*bump* Couldnīt figure it out yet..
Hi f00gami,
are you still around? I need some guidance in a FRM2 retrofit. I'm sure im not the first to ask, but you can e-mail me at srohang1@gmail.com
Great, I appreciate the prompt response. I just received my FRM2 module in the mail today. I will be attempting the retrofit this weekend. I have used ncsexpert to code some features on my car, but I have not used winKFP or toolset32.
I am downloading this file as I am typing:
http://bmwcoders.com/forum/bmw-gt1-o...tool-winkfp-1/
I will be following the steps that you posted earlier, but I am not sure how to use winkfp. Do you have any suggestions? If I have any questions, I hope you don't mind helping me out. I appreciate your support.
FYI, I found this video, is this similar to what I need to do in winKFP?
[ame]http://www.youtube.com/watch?v=cF-V4ubkuNU&feature=related[/ame]
f00gami, I installed the FRM2 in my car. How did you program the module using winKFP? Another forum member said:
Run Inpa and read out the assembly number from light module, run winkfp and click comfort mode, enter zusb (you need to enter the assembly number), remember the ECU name, click update adn choose the right ECU family, next step: enter VIN and click done. Next click prog zb-update, ok and wait a bit, winkfp is programming the ecu.
The problem I am running into is that INPA cannot read NFRM so I cannot get the "Ident" assembly number. Any suggestions would be very helpful. Thanks
screenshot:
http://www.e90post.com/forums/showth...7#post11286017
Hi,my friend,I followed your way to clear circuit warning,but I puzzled in this step: steuern_reset_kurzschlussabschaltung,how to choose the lamp_NR? Just fill in"0x05" then press the "clear" button? then F5 to get the status?
Need your help,thanks!
success! my circuit counter had been reset to 0 now,and I also clear the 9CBB wrong memory with INPA,but while I swicth lamp on,the warning show up again
Is that means my wiring is not correct?
Hi! I have a problem with my Angel Eye ring on one side. I've been using car for a long time while I was waiting for LED bulbs to replace the dull yellow ones.Now after replacement that side where bulb was gone for so long don't work at all. INPA says fault 9CB9. Anyway I was trying to follow the guide but when I chose status_lampen_kurzschluss_counter to check f there is short circuit on the bottom in RESULT window I have ERROR_ECU_SUBFUNCTION_NOT_SUPPORTED_INVALID_FORMAT . When I'm trying to reset by clicking reset_kurzschluss_sperre lamp_id 0 to 255 (shall I leave x05?) and clickin job_status on the other side it says in RESULTS window OKAY.But then trying to clear faults in INPA and fault is still present.What am I doing wrong?Guys please help!Regards
Hi Guys,
I need really Help !
Maybe I'm stupid but I don't understand how put the Lamp number... I did all the rest without problem but the story of Lamp Nr... I don't understood... In the empty line upside argument 1 and Lamp_nr I tested to write 1 or other numbers but it's not working... A Window open and in Job Status it tells me that it was not good... Problem with Ecu, command not possible or something like this...
So I think the problem comes from the Lamp_nr...
Could you please show me or a capture of Tool32 with the Lamp_nr written example.
I've seen other members don't understand like me...
thank You so much !!!
I'm waiting for same thing Gofaster!
Hope we would have a good reply because I'm tired by my right Rear tail light OFF... The bulb was melted... This is why my FRM module shut down this bulb. And why I want reset the Short circuit count (which is at 83>). But when I write 1 or 4 or 30, nothing is working... In the job result it tells me that Ecu can't do this operation... I'm sure I type bad the lamp nr.
I'm lost...
did you ever figure this out????
can you or someone else please explain or give a couple examples of exactly we should be putting in the arguments spot and then hit f5?
the only options in the dropdown are lamp_nr and 0x3f.
no one on any forum can give me straight answer to this and I keep getting errors no matter what i try. They just keep copying and pasting the same damn post over and over without explaining it!!!
Sorry for the anger Ive been trying to fix this for a while now hahaa
So no one has ran into an issue before, figured out the problem and posted the answer. Anyway, I have the same issue with my right rear tail light, I will spare you the details because I think I have this figured out, as soon as I have a charged battery I will test it and post results.
Based on all of what I have read, ( 0x3f ) is equal to 63 in hexadecimal, so, I am not clear on half of what everyone is posting but if you've entered ( 0x3f) and it said okay and has not replied with an error it shows that hexadecimal is the accepted format for lamp_nr.
I may be wrong until I test but if you know which lamp you are are trying to clear go to the following link and look up hexadecimal and see what your number converts to in hexadecimal, if this solves your problem great, if not lets keep searching.
I will update you all on my findings, here is the link for a converter.
http://numbermonk.com/
Here is the procedure for resetting the module. Read below but these instructions will help newbies like me! If you have an old version module then use "_reset_kurzschluss_sperre". Newer modules use the "steuern_reset_kurzschlussabschaltung". You can tell by sending a reset command and if you get an "OK" then you are good otherwise you will get a "lamp error". Make sure you get a "OK" when you send the job by F5. Another big deal is that I had to use Hex numbers in the input field and make sure that the "data" box is unchecked when using a hex input! As above use this for the hex numbers http://numbermonk.com. The DRL is in the 30's FYI
From Older post:
Connect cable to your car, launch Toolset32 and load FRM70.prg (for FRM2).
- In the window called Select job: FRM_70, select the job status_lampen_kurzschluss_counter. In the list Results select job_status and the lamp output which is shut off due to short circuit protection.
- Send the job to the car using the F5 key. You should get an answer in the Results window and the COUNTER value should be > 0. If COUNTER is = 0 then you didn't select the right lamp output. Try finding the one(s) which have COUNTER > 0. You will look at this value later to see if the short circuit reset-job actually worked.
- Now, switch job to steuern_reset_kurzschlussabschaltung. Notice that this job requires one (1) argument: lamp_nr. Lamp_nr is a number 0-255. Enter the lamp_nr to clear in the Arguments list and select job_status under Results.
- Send the job using F5. Make sure you get an answer OKAY in the Results window.
Note: I don't know the mapping between each lamp and lamp_nr, so I simply sent the command 64 times for all lamp_nr from 0 to 63. Try this - I guess it can't do any harm. Since lamp_nr is supposed to be an integer, I guess possible values for lamp_nr are 0-255.
When you have sent kurzschlussabschaltung-commands for all lamp_nr, do the first job again (check COUNTER). If everything is good, the counters which were > 0 before should now be = 0.
Also, I see there are two jobs which are named quite similar - steuern_lampen_kurzschlussabschaltung and _reset_kurzschluss_sperre. I don't know the difference between these two, but if one doesn't clear your counters, I would try the other one too. Both jobs require the lamp_nr-argument.
Bringing this back again. I have a section of rear tail lights out (outer tail light bars) on the driver's side. I think the FRM just detected a short circuit because I hooked a trailer hitch wiring harness up using the left rear light for only signal indication not power. That might be too much for the FRM to tolerate.
The 23rd I will be seeing if this reset is possible with another member that lives in the area that has the coding laptop. I will report back the results. I printed the hex code conversion since it has been 35 years since I programmed hexadecimal.
Appreciate the trouble shooting by our members as an aid to correct issues like mine...
BMWCCA 149159
FRM70 Lamp numbers
Code:LAMPNR NAME TEXT 0x00 AUSGANG_FL_LINKS Fernlicht bzw. Abbiegelicht links 0x01 AUSGANG_FL_RECHTS Fernlicht bzw. Abbiegelicht rechts 0x02 AUSGANG_AL_LINKS Abblendlicht links 0x03 AUSGANG_AL_RECHTS Abblendlicht rechts 0x04 AUSGANG_BEGRL_LINKS Begrenzungslicht links 0x05 AUSGANG_BEGRL_RECHTS Begrenzungslicht rechts 0x06 AUSGANG_NSW_LINKS Nebelscheinwerfer links, PL3 ab 07/14 und (SA5A1 oder SA896): Bremslicht links 0x07 AUSGANG_NSW_RECHTS Nebelscheinwerfer rechts, PL3 ab 07/14 und (SA5A1 oder SA896): Bremslicht rechts 0x08 AUSGANG_FRA_LINKS_VORN Fahrtrichtungsanzeiger links vorne 0x09 AUSGANG_FRA_RECHTS_VORN Fahrtrichtungsanzeiger rechts vorne 0x0A AUSGANG_FRA_LINKS_HINTEN Fahrtrichtungsanzeiger links hinten 0x0B AUSGANG_FRA_RECHTS_HINTEN Fahrtrichtungsanzeiger rechts hinten 0x0C AUSGANG_R56_CS_ORANGE PL3: Colour-Switch Orange, sonst: LED-Zusatz-Fahrtrichtungsanzeiger links 0x0D AUSGANG_R56_CS_BLAU PL3: Colour-Switch Blau, sonst: LED-Zusatz-Fahrtrichtungsanzeiger rechts 0x0E AUSGANG_BREMSLICHT_LINKS Bremslicht links, PL3 ab 07/14 und SA5A1: Tagfahrlicht LED, PL3 ab 07/14 und SA896: Tagfahrlicht links 0x0F AUSGANG_BREMSLICHT_RECHTS Bremslicht rechts, PL3 ab 07/14 und SA5A1: Nebelscheinwerfer LED, PL3 ab 07/14 und SA896: Tagfahrlicht rechts 0x10 AUSGANG_BREMSLICHT_MITTE Bremslicht mitte 0x11 AUSGANG_SL_BL_LINKS_1 Schlusslicht/Bremslicht links 1 0x12 AUSGANG_SL_BL_RECHTS_1 Schlusslicht/Bremslicht rechts 1 0x13 AUSGANG_E70_SL_BL_LINKS_2_R56_SML_LV_RH E70: Schlusslicht links 2, R56: Seitenmarkierungsleuchte links vorne, rechts hinten 0x14 AUSGANG_E70_SL_BL_RECHTS_2_R56_SML_RV_LH E70: Schlusslicht rechts 2, R56: Seitenmarkierungsleuchte rechts vorne, links hinten 0x15 AUSGANG_KZL Kennzeichenlicht 0x16 AUSGANG_INNENBELEUCHTUNG Innenbeleuchtung 0x17 AUSGANG_NSL_LINKS Nebelschlusslicht, US: Break-Force-Display links 0x18 AUSGANG_NSL_RECHTS Nebelschlusslicht, US: Break-Force-Display rechts 0x19 AUSGANG_RFL_LINKS Rueckfahrlicht links 0x1A AUSGANG_RFL_RECHTS Rueckfahrlicht rechts 0x1B AUSGANG_BFD_LINKS Break-Force-Display links 0x1C AUSGANG_BFD_RECHTS Break-Force-Display rechts 0x1D AUSGANG_DRL_LINKS Tagfahrlicht links 0x1E AUSGANG_DRL_RECHTS Tagfahrlicht rechts 0x1F AUSGANG_KLEMME_58G Klemme 58g 0x20 AUSGANG_BIXENONKLAPPE Bixenonklappe 0x21 AUSGANG_SMC SMC 0x22 AUSGANG_FRA_ZUSATZ_LINKS FRM3R: Zusatz-Fahrtrichtungsanzeiger links 0x23 AUSGANG_FRA_ZUSATZ_RECHTS FRM3R: Zusatz-Fahrtrichtungsanzeiger rechts 0x24 AUSGANG_FUSSRAUMLEUCHTE FRM3R: Fussraumleuchte 0x25 AUSGANG_R56_CS_GRUEN FRM3R: PL3: Colour-Switch Gruen, sonst: Kl58G Bedienteilbeleuchtung 0xFF UNKNOWN unbekannte Lampe
FRM87 Lamp Numbers
Code:LAMPNR NAME TEXT 0x00 AUSGANG_FL_LINKS Fernlicht links, E92/E93: Abbiegelicht links 0x01 AUSGANG_FL_RECHTS Fernlicht rechts, E92/E93: Abbiegelicht rechts 0x02 AUSGANG_AL_LINKS Abblendlicht links 0x03 AUSGANG_AL_RECHTS Abblendlicht rechts 0x04 AUSGANG_BEGRL_LINKS Begrenzungslicht links 0x05 AUSGANG_BEGRL_RECHTS Begrenzungslicht rechts 0x06 AUSGANG_NSW_LINKS Nebelscheinwerfer links 0x07 AUSGANG_NSW_RECHTS Nebelscheinwerfer rechts 0x08 AUSGANG_FRA_LINKS_VORN Fahrtrichtungsanzeiger links vorne 0x09 AUSGANG_FRA_RECHTS_VORN Fahrtrichtungsanzeiger rechts vorne 0x0A AUSGANG_FRA_LINKS_HINTEN Fahrtrichtungsanzeiger links hinten 0x0B AUSGANG_FRA_RECHTS_HINTEN Fahrtrichtungsanzeiger rechts hinten 0x0C UNBELEGT_1 unbelegt 1 0x0D AUSGANG_BEL_WBL_TASTE Beleuchtung WBL-Taster 0x0E AUSGANG_BREMSLICHT_LINKS Bremslicht links 0x0F AUSGANG_BREMSLICHT_RECHTS Bremslicht rechts 0x10 AUSGANG_BREMSLICHT_MITTE Bremslicht mitte 0x11 AUSGANG_SL_BL_LINKS_1 Schlusslicht/Bremslicht links 1, E92/E93: Tagfahrlicht links 0x12 AUSGANG_SL_BL_RECHTS_1 Schlusslicht/Bremslicht rechts 1, E92/E93: Tagfahrlicht rechts 0x13 AUSGANG_SL_BL_LINKS_2 Schlusslicht/Bremslicht links 2 0x14 AUSGANG_SL_BL_RECHTS_2 Schlusslicht/Bremslicht rechts 2 0x15 AUSGANG_KZL Kennzeichenlicht 0x16 AUSGANG_INNENBELEUCHTUNG Innenbeleuchtung 0x17 AUSGANG_NSL_LINKS Nebelschlusslicht links 0x18 AUSGANG_NSL_RECHTS Nebelschlusslicht rechts 0x19 AUSGANG_RFL_LINKS Rueckfahrlicht links 0x1A AUSGANG_RFL_RECHTS Rueckfahrlicht rechts 0x1B AUSGANG_BFD_LINKS Break-Force-Display links 0x1C AUSGANG_BFD_RECHTS Break-Force-Display rechts 0x1D AUSGANG_KL_58G Klemme 58g 0x1E AUSGANG_FLC_LED LED Fahrtlichtkontrolle 0x1F AUSGANG_VORFELD_BEL LED Vorfeldbeleuchtung 0xFF UNKNOWN unbekannte Lampe
With any luck, these might be able to speed you up.
Giftschrank Projekt
Need to reset the driver's side outer 3 band running lights, one of those you posted has to be it.
Will post results good or bad.
BMWCCA 149159
Thanks to enda320 I used a translator for both FRM 87 and 70 from German to English.
FRM 87 LAMP NUMBER
NAME LAMPNR TEXT
0x00 high beam headlights AUSGANG_FL_LINKS on the left, E92 / E93: Abbiegelicht on the left
0x01 high beam headlights AUSGANG_FL_RECHTS on the right, E92 / E93: Abbiegelicht on the right
0x02 dimmed headlights AUSGANG_AL_LINKS on the left
0x03 dimmed headlights AUSGANG_AL_RECHTS on the right
0x04 sidelight AUSGANG_BEGRL_LINKS on the left
0x05 sidelight AUSGANG_BEGRL_RECHTS on the right
0x06 fog lamp AUSGANG_NSW_LINKS on the left
0x07 fog lamp AUSGANG_NSW_RECHTS on the right
0x08 direction indicator AUSGANG_FRA_LINKS_VORN on the left in front
0x09 direction indicator AUSGANG_FRA_RECHTS_VORN on the right in front
0x0A direction indicator AUSGANG_FRA_LINKS_HINTEN on the left behind
0x0B direction indicator AUSGANG_FRA_RECHTS_HINTEN on the right behind
0x0C UNBELEGT_1 uncovered 1
0x0D lighting AUSGANG_BEL_WBL_TASTE WBL tracer
0x0E stoplight AUSGANG_BREMSLICHT_LINKS on the left
0x0F stoplight AUSGANG_BREMSLICHT_RECHTS on the right
0x10 stoplight AUSGANG_BREMSLICHT_MITTE mitte
0x11 AUSGANG_SL_BL_LINKS_1 tail light / stoplight on the left 1, E92 / E93: Day driving light on the left
0x12 AUSGANG_SL_BL_RECHTS_1 tail light / stoplight on the right 1, E92 / E93: Day driving light on the right
0x13 AUSGANG_SL_BL_LINKS_2 tail light / stoplight to the left of 2
0x14 AUSGANG_SL_BL_RECHTS_2 tail light / stoplight to the right of 2
0x15 sign light AUSGANG_KZL
0x16 interior lighting AUSGANG_INNENBELEUCHTUNG
0x17 AUSGANG_NSL_LINKS nebulous tail light on the left
0x18 AUSGANG_NSL_RECHTS nebulous tail light on the right
0x19 back driving light AUSGANG_RFL_LINKS on the left
0x1A back driving light AUSGANG_RFL_RECHTS on the right
0x1B break Force display AUSGANG_BFD_LINKS on the left
0x1C break Force display AUSGANG_BFD_RECHTS on the right
0x1D clip AUSGANG_KL_58G 58 gs
FRM 70 LAMP NUMBERS
NAME LAMPNR TEXT
0x00 high beam headlights AUSGANG_FL_LINKS or Abbiegelicht on the left
0x01 high beam headlights AUSGANG_FL_RECHTS or Abbiegelicht on the right
0x06 fog lamp AUSGANG_NSW_LINKS on the left, PL3 from 07/14 and (SA5A1 or SA896): Stoplight on the left
0x07 fog lamp AUSGANG_NSW_RECHTS on the right, PL3 from 07/14 and (SA5A1 or SA896): Stoplight on the right
0x0C AUSGANG_R56_CS_ORANGE PL3: Colour-Switch orange, but: LED addition direction indicator on the left
0x0D AUSGANG_R56_CS_BLAU PL3: Colour-Switch blue, but: LED addition direction indicator on the right
0x0E stoplight AUSGANG_BREMSLICHT_LINKS on the left, PL3 from 07/14 and SA5A1: Day driving light LED, PL3 from 07/14 and SA896: Day driving light on the left
0x0F stoplight AUSGANG_BREMSLICHT_RECHTS on the right, PL3 from 07/14 and SA5A1: Fog lamp LED, PL3 from 07/14 and SA896: Day driving light on the right
0x13 AUSGANG_E70_SL_BL_LINKS_2_R56_SML_LV_RH E70: Tail light to the left of 2, R56: Side mark light on the left in front, on the right behind
0x14 AUSGANG_E70_SL_BL_RECHTS_2_R56_SML_RV_LH E70: Tail light to the right of 2, R56: Side mark light on the right in front, on the left behind
0x17 AUSGANG_NSL_LINKS nebulous tail light, the US: Break Force display on the left
0x18 AUSGANG_NSL_RECHTS nebulous tail light, the US: Break Force display on the right
BMWCCA 149159
Well spent a good deal of time tonight with a friend who had coded a number of BMWs and is familiar with the NCS-Tool32-etc. Here again is the problem with my E93 the left rear outer light bands are not functioning. These are not brake lights but parking/running lights. The inner panel attached to the trunk work fine.
Based on this and the fact that power to those lights isn't being received we ran through the lamp data looking for a counter code greater than zero which would indicate a malfunction. Not one counter indicated anything but zero.
I think we didn't enter the hexadecimal code correctly as when we tried to enter it the tool would not accept it.
I am planning to provide my friend post #64 as I think we may have made a mistake there.
Did code Kombi to provide accurate digital display on the instrument panel vs just a D for drive.
More when we attack this again...
BMWCCA 149159
Great post, a lot of info for upgrading FRM...
One stupid question...if we disregard the need for FRM2 when upgrading to Xenon light, is there any particular reason for upgrade from FRM1 to FRM2(3), what are the advantages of a newer version of FRM2(3)?
mIRO
Hm, that seem like a really odd probem. But I thank everyone that has posted an answer because it helps with other peoples problems.
Any luck on this? I'm having almost the exact same issue but I do actually see the short circuit counters that have counted up. I simply cannot find the reset job in Tool32 when I load FRM_70. I've confirmed that I have FRM2 which uses FRM70 so i'm not sure where to go next... I've spent hours in my car running all of the status jobs to see if theres anything that might make it obvious but I've gotten nowhere.
OK, I did this today, all with INPA leads and tools32.
1) Check your FRM for fault codes, you should see short circuit protection or the equiv. and German, and it won't clear.
If should also say which circuit set it off, make a mental note if you haven't already, and you can shut down INPA go to tool32
Fire that up, file>load sgbd and pick you FRM type.
You can look through the jobs and find STATUS_LAMPEN_KURZSCHLUSS and then press the "run once" button, looks like "1x>" at the top, and this will give a list of the short circuit states.
This will probably be a lot of zeroes, and a 1 in the faulty circuit.
Click the Tabellen info tab, usually hiding in the bottom left corner, or you can select it from the "windows" option on the program header at the top.
Zip down through the list of tables until you see LAMPNRTEXTE which is a list on the lamp's hex codes. Find the one which has the problem and remember the number, or numbers if you have a few busted.
Back to the tool32 main window, and go to _RESET_KURZSCHLUSS_SPERRE aka RESET SHORTCIRUIT PROTECTION
In the argument box, type 0x3e for example, i.e whatever the bulb was which had a problem, and press the "run once" button. You should get a window pop up, and it'll have JOB STATUS OKAY! written in it.
Repeat if you have more than one bulb gone etc.
You can now go back with INPA, check the code, and delete it, and you'll see it shouldn't return. (or run the FS_LESEN job in tool32, to check, and then the FS_LOESCHEN job to clear, but it does look like tool32 wants you to tell it the fault code number to delete)
If you want to have a look at your options without pluging into a car, click configuration>ediabas in tool32, and tick the SIMULATION box.
Don't worry about the "no sim file" message, those are pretty basic and dull anyway, they just pretend there is a fault to play with.
Giftschrank Projekt
Thank you so much everyone for all this info!!!!
Could anyone tell me if I can reset the FRM module in my E70? It crapped out while coding it with NCS-Expert and I have no idea why.
I want to thank enda! Reset LCM perfectly!
