a better show.
i just found my calling!!!, i love the e30 platform and i love the 1.8t (as i own an e30 and a 20th AE GTI with a 1.8t) and ive said it numerous times that i would love to have a 1.8t in a RWD car in an e30 at that, and low and behold you did it! please post more pics and details, how did u get the 1.8t to bolt up to the W58 and what did u do for mounts?
So I put a 4.10 lsd in today. Love it! Such a difference compared to the 2.93 I had in there.
I took it out to a couple empty lots today to see how it was. I need to get used to the gearing but today was my first time ever being able to slide in third. Hopefully in the next few weeks I can get the ecu flashed and I will have good power. Currently I am onnly running 7lbs, stock MAF & stock injectors.
used the gopro while I was messing around.
[ame]http://youtu.be/Ljxds3xeM2M[/ame]
[ame]http://youtu.be/zxGWH0qeLro[/ame]
This is way cooler than all those other options ... can't wait to see it in person!
Yes! Car sounds awesome at low boost
video from an event we had this past weekend. I am quiet impressed. I was sticking to the rev limiter most of the time in second gear. I was running 235/50/17s and I just couldn't spin them enough in 3rd like when I have my 16s on.
ya it was a cool event. cold as hell.
but how did you like the 4.10? it sorted seemed like you were between gears all day.
just banging of limiter all day.
and what was up with the chu chu train smoke. ?
overall pretty sweet out there forsure.
Coming from the 2.9 I like the 4.10 a lot. With the big tires on the 17s I just couldn't keep them turning in 3rd. For the next event I am going to try some 215/40s. If I still can't turn them good in 3rd I can always turn the boost up, I was running 13lbs but tuned for 19, so I have room. At the same time early on with the 16s clicking third I found my self not able to scruff my speed enough and kept ending up in the grass in the back section of the lower course. So maybe the 4.10 is not ideal but I am not sure what I should try next, is there something higher? or I can go down to something in high 3's (not sure what the ratios are 3.73,3.90?)
As for the smoke I think its a bad valve seal. It ran just fine but as you saw, billowed smoke after a run. no smoking at idle, cruising or even during heavy throttle. Last week I had an injector stick open on me while I was cranking it over. Popped the head gasket & when I drained the oil after changing the head gasket there was just about 2 gallons of oil/gas mix. So I am giving my garage a much needed cleaning then pulling the head again to put some new seals in & have it all checked out. Should be fine for the next event.
It was my first time really driving/drifting it since the swap. sure I have done some small parking lot goofing but this was its first true test. I wasn't holding back and was quite impressed that I only broke a throttle cable.
another vid
I think a 3.73 would be much better for you
Highlight of my day
Asking you for some oil and you having a half quart in the engine bay!!!
I looked at some supra forums to see what they pair their w58s with and IIRC they run like 4.56's or higher.
I want to get a welded anyways so I will look out for a 3.73 and see how it does.
Yea I would agreed with a 3. something. Get more use out of 2nd. Can you get something like a 3.15?
And I like how you found my favorite pothole on the lower course!
with your motor issues worked out at 19psi you should be able to nuke 3rd pretty good with a 3.73 all day on 17s
So epic I want to do this swap real bad
