Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 102
Thread: E32 Suspension Thread
  1. #26
    Naperville, il
    1989 BMW 735i
    Not the greatest picture...
    but I hope this gives you an idea on what the drop looks like.
  2. #27
    San Francisco
    1990 325ic, 2006 Lexus SC430, 2007 Lexus LS460
    stephenyi - looks great!
    So I'm assuming it's possible to only lower the front and not adversely affect the handling dynamics of the car? The rear gap of my car looks OK stock but the front gap is like the grand canyon.
    2006 Lexus SC430 - The Wife's
    2007 Lexus LS460 - The Family Hauler
    1993 BMW 525i 5 speed Calypso - My Pet Project
    1993 BMW 525i Auto white - project #2
    1994 BMW 740il - project #3
    1992 BMW 525i Auto Green - project #4
  3. #28
    Noblesville, IN
    '89 735i/5, '97 M3
    Looks good. Where did you order from? Is there any change in ride?
  4. #29
    Naperville, il
    1989 BMW 735i
    Quote Originally Posted by nik77356 View Post
    I ordered the H&R springs and rear Bilsteins from Turner Motorsport and the front Konis from Tire Rack.
    I was afraid that the ride would stiffen up after the drop but I don't notice any additional harshness in normal driving. The Konis are set to 1 full turn from the softest setting. I definitely don't feel as much roll on higher speed turns. So overall, the suspension feels tighter without feeling harsh if that makes sense.
  5. #30
    Noblesville, IN
    '89 735i/5, '97 M3
    Is there a write-up anywhere on replacing the front control arms? I have ordered the parts already and am looking to do it sometime this week. If not, does anyone know if any special tools are required? I will do a write-up if there isn't one.
  6. #31
    Aug 2009
    Sioux Falls, SD USA
    84 528e 88 735i, 01 325i
    Rod Paine is the MAN!
    I don't know of one right offhand specifically for the e32, but Rod Paine has an excellent writeup for the e28, and there are a lot of commonalities between the two models. http://mysite.verizon.net/vze7aq8e/id18.html
  7. #32
    Vancouver, B.C., Canada
    750iL
    http://www.bmwe34.net/E34main/Mainte.../Upper_arm.htm
    Most E34 stuff is very relevant to E32s as they share a lot of the same suspension/engine/drivetrain.
    On an unrelated note, I'll post some pics of my E32 with newly installed Bilstein/Vogtlands. Other than looking far superior to stock, it feels like a completely different car. Well worth the investment, even if I did eat the labour costs to have it done at a shop.
  8. #33
    Noblesville, IN
    '89 735i/5, '97 M3
    Thanks guys! Both those links look like they will be very helpful. I will do a write-up as well when I do it.
  9. #34
    750iL
    As she sits:
  10. #35
    Nov 2010
    China/HongKong
    1994 BMW 740iL
    mine is this low:
    i just cut the hell out of the coils front (2) rear (3), and use 2 silicon rings each side in the rear to make it stiffer. rides perfect, and in the rear i can sit people with no problem
    OO=[ ][ ]=OO
    Quote Originally Posted by MCA View Post
    7er BMW > Econoboxes
  11. #36
    Earth
    E34 M5, E36 M3, E90 M3
    Dahnn, what shock are you using? stock? still have the sls? looks great btw!!
  12. #37
    Nov 2010
    China/HongKong
    1994 BMW 740iL
    im using stocks from 735i, i deleted the SLS :-)
    thanks for comment!
    OO=[ ][ ]=OO
  13. #38
    MD/DC/VA
    Many...
    Mine has Bilstien Sports front & rear with Racing Dynamics springs..
    Love the ride and handling but I have been eating upper strut bushings! BMW warrantied the first new set I tore through and I'm now headed to set #3
    Anyone else had this problem?
  14. #39
    Zionsville, IN
    93 740i, 84 533i
    Instead of starting a new thread on this, I thought I would ask a question to my problem here. I did have a set of older H&R lowering springs, but one of them broke, so I decided to cut the older stock springs to see how the worked. Well, when after cutting a couple coils off and put them back on, I noticed that the stock springs have a slight taper at each end to fit into the upper and lower perches. I put the cut portion to the top because the lower perch is more form fitting to the spring, while the upper is flatter around the outer rim. The problem is that with the spring larger than the perch, it actually binds against the outer edge of the 'tower' when turning.
    How do those in the cut spring crowd handle this?
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
  15. #40
    cincinnati,ohio
    03 Mini "S"
    I hated mine when I cut the front springs....Was noisy as hell. The problem is after you cut the coils they are too big to sit down in the perches correctly. And will make all kinds of noise while turning.
  16. #41
    1965truckrod's Avatar
    1965truckrod is offline JFV Photography BMW CCA Member
    Santee, CA
    1993 BMW 740IL (E32)
    Not sure if this is still relevant however I have a few detailed pictures of the control arms on my suspension write up but I had previously done the control arms before the springs and shocks. I can make up a write up if someone would like a bit more detail on the ins and outs of the larger bolts and how the assembly goes together.
    http://www.mediafire.com/?a1itatmi4nh9h08
    or from google docs:
    https://docs.google.com/viewer?a=v&p...2ZGI3&hl=en_US
    Jesse
  17. #42
    Australia
    94' 740iL / TE Cortina
    Can some one recommend me a setup?
    My current suspension is stock height I believe. I want a more neat looking stance.
    My wheel sizes are.
    Front : 245/35/R19
    Rear : 265/30/R19
    I'm wanting the rear wheels to have a slight tuck under the guards. For the front wheels I don't want these to tuck under the guards but have a more fender filling appearance.
    I still would like the car to feel like a 7 series and not a suped up Japanese sports car but I'm willing to sacrifice a little smoothness.
    Here's a few pictures of what the car currently looks like. I can take some more on request.
    1994 740iL - 3.15LSD, Rollin' on 19's
    1979 TE Cortina - N/A 6cyl, 14.0@101mph
  18. #43
    Earth
    thats a gorgeous cortina!!
  19. #44
    Nov 2008
    Clemmons, NC
    96' BMW 328i
    has anyone actually used an e34 coilover setup on an e32 front and rear? I want to go really low
  20. #45
    Earth
    i think 89bmw735il has done it
  21. #46
    Manhattan Beach, CA
    S/C Tacoma 4x4, + 330Ci
    TEaaron ur 7 looks amazing
    i think a 1 inch drop in front would be perfect for you.... and btw did you swap the 3.15 LSD in the car yourself? im very interested in that mod, can you please tell me how wonderful it is?
    Glare shielding www.justoffroad.org
  22. #47
    Australia
    Quote Originally Posted by DSMjrv View Post
    Yep, put it in last week when my 2.93 broke. the acceleration has improved in 1st and 2nd gear. The LSD feels nice, the back end will step out now like never before if you're pushing it around some 1st or 2nd gear corners.
  23. #48
    Manhattan Beach, CA
    ZOMG i cant wait to turn my 7 into a real sports car!!!!
  24. #49
    May 2016
    DC
    1991 BMW 750il
    Sent from my VIVO XL using Tapatalk
  25. #50
    May 2016
    UK
    01/1992 E32 735i SE
    I've got h&r springs ready to install. Can I fit them with stock shocks?
