the valve is for 1/2" pipe thread, and it will drain back into the oil pan through the oil filter bypass hose
The problem with my car is I'm burning about 2 to 3 qts a month and its all sitting in the intake manifold. the oil thats made its way into the intake isnt very thick so it flows easily. The valve I'll be using is for a 1/2" pipe. I doubt I'll have a problem
Didnt install it yet. need the time to do it. maybe this weekend since its gonna snow
Cleaning it out wont be a problem, I'll just remove it and flush it out with carb cleaner. The solenoid valve is normal open so when there is no power going to it, it stays open. I'll have it wired to an ignition power so when you start it closes
2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4”cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50”
Guys I need some help.
Bought a 540 with the M62, it had a non running engine due to timing problems. New chains and guides though.
After taking the upper timing covers off (I did not remove the lower cover or the jesus bolt) and retiming the engine is suddenly blowing blue smoke at startup. Just changed the oil seperator on the back of the intake manifold, I also cleaned the intake manifold very well.
But it is still blowing smoke, I really doubt it is the other oil seperator since it only started when I retimed the engine?
Could I possibly have nicked a hose or forgot to connect something? :/
I have a new (to me) 2002 540i that was blowing smoke at start-up (sometimes, often enough to bother me). I'd replaced the CCV and still had the problem. So I did the oil separator by-pass as others here have suggested. Thank you all! It's working great.
In this case, my car had a connector for a hose at the rear of the driver-side cam cover that had never been opened up. So I drilled a hole in it and used that for the new outlet for blow-by gasses. I got an X5 oil separator and modified the CCV to block the flow from the stock oil separator and take the flow from the external one that I installed. And like others did here, I spliced an oil drain line into the unpressurized line from the oil filter. Works great.
Thanks again to so many who helped on this thread.
Sounds pretty good! Any pics.
Sure. Here are some photos. I'm not wild about the red hoses to the external oil separator, but I wanted to do this before taking a trip and that's all I could find locally. I might replace them with black hoses before long.
One photo is obvious. The other is above the rear of the driver-side cam cover, looking down on the hose connections. The one closer to the camera is attached to the cam cover. I used a brass plumbing elbow with 3/4' OD, and the hose comes out neatly, with no kinks. (It was a tight fit between the cam cover hose fitting and the stainless fuel line above it.)
If you look closely in the second photo you can also see where I attached the red hose from the oil separator to the CV. (I modified it by adding a 3/4' OD brass pipe in the end of the CCV, which also blocked the stock air (and oil) inlet to the intake.)
Hate to add to a old post but I just bought a 97 540i and its got a botched CCV delete and I need a good proven fix for the external catch can setup. Just joined the forum a few days ago. Don't trust driving my car till I get this fixed. Replacement of the OEM CCV system is not an option now. Previous owner made sure of that by removing all the oem parts and plugging off the ports.
Cant do pics here yet, but can email them.
My email is mondogymc@gmail.com
so hit me up, I can really use some guidance and help on this please.
Getting ready to do this....the primary thing I'm confused about is how the rubber hose (and BTW, has anyone come up with a good source for a high temp oil resistant hose rather than heater hose) that is connecting to the Oil Separator under the manifold is able to seal the hole to the OS? Didn't the spring on the original pipe do that, along with an O ring? So now there's no spring force....
thanks, roy
Found McMaster Carr has 3/4" oil hose rated at 450 degrees F. So I'm using the original pipe, and moved it inside the coupling hose close enough that I could use the firmness of the pipe to mount a regular hose clamp so it will wedge against a rib on the block which is lower than the intake surface. Locks the Oring in place very solidly.
roy
I should have posted better pics before, and I haven't been following this thread. Sorry.
Here is a pic of my modified CCV. Pretty simple. The plug at the end (where I put the piece of pipe) is glued in and can be cut/pried out. That's where I put a section of 5/8" ID pipe. (It might have been a pipe section or cut from a pipe adapter/connector. Can't remember but if you browse Home Depot you can find something that works. This one is slightly larger than 3/4" on the outside, but my 3/4" hose fit on it OK.
I used 5 min Quick Steel, or something like that, to plug the hole on the side and to secure the pipe in the opening for the blow-by gasses from the external OSV.
Actually, this is a photo of an extra one that I have. I can't remember why I didn't use it. Not sure about the diaphragm and I'm not where it is, so I can't check it now. Anyway, after this weekend I can send it to the first person who wants it, for the cost of the postage. Just send me a PM.
Can someone bring this back to life and provide pictures with a detail where hoses go? Rather than random sketches and up close pictures of hoses and plugged ports? This could be very useful if someone had a detailed outline on how to perform this modification with accurate diagrams, routing of hoses and parts used.
Been reading up on adding an oil catch can and doing a CCV delete, I have a 95 540i M60, my stock oil separator is still working fine, I notice that there is a thin film of oil in my manifold no pooling since diaphragm is working and would like to add a catch can to further reduce blow by contaminant.
I wanted to know if I can keep the stock oil separator and add catch can between the separator and the manifold CCV delete plate? Will this setup work in catching contaminants and also reintroduce a vacuum and flow to work with MAF sensor to run engine smoothly?
Any catch can that will fit in this engine compartment and what size hoses and connectors need to maintain the right amount of vacuum?
Any feedback or advice is appreciated .... new to oil catch cans .... thanks.
Back from the dead thread, I did this copper tube setup and it did NOT work in my application. The car I have has a major smoking issue and I replaced the ccv with a cheap unit and it did nothing. On to the OSV. I was worried I had a bad rings or bore scoring that it was smoking so bad. I didn't want to pull the manifold to hook up to the osv tube at the timing cover so we tried this copper tube fix. It just didn't provide enough vacuum. We took the catch can and hooked it to the port on the ccv plate where the booster goes and after a couple minutes of reving the motor the smoke cleared up. I'm not sure if it's the cheap ccv or what but it just didn't work. We went ahead and ordered a ccv delete plate for $60 and going to go that route since the ccv is ruined now.
